Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Wallpaper I had wallpaper that was in my cellar that had gotton wet it was a cloth wall paper nevertheless it smelled somewhat of mold. My husband put the paper on the wall which looks great but I still can smell an odor of the mole. Is there anything I can put in that room that will kill that smell? Thanks andrew080104@yahoo.com
  • 400 Answers
A bag of charcoal will absorb most smells, but you need to get to the source of the smell. If the wall paper is cloth based, it should be safe to use a small mist spray bottle and a mild mix of disinfectant and bicarbonate of soda which should neutralize the smell.
Posted on Mar 09, 2009
My LG front loading washer smells like wet clothes that have been in the washer for months? Musty smell?washer overnight? Strong smell of musty old clothes
This is caused by the biomass built up inside the tub of the machine. This can also be caused by a moldy door boot. You need to scrub your door boot between the tub and the door. Water settles in the bottom of it and molds. Once you clean this, order affresh washer cleaner for your machine. This kills all the biomass built up in the tub and removes the smell. You will put all three tablets in the drum and run on the longest hottest wash available. When this is completed your machine should smell much better. To keep this from getting so bad again... Keep the washer door cracked open between cycles. This keeps the inside from smelling. Hope this helps
Apr 04, 2012 | LG WM-2277HW Front Load Washer
How do we clean with this machine .
Is this a front-load washer or top load?
Is the machine operating properly, or are your clothes getting a musty smell?
The musty smell has a few solutions, One may work but probably a combination of all will work best.
Immediately move wet clothes to the dryer, do not let them sit in the washer for a long time.
If your clothes smell, put mouthwash with your clothes directly in the tub during the wash cycle (this will not stain your clothes)
leave the door open when not in use (lets it dry out)
If the washer smells, use bleach and hot water in an empty cycle once in a while (kills just about every kind of bacteria or mold which may be causing the smell)
Use washing machine cleaner once in a while(can be found at your local grocery store isle next to detergent)
Dry your clothes completely, damp clothes can start to smell again.
If you are looking for a new washer, try to find a newer model that features a stainless steel tub with silver impregnation. The silver is a natural disinfectant.
Mar 15, 2012 | Washing Machines
Product = model 15962 Problem = really bad smell
A good trick that i found was to fill tub with hot water and put a full cup of dishwasher detergent any kind but has to be powdered not liquid detergent. Do this two times in a row and then every month.
Jun 10, 2011 | Kenmore 15962 / 15964 Top Load Washer
Safe smells like mildew and papers inside are wet. There is mold
Desiccant moisture absorbing packs will help to absorb some of the excess humidity in the safe. In addition to the desiccant packs, we suggest that you open the safe at least once every two weeks for approximately 20 minutes. To alleviate some of the musty odor, we suggest that you remove the items from the safe and wipe the interior with a paste of baking soda and water. Do not store your safe unit in areas of your home or business with already high humidity levels such as a basement or cellar as this will add to the moisture problems. You can get the packs from the following link: http://www.sentrysafeshop.com/Moisture-Control-Desiccant-Packets-p/desiccant%20pack.htm
Sep 05, 2010 | Sentry Fireproof Safe
After completing a load of clothing, the laundry sometimes has a moldy smell. If it doesn't smell right away, it smells after wearing the clothing and sweat a bit. This is not a body smell - this is a...
It sounds like your leaving the clothes in the washer long after the cycle is finished. Once your clothes smell from the washer they will smell moldy dry.
Aug 19, 2010 | Dryers
Customer wants polycomposite tub wall panels over existing embosed wallpaper product is AquaGlass Avondale tub wall set.
advise client panels will most likely shift or not bond correctly when adhesive is applied to wallpaper also will have a mold problem from moisture trapped between panel and wallpaper and depending on thickness of panels the embossed paper may create bumps/waves in panel
Apr 06, 2010 | Home
Bad smell in side car. smells somewhat like a mold or dampness problem.
Check the carpet on the passenger side and see if it is damp or wet. Also, have you noticed white smoke coming from your vents? Does your windshield etc. fog up rather than defrost? If so, you probably have a heater core that is leaking and needs replaced.
Hope this helps! Good luck.
Oct 14, 2009 | 2002 Chevrolet TrailBlazer
Why does our duet whirlpol washer smell like mold. Our washer are
Your washer smells moldy because there is mold growing in it somewhere. To kill the mold and clean the inside of your washer do a hot water wash using no clothes but adding two cups of bleach to the machine. It will also smell better then.
Jul 06, 2009 | Hotpoint Aquarius WD640 Front Load...
The clothes smell if left in the washer wet overnight
Wet clothes should not be left in the washer over night as mold will develop and cause a moldy odor. You could run the load through a rinse cycle with fabric softener or baking soda to get rid of the odors.
Jun 07, 2008 | GE WHRE5260E Top Load Washer
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
78 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
