Question about KitchenAid KSBP25FKSS Side by Side Refrigerator
My ice dispenser on my kscs25inss01 is not dropping any ice. When you press the lever no motor noise occurs. The water dispeser is working perfectly, the problem is only on the ice. Help.Chris 813-205-5604
  • Anonymous Apr 12, 2009
    same problem
2 Suggested Answers
  • 409 Answers
SOURCE: Kitchenaid side/by/side refrigerator Model KSCS25INSS01-Auto defrost happening often and ice machine not producing ice
hi there,
the icemaker is not making ice due to the fact that the valve solenoid may need replacing.
check the water line into the icemaker, to make sure that you don't have a water leak.
the reason the fridge is running is due to the fact that it's trying to remove as much warm air out as possible.
i would have a technician look at it.
Posted on Sep 17, 2008
  • 1218 Answers
SOURCE: nowater from dispenser new frig..
If it's new (under one year old) then it's Whirlpool's problem.
Call your selling dealer or Whirlpool factory service.
Should be a free call.
If over a year, post back.. Jack
Posted on Nov 01, 2009
Ice despensor is switch is not working but it is still making ice that I retrieve by pulling ice bucket out and dumping in bowl or glass?
EDIT: Go to the end of my reply and try the last suggestion first please? Sorry, I got ahead of myself.
You should cut off the water supply to the fridge and empty the ice receptacle then you can start removing the ice/water dispenser cavity while looking for the switch that the ice dispenser actuates to get the motor turning. I would start there and use a multimeter (VOM) to test the switch, if it checks okay I would then look at the motor that drives the auger (screw looking thing that moves the ice to the dispenser tube).
Though, if you hear the motor running when you hit the switch? The ice could have just fused around the auger and gently as possible, breaking it up may be the fix the problem and you'll be good as new. Put your ear against the freezer door while pressing the ice dispenser switch to listen for the motor as it may be very quiet through all of the insulation without the noise of the ice that usually is getting pushed through?
PS: I would try my last suggestion before emptying the bin and checking the switch and motor as if you hear the motor running this will tell you that the switch and motor are functioning.
Apr 18, 2015 | Refrigerators
My LG ref. stop dispensing water and ice. make ice but it doesnt dispense it.
I have found that my ice maker makes ice, but i can not dispense, water or ice, control board good, micro switch good only thing left is reversing solenoid. i have just ordered one once i replace it ill get back to you
Dec 18, 2012 | LG LSC26905TT Side by Side Refrigerator
No water from the water dispenser.
a new refrigerator has a water resevoir that has to fill up. you have to hold the water dispenser down for a minute or so to allow this resevoir to fill.
if you have done this already, then you probably have a bad water valve.
Jun 12, 2010 | Whirlpool GS6NBEXR Side by Side...
My Whirlpool Gold side-by-side refrigerator GS6NVEXSL00 wont give me the ice out the door. It makes ice, but when I press the button on the door nothing happens. Seems like the button went out. HELP!
Does the water dispenser work? Is there a light at the dispenser panel, does it light? Do you hear any noises or motors running when you actuate ice dispenser? You could have a power issue for the dispenser. Some newer whirlpool models have an issue with the wiring leading into the door at bottom being so securley fastened to frame, the lack of movement forces the wires to bend, and in time break, with door usage. If water dispenser works, and you hear no sounds when the ice lever is actuated, then you have a problem with the dispenser panel circuit board. if water works and you hear some sounds when ice lever is actuated, such as a loud popping noise, then you have a bad ice dispenser auger motor, not churning the ice out of the bucket.
Mar 18, 2010 | Whirlpool GS6NVEXSL Side by Side...
Ice continues to be made, about a week ago, the part that turns the ice to crush it or dispense it doesn't work, it also takes about 2 minutes when water is activated before it will finally dispense, all...
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing. Take all the ice out of the bin and try. Anything? Take the bin out and try. Anything? The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter. If your are, probably bad motor. If not dispenser switch.
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see how fast the water comes out when you try the dispenser. If it's slow here there is a valve our water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again. It it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Aug 21, 2009 | Refrigerators
Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Jul 24, 2009 | Refrigerators
hi there,
Sep 17, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Ice Dispenser does not work.
Remove the ice tray and clean it throughly with warm water. Let it dry at room temperature and see what happens.
Jul 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Open Questions:
See all KitchenAid KSBP25FKSS Side by Side Refrigerator Questions
KitchenAid KSBP25FKSS Side by Side Refrigerator Logo
131 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
