Question about LG 23LX1RV 23 in. TV/DVD Combo
None of the buttons on the TV are working except
The buttons on the side and the DVD operation buttons all stopped working on the TV except for the power button. The remote still works fine.
    Problem Solver:
  • 10 Answers
Go into the menu and turn off keylock.
Posted on Mar 11, 2010
Power supply or main board ? RCA flat screen
At a guess, main board. I agree if power supply board is bad, you won't get DVD working.
Dec 31, 2015 | RCA 26LA30RQD 26 LCD TVDVD Combo
The sat button on my remote is rapidly blinking, and now most of the other buttons will not work.
When the SAT button blinks repeatedly, or the buttons do a dance (Sat & DVD, TV & AUX, repeat) it means you need new batteries. Replace all four AAA batteries, ensure they are all four aligned the same way, and then hit SAT. Your remote should return to its normal function. If you leave the batteries out for too long, the remote will forget how to operate the TV and receiver, so be sure to have all four new batteries ready before you remove the old ones.
Oct 17, 2014 | DISH Network Televison & Video
Have a Luxor tv for less than a year, but can't find my receipt to take it back. I can use the remote easily whilst watching tv but once I turn into DVD it will let me go to the homescreen, but none o
Try re-programming the control or get a new one it may be that the control you currently have has de-programmed or is not properly cleaned
Feb 23, 2013 | Televison & Video
Hooking up older Curtis-Mathes TV to a newer DVD player.
It is hopeless if the television will not stop cycling through its channels. That is an unattended operation and may point to there being something really wrong with this television OR it may be one of the televisions that has to be fed a signal of some type in order to stop cycling through its channels.
First, how would you connect a dvd player to this television: You would have to buy a part that has yellow red and white holes on one side and a coax output on the other side. I bought one from my local drugstore a little while back. It is Philips brand, and it says connect any dvd player to any television right on the package. I don't know if they are sold anymore, but I imagine that some store would still have them. Then you would disconnect the vcr and connect that part there with the dvd player connected to it (the part I described).
Next, if your television is the sort that needs at least one channel to be programmed into it so it won't keep cycling them, you would have to connect a converter box where you have the vcr connected right now. I know, this troubleshooting takes work, and there is no way to tell if this will work.
Dec 02, 2012 | Televison & Video
Cannot program dvd player. unit does not fully answer commands from remote.
To program the DVD player's remote control to operate your TV, follow these steps:
  1. Turn on the TV, and then aim the DVD player’s remote control at the TV.
  2. Press and hold the [TV Power] button on the DVD player's remote control.
  3. While holding the [TV Power] button, use the number buttons on the remote to enter the two digit code assigned to your brand of TV.
Note 1: If your DVD player's remote control can be programmed to operate a TV, the TV brand codes will be listed in your owner's manual. If you don't have your owner's manual available, click here to go to the download center and download a copy.
Note 2: Many TV brands have more than one code. If the first code does not work, try the next available code.
  1. If the TV turns off, the code worked correctly and your remote control is now programmed. If the TV stays on, repeat steps 1 through 3 with a different code listed for your brand of TV.
Note: If none of the codes listed allows your DVD player's remote to control your TV, then the remote is not compatible with your specific model.
Let us know if you want something more else please accept the suggestion.
Thank You for contacting Fixya.com
Jun 11, 2010 | Audio Players & Recorders
Vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Apr 04, 2009 | Vizio VO47L 47 in. LCD TV
My remote stopped working
Removing The Batteries Should Reset The Remote Try Removing The Battering And Holding The Power Button For 30 Seconds And Then Retry It.
Jan 07, 2009 | Akai LCT3201TD 32 in. LCD Television
Video issue
unplug connector ZF behind the speaker grill if this restores normal operation than you have bad buttons on the front of the tv.
Feb 26, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Nothing works on remote
Hi, check out my (admittedly lengthy) fix here:
http://www.fixya.com/support/t300197-tv_w_built_in_dvd
Hope it helps!
Ryan
Nov 21, 2007 | Mintek DTV-373-D 37 in. LCD HDTV
Avic D2 Won't Complete Initialization
you can open up the unit if you are savey enough and clean the ribbon with an alcohol pad. it worked for me and ever since i did that the door hasnt frooze up on me.
Sep 27, 2007 | Pioneer AVIC-D2 DVD Nav/6.5"...
LG 23LX1RV 23 in. TV/DVD Combo Logo
181 people viewed this question
Computer Repairing
Computer Repairing
