Question about Panasonic Viera TH-42PZ80U Plasma TV
What is the screw hole size in back of tv
I have a Panasonic TH-42PZ80U tv, I bought a wall mounting bracket that is missing the screws that fit into the back of the tv. Can you tell me what size and if it is fine thread. I have tried 3/8" to big, 5/16" fine, and 1/4" to small
  • Marie Warwick Maynard
    Marie Warwick Maynard Feb 02, 2016
    I ha e an emerson tv that i need screw for the bracket to tv
    President:
  • 2,992 Answers
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
Posted on Mar 01, 2009
What is the size of M6 screw (dimeter and length) for wall hanger
Posted on Aug 17, 2012
The pedestal screws are a different size than the mount screws. I would like to know what size are the mount screws?
Posted on Dec 21, 2009
2 Suggested Answers
SOURCE:
eagle338
  • 4889 Answers
SOURCE: no screws for the tv to mount to the bracket
You will 4 m5x18mm and 4 m5x25mm machine screws. That should do the trick..
CAN I GET SCREW HOLE SIZE OF BACK OF TV FOR WALL MOUNT
The 3 most common sizes for the bolts to mount the wall mount to the TV is either M8x20mm or M6x20mm or M4x20 depends on the size of the screen. This site has a chart that will show you what to look for, for your TV M6x20mm TV to Wall Mount Bracket Phillips Bolts Screws Stainless VESA 200
Aug 23, 2015 | Panasonic Viera TC-32LX85
TH-C4HD18
the four holes on rear are for wall mounted bracket, the stand that goes in bottom generally requires the removing of a cover plate which will be about size of the upper part of stand and will be approx four screws, remove cover and stand will slot in and fix with scres/bolts accordingly.
May 05, 2012 | Panasonic TH-C42HD18 42 in. Plasma TV
Can't find screw size to fit back of my 42in Toshiba Regza. I want to mount on wall. Screws that came with the 42in wall mount don't fit it. It's not a 5/16, 6mm, 8mm fine thread or course thread
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
Dec 19, 2010 | Toshiba REGZA 46RV530U LCD TV
I have a Panasonic TH-42PZ80U 42" plasma tv I would now like to mount on a wall. I have gotten conflicting information as to whether it is VESA or not. Can you tell me anything about wall mounts for...
Just purchase a mount for 42" and above They come in different styles for your likening and make sure the wall bracket gets mounted into the wall studs and your all set. No major job. I get $150 all day long for those installs.
Nov 26, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Screw size for wall bracket
Hello. The best thing for you to do is take your bracket to a hardware store and get the largest diameter screw you can that will fit easily into the holes. Regarding length, you should try to screw into the wooden studs behind the sheetrock or plaster wall so you will want 2 and 1/2 or 3 inch screws. Be sure to drill a pilot hole for each screw but only go in half as deep as the screw is long and use a bit that is only half as big around as the screw is.
Jan 14, 2010 | Panasonic Viera TH-50PX80U Plasma TV
No screws for the tv to mount to the bracket
Mar 01, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Does model th-c42hd18 require only a panasocin wall mount bracket. Seems others do not work
I am not familar with your exact model but my Panasonic TH-42PX600U 42 in. Plasma uses a generic brand wall mount. The first mount I bought would not fit so I returned it and bought a different brand which worked well. Start shopping your local stores (even walmart has a couple of different types to choose from), carefully open the packaging in case you need to return it and see if it will fit the mounting holes on the back of your TV. If it fits on the back of the TV then you should be good to go.
Jan 11, 2009 | Panasonic TH-42PX600U 42 in. Plasma HDTV
42'' LCD PLTV-4250 MOUNTING
The universal mounts generally have a selection of screws that are to fit different makes and models of tvs.
If you bought the appropriate size mount for the size of your TV, there should be mounting holes that match your TV, and screws that will secure it.
I have not seen any mounts that use more than four.
Apr 07, 2008 | Protron PLTV-4250 42 in. LCD Television
Panasonic Viera TH-42PZ80U Plasma TV Logo
24,909 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
