Removal of housing of Viking washing machine
I have a leak at the bottom of the machine and want to look for the source of the leak.
  • 15,935 Answers
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Hello - I followed your instructions to someone else`s problem & got as far as I could. To access the internal parts I`m sure I need to remove the silver top - but I cannot remove the black knob o
Most likely the pump on your washing machine. Coins get stuck in there and break the plastic housing. You won't need to lift up the beast-just get to the back with a flashlight.
Nov 11, 2014 | Washing Machines
Appears to be the condensation leaking into freezer bottom and leaking all over the floor. Drain has been thawed but leaking continues. Local dealer advised to get a fix kit from viking, but I have no...
Drain troth kit with clasp to fix defrost drain port and to program board for conventional defrost to 4 hrs run time. Viking parts dist has that available 8004889868
Aug 26, 2011 | Viking VCBB363L Bottom Freezer...
My washer is leaking when draining very small leak what can i do
Start with inspecting the entire lenghth of the drain hose for any type of pin hole or abrasions that could be the source of your leak.
If the leak seems to be coming from the inside of the machine, take a putty knife or something similar and insert it between the front panel and the top panel that the lid is connected to about two inches in from the edge of the side panels and you should feel a fastener, push inward or towards the back of the machine, you will have to push hard, this will seperate the top and front panels, lift up on the front panel and remove it, now inspect the inside of the machine and try to locate the source of the leak, you may have to run the washer thru different cycles(fill,drain,spin,etc.) to see the leak source.
Pay close attention to the pump area for the leak, this has been a source of leaks in the past, with a plastic pump housing, they have been known to develope leaks by way of holes worn thru the plastic housing!
GOOD LUCK !
Aug 08, 2010 | Maytag LAT3600A Top Load Washer
I have a kleenmaid top loader washing machine. There is a leak coming from the bottom of the machine - I have taken the fabric softener cup out - but there is no bolt to remove the agitator. any ideas?
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Sep 10, 2009 | Washing Machines
Remove housing on viking se
there are six screws on the back and 1 on the free arm cover after that there are two on the bottom, after removing all of those screws its easy if you hit the side by the handwheel and it should pop free. i really wouldnt recommend doing this if your not a certified viking tech as it will void your warranty
Jun 24, 2009 | Husqvarna Viking 1
Top loading washing machine leaking at center bottom
remove panel below door and run it. Then you can see if it is the front seal or back at pump. Two screws on bottom of panel to remove it
Apr 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Water leaking from bottom
Replace water pump. Common problem. Unscrew the control panel ,two screws on each end. Flip control panel over and unsnap gold brackets from base to the back. Lift up housing and disconnect lid switch, remove housing. The water pump is in the front lower that has two hoses , disconnect hoses and unsnap pump. My sister fixed hers in about 25 minutes.
Apr 06, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
I have a maytag 6800 toploader. Water from bottom
If you feel OK to troubleshoot the Service Manual will give you some possible leak points to check. If you want to troubleshoot you beyond basic inspection you will need to remove the front panel and observe where the leak source might be. Worse case a tub seal issue. Easier fix would be a leak in the drain line; tub to drain pump/drain pump to output drain hose, one poster recently reported a cracked drain pump housing as their leak source. Here is a link for the manual.
http://www.fixya.com/support/r1655507-found_service_manual_neptune_top_load
The one leak source I would be concerned with is a leak described around the clutch pulley on page 28. If that is your leak source it’s a big project and you may need think about a service repair (BIG$ for labor but see if you can get a no cost quote) or a replacement machine if it’s not cost effective to repair. If you go the replacement direction call the Maytag CSV phone number at the end of the manual and complain, I got them to offer up a 25% rebate by talking to a supervisor on their Whirlpool, Amana, Maytag product line (don’t shoot the messenger). I’m a DIY’er and if I can’t fix this thing for under $300 with ebay parts I would move on. But let’s go one step at a time and try to ID the leak source.
To help you remove the front panel see page 33 Pic for the putty knife insertion point to raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base.
See page 41 for front panel removal don’t poke around in there with the power on just view for a water leak with a flash light while the machine fills in a Quick Wash cycle and as the machine proceeds through the wash cycle. Safety first, please follows the safety guide lines in the SM. Post again if you have questions and I’m sure I or other forum members will chime in for support. Good Luck.
Mar 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Whirpool Front Loading HE (GH9400PW4) washer is leaking! Hellllp!
remove the bottom acesss panel and run through drain/spin cycle youll see where the leak is then. perhaps debis has puntured drainline hose or pump housing is leaking
Mar 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Asko Washer leak
Remove the bacpanel, and locate the leak. Be careful for moving parts, and electricity.
It may leak from the pump or from a hose or so.
Jan 15, 2008 | Asko W6441 Front Load Washer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
