Question about Toshiba A75-S125 Satellite Notebook
What steps do I do to find media card once it is inserted into slot?
  • 447 Answers
If you are running Windows a dialog box will probably pop up asking what you wish to do with the new media which has been inserted. It will give you several options including Open Folder To View Files. You can also access the media card thru My Computer as a removable drive - you'll want to note what drive letter is assigned to it for future reference...
Posted on Mar 01, 2009
How to use the card reader emachines EL1333G-03W
Insert your media into the appropriate slot. Open "my computer" and open the media once it is recognized.
Nov 10, 2012 | eMachines EL1333G03w (884483010820) PC...
How can i switch to a memory card?
Most digital cameras use either a secure digital (SD), compact flash (CF), memory stick, multi-media cards or XDcards.
Step 1: Power the camera off and determine what type of card your camera uses. You can check the owners manual, go to the manufacturer's site, or look on the camera to find out what card you use.
This is a picture of an "SD" card in a Digital Camera.
Step 2: Insert the memory card into the camera by locating the memory card slot on the bottom or side of the camera body. Open the memory card door by using an "Eject" button or sliding the panel to the side. Insert the memory card as advised by the icon on the inside of the door. Close the door and turn the camera on.
Step 3: Format the memory card for the camera. Many digital cameras will do this for you once the memory card in inserted and the camera is powered on. On some cameras you can do this manually:
Press your camera's "Menu" button, select "Tools," and find the "Format" feature. Select "Format" and press "OK" or "Set" to format the memory card. Press the shutter button to exit "Menu" mode.
To remove the memory card, open the camera as you were able to in Step 2. Then press the end of the card in and release. The card will slide out of the camera.
Some accessories may be required to transfer media to your computer. There may already be a slot in your computer for the card, if not, an SD to usb kit can be purchased online or from a local electronics vendor for a reasonable price.
May 05, 2011 | Cameras
Even when card is inserted properly it does not show up on the desk top or in 'my computer'
You will need a driver for the hardware to work correctly in order to show up in "my computer" If the card or hardware came with a insallation cd, please insert that disc and install the driver. If it did not come with a driver, then you may need to google it up for a driver, or simply tell us what card you had inserted in. If you are talking about card such as sd card or media card and it did not show up on the computer then 1, your media card is bad, and you will need to test it with another device( such as another computer with the media device slot) to see if it is working. If it is working on another device, we have to assume that your media card slot on your computer is not working. In this case we will assume that the hardware is there, however the media slot driver is not installed, or functionly correctly. You will need to go into device manager via your control panel and scroll and once in your hardware device manager, in your media/ sd device, see if there is any hardware detect, if not, your media device is bad, and it is not working. 2) If it is working, and it is seeing another card if you insert another card, then your card may just need to be formated.
Feb 06, 2011 | Computers & Internet
My playlists on the micro-sd card don't show up on my e250
HI. The best way to isolate the issue here will be to extract the SD card from the e250 and insert it in not your PC SD card slot to(use a usb SD card adapter if you do not have a SD card slot on your CPU) check the integrity of the card. If you are able to retrieve your media off the card while it is inserted in your PC, this will confirm that the card is not the issue and that the actaul culprit will be the program on the e250. In this case, reset your e250 device as stated in your manual y pressing the reset button. Once it is reset; Update your firmware. This should correct the issues.
Aug 22, 2010 | SanDisk Sansa e250 MP3 Player
Can't remove memory card from printer
hi
  • Ensure the MP970 is connected to a working electrical outlet. Turn the printer on by pressing and releasing the power button located on the upper left hand side of the control panel.
  • Step 2 Select the memory card you wish to use. Insert the memory card into an appropriate adapter if it requires one. Open the Card Slot Cover, located on the right hand side of the printer, by pulling the door out and toward the center of the printer.
  • Step 3 Insert the memory card into the appropriate card slot with the label side facing up. Confirm the Access Lamp is lighted. Close the card slot cover.
  • Step 4 Check the "Select and Print" option on the display screen. Select the "Okay" option.
  • Step 5 Load your preferred print media into the printer. Confirm Paper Source, Paper Size and Media type. Select the "Okay" option. Select the "Next" option. Select the "Okay" option to access the images on your memory card.
  • Step 6 Press the Left or Right Arrow buttons to select the image you wish to print. Press the + or – button to determine the number of copies of this image you wish to print. Select the "Okay" option.
  • Step 7 Confirm your print instructions. Select the Print option to being printing your photos.
  • Jul 06, 2010 | Canon PIXMA MP130 All-In-One InkJet...
    How to use a memory stick right from the start
    hi
  • Understand how a Memory Stick Pro works. The small card saves information from a portable device. You can save, delete and rewrite to the card as many times as you want. You can also remove the card and insert it into another device. For example, you can save photos from a camera, then insert the memory card into your laptop to view or download the images.
  • Step 2 Make sure you buy a memory card that matches the demands of your electronic device. The cards have different saving speeds and data-holding capacities. Generally speaking, the more data the card can hold and the faster its speed, the more expensive the memory card. Check your electronic device's product information for recommendations on the best type and size of memory card.
  • Step 3 Insert the Memory Stick Pro into the electronic device. Most devices have a small flap or cover on its side that holds the card. The memory card slides into a slot under the flap. Gently push in the card and close the flap.
  • Step 4 Save to the memory card. Once the card is installed, many devices know to save new data to the card. In some cases, however, you may need to specify where to save files, either to a built-in hard drive or to the memory card.
  • Step 5 To remove the card, open the flap and gently press the card in. The card should then pop out of the slot for easy removal. The card can now be inserted into another device.
  • vote me if your setisfied
    Jun 29, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
    How do i insert my simcard into the nokia 7100 there is no slot?
    Step 1
    Slide the release button,and remove the back cover.
    Step 2
    Remove the battery,and insert the SIM card.
    Step 3
    Insert the battery,and replace the back cover.
    Step 4
    Pull the handle toward the bottom of the phone,and
    remove the SIM card.
    Oct 29, 2009 | Nokia 7100 Cellular Phone
    Phone cannot read or doesn't recognize media card
    It need to be unlocked, enter blackberrymep.com to get MEP2 code (blackberry sim unlock code) .
    Apr 02, 2009 | RIM BlackBerry Bold Smartphone
    Inserting media card into toshiba laptop
    In the card slot if u are inserting a mmc card it will be inserted directly and after inserting u will find a new drive in my computer and on opening that u will be finding the data and to transfer the data directly right click on the data and send to drive name allottedto card reader.
    If u rae using a micro SD card then u will have to use an adaptor which will convert micro sd card to the MMC size.
    Mar 01, 2009 | Toshiba A75-S125 Satellite Notebook
    Memory card
    You should be able to go into My Computer and the memory card will be listed under Drives with Removable Media. MM85
    Jul 27, 2008 | HP Computers & Internet
    Toshiba A75-S125 Satellite Notebook Logo
    32 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
