Question about IBM Computers & Internet
Power pin outs
I purchased a ibm netvista 8317 s42 motherbaord and can't find the front panel pin outs for the power on and hard drive led etc. etc. Can you help?
  • Tim Crosslin May 11, 2010
    Can you see what the model number is on the motherboard?
    Scholar:
  • 82 Answers
I have 3 wires on my pc and i dont know where to connect them on my motherbaord - the wires have writen on them "HDD LED" "PWR LED" "PWR S/W" can any1 help me?
Hi Dan,
The wires are from the front panel. HDD LED which causes an led (usually red) light to turn on when the Hard Drive is active. The PWR LED turns on an LED light (usually green) when you turn on your computer. The PWR S/W turns on your computer when you press the on button of your computer. The front panel connector riser is usually located on the bottom right of your computer. They fit on little pins. Unfortunately there is no standard, so connections vary. Sometimes the pins are labeled on the motherboard. . Check your manual. For more info do a google search for "Motherboard front panel connectors". Hank
Mar 12, 2010 | Intel Computers & Internet
How do you open an IBM NetVista computer's front panel? I can open a side panel of the computer easily but I don't see any obvious way to open up the front panel in order to investigate a mysterious random...
Had the same problem. Removing the front panel to get to the hard drive took me quite a while to figure out!
Look at the back of the pc. At the very top (above the connectors) you'll see a blue push. Push it at the same time as pulling the black "handle" (just the plastic - not the metal and plastic) and it releases the bevelled plastic which is gripped so hard otherwise.
This isn't mentioned in any manual or guide. Very odd. There is no need for a flat bladed screw driver at all although it says that in the book. So the front cover rips off top to bottom when the blue button is pressed!
This works on the 8307 and a few other models.
Apr 08, 2009 | IBM NetVista PC Desktop
I need to know front panel pinout values for IBM NetVista 49P15
THE VENDOR HAS THE PIN LAYOUT AND SOME OF THE PLACE WHERE YOU DO BUSINESS WILL HELP WITH GETTING YOU THE DIAGRAM PAPER WORK.
ROD
Feb 16, 2009 | IBM (33P0825) Motherboard
Ibm 8303-21g front audio pin configuration
Manual usually has diagrams and pin configuration for your system.
If you don't have the manual go to their web site and take a look.
Feb 06, 2009 | IBM Computers & Internet
Ibm rear audio
My IBM NetVista 8307-P8G SoundMax Driver Not Support 5.1 speaker settings. pls help me
Dec 08, 2008 | Computers & Internet
Front panel Pinout
the pins are usually labeld on the board itself or in the board manual
May 22, 2008 | IBM NetVista PC Desktop
Pin alignment on motherboard for led switches
Connecting the Front Panel Header
Table 6. Front Panel Header (J9H3)
Pin
Signal
In/Out
Description
Pin
Signal
In/Out
Description
Hard Drive Activity LED
Power LED
HD_PWR
Out
Hard disk LED pull-up (330 ω) to +5 V
HDR_BLNK_GRN
Out
Front panel green LED
HDA#
Out
Hard disk active LED
HDR_BLNK_YEL
Out
Front panel yellow LED
Reset Switch
On/Off Switch
5
Ground
Ground
6
SWITCH_ON#
In
Power switch
7
FP_RESET#
In
Reset switch
8
Ground
Ground
9
+5 V
Out
Power
10
N/C
Not connected
Apr 01, 2008 | Compaq (283983-001) Motherboard
IBM NetVisat 02R4084 Mainboard
With the power on cross the pins with a slide on connector. When it fires on you know which one is the sw. When you cross the reset it will restart. When you try the HD the light will come on during HD activity. And the power light will work when you have the power light plugged. It isn't to hard. Just be careful.
Sep 27, 2006 | IBM (02R4084) Motherboard
Computers & Internet Logo
118 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
