Question about Maytag Atlantis MAV6000 Top Load Washer
Tub doesn't spin during spin cycle. You can
Tub doesn't spin during spin cycle. You can assist it and get it going but it's much louder than before. My guess is a loose belt. I just need to know how to get to the belt/motor/pully.
  • 4 Answers
If the above doesn't work (not a belt/motor/transmission problem), it may be something similar to what happened to mine. Google something to the effect of "how to remove front panel of xxxxxxx washing machine". You will either need a new clutch clip or re-bend the old.
Fix
New part
Posted on Jan 27, 2013
Tip up the washer from the front and belt is accessible.If you need to get to the motor, insert a putty knife about 2 inches from either side of the top front seam while pulling up on the lid. The top will flip open, the there are 2 small sheet metal screws ( 1 on each side) near the top of the front panel to remove. Then lift up and pull out the front panel.
Posted on Mar 05, 2009
Whirlpool Duet Washer GHW9100LW1 symptoms of knocking noise during spin cycle. Efforts so far: checked shocks manually and observed during spin cycle and no excessive movement. Drum drive pulley:...
Always worth while adjusting the 'balance'!
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 01, 2011 | Whirlpool GHW9100L Front Load Washer
We have a Maytag Performa PAV2200 Washing machine...lately, during the spin cycle it makes a loud whinning or scraping type of noise during the spin cycle and sometimes during the wash cycle.... we took...
Might be the tub bearing going out. Is she leaking any?
Here is a visual inspect and repair of the tub seal:themobilian_1841.jpgthemobilian_1842.jpgthemobilian_1843.jpgthemobilian_1844.jpg
I used a pipe wrench to unscrew this top portion of the seal (lefty loosey)themobilian_1845.jpgthemobilian_1846.jpgthemobilian_1847.jpgthemobilian_1848.jpgthemobilian_1849.jpgthemobilian_1850.jpgthemobilian_1851.jpgthemobilian_1852.jpg
Those 6 springs are pretty tough to get back on there without the special tool
other than that it all goes back pretty easy.
Service manual and more HERE
Mar 12, 2011 | Washing Machines
The washer recently began producing a high pitch squeek during the washing cycle, and a louder than normal sound during the spin cycle.
The motor Carriage is not pulling back fast/far enough special poly lube you can use other lube just wont last long or will deteriorate wheels quickly. What you can do is set for spin, hold open lid slightly with one hand pull back on motor slightly. If sound stops you got it. Other wise sounds like mount stem may need replacing if you do also replace spin bearing this is under basket and outer tub on top of transmission.
Nov 25, 2010 | Maytag Neptune MAH5500B Front Load Washer
Spin cycle noise. no longer sounds smooth
The rear half of the outer wash drum (which contains the rear bearing and tub shaft seal) needs to be replaced. On a 1 - 10 scale, this rates a difficulty rating of about an 8. An experienced appliance tech can do it in about 2 hours, and hit you up for about $500. I do not suggest this as a do it yourself repair. Did you know that the new LG machines use a balance ring to make them much smoother running? (Hint: It may be wiser to replace the machine.)
You can find a service provider, to do the repair or just get parts here:
http://www.lg.com/us/support/repair/support-repair-provider-lookup.jsp
Jul 19, 2010 | LG WM-1832C Front Load Washer
My washer is getting louder & louder on the spin cycle. Is a bearing going bad?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Jun 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
Front load machine will not spin all the water out of the cloths and it is making a noise during the spining cycle.
Hello Friend,
The problem you described suggests that the spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle, as said by you. This would require to call a qualified appliance repair technician.
Check this and do get back to us for any further assistance.
Thanks for using FixYa....!!!!
Mar 05, 2010 | Frigidaire Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Front Loading Washer - Load Banging During Spin Cycle
hello, your problem is that your shocks are bad and need to be replaced. you can access them by removing the front lower panel. make sure you unplug the washer first. you will see 2 of them on either side of the tub. i belive you can twist the upper portion and then remove the bottom screew and remove the shock. of course before you start you should have the new shocks. and make sure their is no water in the tub.
Dec 03, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing machine is louder then normal on the spin cycle.
This sounds like the rear bearing is going. After getting louder, the next problem is grease appearing on your clothes during the spin cycle. This is a very major repair.
Jan 10, 2008 | Kenmore 43042 Front Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
103 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
