Question about Kohler K-5988-2-7 Entree Self-Rimming Kitchen Sink, Black Black
KOLHER Soap dispenser won't dispence soap. - Kohler K-5988-2-7 Entree Self-Rimming Kitchen Sink, Black Black
  • Paintpinto Mar 14, 2009
    I have a soap dispenser installed in my kitchen sink. It has stopped dispensing soap. I have cleaned it, looking for clogged soap, and see nothing obvious. If I depress the pump repeatedly (100 times) it will emit a little foam, but no soap. Before you ask,; yes there is soap in the under-sink container. Does it need priming? If so, how does one do that?
  • Johnny TOLAND
    Johnny TOLAND May 11, 2010
    Have you noticed if "straw like tube" is in pump? if not has probably fallen into soap bottle.Retrieve by unscrewing from under and fish out fallen piece,no need to prime or can check prime by inserting into glass of warm water and pumpng until results 4-9 pumps should do. no results pump is wore out or straw has hole or crack in it. buy new replace.
  • 247 Answers
Pull the dispenser out. Put it in semi hot water foe a few minutes to clean it. Then put the pickup tube in a glass of water and pump it untill water comes out. They get clogged with soap after so long.
Good Luck
Kurt
Posted on Mar 18, 2009
I had the same problem and found out that the neck of the soap bottle had broken off and the bottle was in the bottom of the cabinet. Does anyone know where I can get a new bottle? I can't find a part number on the Kohler site. Thanks
Posted on Jul 09, 2009
My kenmore he2 wont dispence the soap in the soap dispencer
Evening to you
Allow the washer to start a cycle and have the dispenser drawer ajar and observe through which dispenser the water goes.
Does the first stream go through the pre-wash dispencer,secondly notice where the main stream goes and lastly where the softener would go. If this can help you in any way just put use the dispencers as fits the washing.
goodluck
Kolbrun
Feb 26, 2012 | Kenmore HE2 Washing Machines
My dish washer soap does not dissolve, whether or not I put the tablet or the pillow into the soap dispenser. Is it the soap dispenser door? Would hard water buildup create low water pressure so the soap...
The most likely causes are the you are using a tablet in a gel coating but putting the tablets into the dispenser drawer when the dispencer drawer is damp, thus causing the tablet to stick inside the housing; or, if the dispenser drawer is releasing the tablet into the bottom of the cabinet then I would say you have a problem with your water heater. In which case you would need an enginner to come and replace the heater.
Hope this is of help
Jan 25, 2011 | Maytag MDB7100AWB Dishwasher
Dishwasher won't access soap tray
Check if the dish rack is reversed. If it is, it'll block the dispenser from opening.
If that is not the case - you may have problems with soap dispencer solenoid or with control board. Unplug the d/w. Disassemble the door, and find the solenoid contacts on the dispenser. Check for continuity. No continuity - replace dispenser.If dispenser is ok, check wiring for continuity. Otherwise it's the board.
Jun 01, 2010 | Dishwashers
Washer will not dispense soap from dispenser.
make sure that the soap dispenser if clean and free of residue build up. if this is clean you need to replace the dispencer
May 19, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
The soap dispenser is not dispensing all of the soap (not overloaded)and fabric softener is not dispensng at all
dispencer cam could have come off, broken spring, bad disp motor, control not sending power to motor,top must come off to exspose
Dec 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kitchen sink soap dispenser won't pump
soap may be too thick or pump tube may not be touching soap in dispencer. try pumping same soap from cup
Mar 08, 2009 | Plumbing
Water from soap dispenser when spinning
Thanks this solution cured mine and my friends machine with this problem of water coming out of the soap dispencer.
Jan 12, 2009 | Washing Machines
Soap dispencer won' t dispence soap
My Bosch intergreted dishwasher is only 3 years old. For the past year, the dishwasher dispenser refuses to open on the second cycle. We have had the repair man here 3 times, and each time he says it's fixed,but it clearly is not. Does anyone know what to do about this??
Barbara Berger
Sep 30, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Soap Dispencer Doesn't Always Open
We are having the same issue with a new dishwasher. One solution is to leave the soap dispenser box open when you close the door. This will at least get soap in the washer.
Jun 07, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Soap Dispence problem on GHW9200LW
In applications with low water pressure, insufficient water
volume is introduced during the fabric softener dispensing
portion of the cycle to flush the dispenser.
RESOLUTION:
The holes in the dispenser housing were enlarged to allow
a greater volume of water to flow through the fabric
softener dispenser to properly dispense the fabric softener.
Order and replace the dispenser housing, Part
#8181719, to correct the condition
Feb 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kohler K-5988-2-7 Entree Self-Rimming Kitchen Sink, Black Black Logo
2,120 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
