Question about Husqvarna Garden
Tecumseh LH358SA engine overspeeds- throttle inoperative
I don't have an exploded diagram to see if anything's disconnected. I've exposed the side of the engine where the throttle is. Small wire with a bend sits in a groove on a metal plate that has holes in it. Should wire go in a hole or stay in groove?
Had this same problem 2 yrs ago, and it was because the governor let go, engine overspeeded and threw rod through wall. Now, same problem but I was able to shut off engine in time. Tried starting again- same problem. Called service, they said it's a throttle adjustment. Thought I'd ask here.
  • 2 more comments
  • typewrite343 Mar 02, 2009
    Any possibility I could send you a few pictures of what I'm seeing? When I move the throttle lever, I don't see anything attached to it moving. I do see holes in the plate that the throttle lever moves, but nothing in those holes.
  • typewrite343 Mar 04, 2009
    Thanks for all so far. Sorry so long for a reply- I was down sick. Where can I send the photos?
  • typewrite343 Mar 18, 2009
    I didn't hear from you- figured you were busy. Is there an email I can send pix to? Something's definitely not connected right- who knows how it got that way! Couldn't get the right diagram. Was referred to Techumseh.
  • typewrite343 Apr 04, 2009
    I don't get your last message. I've been very thankful that you've tried to help me, but I can be a little scatter-brained at times, and didn't reply in a timely manner. Quite frankly, no snow = no thinking about snowblower as there are so many othe things that need repair here! Not an excuse, but an explanation. My apologies if you thought I was upset.
    I'm inserting images if you're still willing to help. Of note, when I took the pix, I tried firing it up for the hell of it, and the throttle worked fine. I could go from slow to fast, and it wasn't overspeeding on high. Something's getting stuck somewhere.
4 Suggested Answers
  • 78 Answers
SOURCE: I have a 9hp Tecumseh engine on my Sears chipper
I will try again here.
1 wire link from the top hole in the governor arm to the throttle on the carb. There should also be a wire link with a spring that goes from the Governor arm to the speed control handle.
Posted on Oct 22, 2009
  • 110 Answers
SOURCE: I have an old tecumseh 10 hp eng model vm100. with carb problem
Rigid link to the top hole on govenor arm, spring link to second hole. If engine 'hunts', try the 3rd or 4th hole. Each lower hole will take off a few rpm, but make the engine less prone to 'overshoot' the goverened speed.
If you have not disturbed the govenor arm clamp where it fixes to the shaft that goes into the engine, that should be all you have to do if you have, proceed as follows ;-
Assemble as above. With engine OFF, loosen the govenor clamp. Push the end of the govenor arm so the carb throttle is wide open. Whilst holding it there, rotate the shaft in the same direction as the arm would have rotated it if you hadn't lostened the clamp. Ensure it's rotated as far as possible (this removes ant 'lost' movement in the internal govenor mechanism.). Now tighten the clamp and release everything. Push the speed control to FAST. The throttle should open, and it will requirer about 4 OZ of force on the end of the govenor arm to close the carb throttle. This force will be generated by the govenor when the engine is started
Move the speed conrol to SLOW. Most of the tention should disappear, allowing the throttle to close with very lettle pressure on the govenor arm.
If all this behaves as described, you should be safe to start.
Posted on May 12, 2010
  • 3 Answers
SOURCE: Garden Way "Speedy Hoe" with
The throttle cable does not connect to the carburator. The round end of the cable pushes on the throttle plate arm. The cable is spring loaded and returns when you let off the throttle. The throttle plate arm on the carb is connected to the governor- the plastic vane that fits in the slot in the engine top cowl and sticks up into the cowl- by a spring. The air that is moved by the fan on top of the engine pushes on the governor and brings the engine speed down when you let off the throttle on the handle.
Posted on Jun 16, 2011
I need to replace an ignition coil for a 2006-7 Husqvarna snow thrower (10530SBE) 96195000102. What is the part number and where can I buy it?
The Snow thrower you have uses a Tecumseh LH385SA engine. The ignition coil you're looking for is part number 35135A and a few places online have it available. Below is one online location.
Tecumseh LH358SA Snow Blower Engine Ignition Module Coil 35135A FREE...
Nov 09, 2017 | Husqvarna Garden
MTD snowblower with Tecumseh engine 8 hp stalls out when chock is adjusted to run position
hello ,your engine is a tecumseh HMSK90-156525D, Sounds like carb. may need adjusting. Take the heat box off to expose carb. the heat box is the metal box surrounding the caeb., there should be 2 adjustment screws- 1 on the bottom of the bowl and 1 on the side of the carb just above the edge of the bowl ( depending how the carb sets off the engine - if the carb comes straight out it will be on the side facing towards the front of the snow blower or if it goes towards the handles then standing other side of the snow blower the screw will be facing you), turn both screws in til they just bottom out the turn them out 1 1/4 turns out then start the machine. While the machine is running at low idle turn the screw on the side of the carb. in (clockwise) a little at a time listening for the engine to start to rev up and then start to rev down, bog or studder then turn back slightly to bring idle back up. Once the idle is up then the screw on the very top of the carb. turn that out to lower idle to a normal idle. Repeat those adjustments till you cant get the idle to go up anymore. Now for the screw on the bottom of the bowl- move the throttle up to max and turn the screw in till you hear it rev up higher and starts to bog or sputter then turn it back slightly to bring the high rev to a smooth rev. That should take care of it. If it does not solve it then the carb may need cleaning then the adjustments done again. If you need more help on this please feel free to ask. Sometimes you have to do process of elimination and you start with the easiest first. Also the adjustments should help with the carbon build up on the plug.692509.pdf (application/pdf Object)
i have included the manual to give you a good understanding of the carb, page 7 to 25, hope this helps,don't forget the 4 thumbs up,any comments welcome,thank you.~~
Feb 23, 2012 | Tecumseh Snowblower Snow Blower Starter...
I have a 10 hs tecumseh motor on a riding mower i need an explode view of carb and linkage when start-up engine it goes wide open
Hi and welcome to FixYa, I am Kelly. I understand you have a 10 HP Tecumseh engine. There are service manuals available on line for your engine but without your engine model number it is difficult to pass you the correct one: Here is the link for the service manuals:
Somewhere in the list is your manual.
This is my best guess without your engine model number:
^-Make sure you read about Adjustments in section 1 also.
Running wide open causes:
1. Broken throttle control plate spring
2. Governor spring problem
3. Internal Governor flyweight has departed the governor gear.
4. Throttle plate (butterfly) attached to the throttle shaft in the carb throat has come off the throttle shaft.
5. Broken / missing linkage
6. Someone loosened the governor shaft bolt at the base of the governor arm and allowed the governor to get out of adjstment.
Thanks for choosing FixYa,
Aug 12, 2011 | Tecumseh Garden
I have a lawnmower with a tecumseh 173 cc engine that has experienced a sudden loss of power what could be causing this and how do i fix it
Ok, on the left side of the engine at the rear part of the block is a speed governor on Tecumseh vertical shaft engines. there is a spring that connects the governor to the throttle, if that spring is somehow broken or disconnected it can cause the problem you are experiencing. Check for that spring...if necessary, you can order a replacement through your user manual...cheers!
Sep 07, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Tecumseh hm80 snow blower motor linkage
below is a web site for you to check out the parts at. Hopefully this helps you out. If not, let me know and I will try to get you a better diagram. thanks.
Mar 23, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Garden Logo
3,094 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
