Question about Emerson Smartset Clock Radio
Model cks1850 how do i set the days for the alarm
Model cks1850 how do i set the days for the alarm to ring can i down load the instructions for setting
    President:
  • 814 Answers
Sorry it took so long to help you with your problem. [http://www.emersonradio.com/owners/SmartSet%20Series/CKS1850-1851_072706.pdf] Copy this web link and paste it into the address bar of your web browser.It will take you to the Emerson customer customer support web page that has a pdf copy of the owners manual of your make/model of Clock/Radio. You will need a pdf reader and writer to read and make a personal copy of the owners manual for yourself. In the owners manual will be all the operating instructions for setting up the days for the alarm to work on. If you are still having a problem with the operation of the Clock/Radio's alarm function. Call the Emerson customer support at this telephone number. 1-800-909-1240 between the hours of 8am-4:40pm CT. Give them the make and model number of your Clock/Radio and ask them for assistance. I hope this information helps you solve your problem. Thank you for using FixYa and have a nice day!
Posted on Jun 14, 2009
Directions for Resetting the Daylight Savings Time (DST) Start & End Dates on the Emerson Research Smartset Dual Alarm Clock Radio on CKS1850
Unfortunately, you can't reset the firmware of the clock for those built before Jan 2006; you can work-around the issue. You will need to change time zones for the few weeks between the current daylight savings start and end dates and the ones that were built into the clock. For details see: http://www.emersonradio.com/dst.htm ; click on the link for Group 1.
If the unit was built before Jan 2006 (the serial number will start with a value less than 6), switch the time zone to the next one further east on the second Sunday of March, then set it back to your correct time zone on the first Sunday of April. Repeat this on the last Sunday of October and the first Sunday of November. (If you are in the Eastern time zone (zone 2), set the switch to zone 1.)
If the unit was built between Jan 2006 and July 2006 (serial numbers that start 601 to 606), then you can change the start and end dates for DST. See: http://www.emersonradio.com/dst.htm then choose the Group 2 link. Press and hold the Alarm 1 button then press the Month/Date or Calendar button. After three seconds the unit will display the start date for daylight savings. Press and hold the Alarm 1 and Month/Date or Calendar buttons. When the display is flashng (within 5 seconds from the press and hold step), press the Down or Set button (depending on the SmartSet mode) three times until the display reads 3 and F2 (alternating with the date of that Sunday).
For the end date, press and hold Alarm 2 then press the Month/Date or Calendar button. Then press and hold Alarm 1 and the Month/Date or Calendar button. Again within 5 seconds, press the Up button or Set until the display shows 11 and F.
If the display stops flashing, repeat and set the new dates faster.
You'll have to repeat this is the battery is removed or replaced.
I hope this helps.
Mar 15, 2011 | Emerson SmartSet CKS1850 Clock Radio
KADIO KD-3806 Model watch. How can we set date and time.
ALL PARAMETERS CAN BE ADJUSTED BY USING KEYS
GIVEN BACKSIDE...KEYS ARE
MODE (LONG PRESS-4 SEC) TO ENTER INTO SETTINGS;
UP/DOWN TO CHANGE THE PARAMETERS; \
*C/*F KEY TO TOGGLE BETWEEN TO TEMPERATURE FORMAT;
SNOOZE BUTTON TO SET SNOOZE IN ALARM-MULTIPLE SNOOZE CAN BE SET;
RESET KEY CAN BE USED TO RESET CLOCK TO DEFAULT;
DAY COUNTDOWN , AND TIME COUNTDOWN CAN BE ADJUSTED;
DETAILED INFORMATION TO SET THE CLOCK
INSERT CELLS;-SCREEN SHOWS DEFAULT VALUES-INITIAL MUSIC WILL RING;
LONG PRESS MODE BUTTON-KEEP IT PRESSED UNTIL 12 STARTS BLINKING;
USE UP /DOWN BUTTON TO ADJUST HOURS...
THEN SIMPLY PRESS MODE AGAIN, NOW MINUTES 00 IS DEFAULT WILL START BLINKING;
USE UP/DOWN BUTTON TO ADJUST MINUTES;
AGAIN PRESS MODE, SCREEN WILL SHOW YEAR 2002 DEFAULT BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW MONTH BLINKING, USE UP/DOWN KEY TO ADJUST CURRENT MONTH;
AGAIN PRESS MODE, SCREEN WILL SHOW DATE BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW 12:00 BLINKING WITH ALARM SIGN (FOR ALARM SET);USE UP/DOWN KEYS TO SET ALARM, FIRST HOURS AND THEN MINUTES FOR ALARM; THEN ON PRESSING YOU CAN SELECT SNOOZE MINUTES;
AFTER SNOOZE ON PRESSING MODE AGAIN YOU CAN SELECT DAY COUNTDOWN TO SELECT 999 DAYS COUNTDOWN FROM CURRENT DATE;
when watch displays time and everything .....
each and every buttons has some function;(shortcuts)
press down to toggle between 12hr/24hr format;
press up to enter contdown timer;
press snooze to set snooze in alarm;
press c/f to toggle between two temperature formats;
press mode to toggle between alarm time and current time
Nov 12, 2010 | Watches
Don't know how to set alarm on the 1850
Hello, go to www.emersonradio.co there you will find your instructions, hope this helps -Lance
Oct 09, 2009 | Emerson SmartSet CKS1850 Clock Radio
The green set lights up for sat and sun--the days I don't need to get up. How do I set the clock for days m-f. thanks
HOLD DOWN ALARM 1 OR ALARM 2 AND CYCLE THRU USING ALARM MODE FOR WEEKDAYS, WEEKENDS, OR ALL DAYS...
Aug 17, 2009 | Emerson SmartSet CKS1850 Clock Radio
Smart set alarm clock - resetting instruction
First, make sure the time is set correctly – Eastern Standard Time (EST) is the default
Press the Alarm Mode button – it has options for Weekend, meaning Sat and Sun only; Weekdays (Mon-Fri), and Everyday
While holding either the ALM 1 or ALM 2 button, press up or down to set the correct wake-up time
Release ALM 1 (or 2) when you are finished
Here is a link to the manual:
http://www.emersonelectronics.ca/emerson/en/product/view/17796
-Tha Mp3 Doctor
Jan 15, 2009 | Emerson SmartSet CKS1850 Clock Radio
Nelsonic watch with no instructions
Copy and paste this link. It will take you to Bulova's service centerwhere you can download instructions for any of their watches.
http://bulova.com/service/servicecenter.aspx
If you appreciate me finding this answer for you then please rank this solution as "fixya" or at least "helpful" as what I have found for you will solve your problem. :-)
Jan 09, 2009 | Bulova Watch
Changing alarm dates
Press the "alarm mode" button and change it with the + and - buittons. On the display you should see what days it will go off.
Jan 05, 2009 | Emerson SmartSet CKS1850 Clock Radio
Emerson Smartset alarm clock
Hi - You can download the manual from the link underlined in blue below:
CKS3528
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Jun 25, 2008 | Emerson Smartset Clock Radio
Emerson Research SmartSet Clock Radio
There is a solution for this already. You can reprogram the clock to use the new DST settings.
See http://www.fixya.com/support/t137304-daylight_saving_time_issues
Mar 10, 2008 | Emerson SmartSet CKS1850 Clock Radio
Setting the days on the alarm?
Hold the alarm button down and press the mode button to change the days of the week you want the alarm to go off.
Oct 11, 2007 | Emerson SmartSet CKS1850 Clock Radio
Emerson Smartset Clock Radio Logo
246 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
