Question about GE JVM1653 Microwave Oven
Microwave not heating
The microwave seems to be working fine, but when we check the food...still cold. I have checked the power level, but still not luck.
    President:
  • 842 Answers
If the fan is running and the light is on, indicating that there is power to the unit, then there are only 2 likely reasons for this. Either the controller that decides what power to put through has failed, or the magnatron (the thing that creates microwave energy) has failed. SOMETIMES, there is an internal fuse that will blow, but still allow the light to come on and the table to turn etc, My current microwave came from my local dump and when I examined it, there was a spade connector loose on one of the components, I put it back in place and it still works 7 years later. You could take the back off and take a look, but frankly, I would think it unlikely you are going to sort this out. If you do decide to try, the usual rules apply, be sure you can see how it comes apart, work on it UNPLUGGED from the power and make sure that if you put it back together and test it you are happy that you have reassembled it correctly. You really don't want it microwaving YOU instead of your food
Posted on Mar 01, 2009
Everything works fine, except my food is still cold
Check the "power" level setting.
Most microwaves allow adjusting the power level from 1 to 10 (or 10 to 100 on some models). 10 (or 100) is the highest/quickest setting.
I can check mine by entering a time...then before pushing "start"....push the "power" button....and change the level if I want.
Mar 23, 2013 | Microwave Ovens
Microwave oven is not heating food power level can;t be changed at this time
That shows triac semiconductor is working fine, the problem is the magnetron, "heats food" cracked high voltage diode or a shorted high voltage capacitor.
Mar 21, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Mw8992rd seems to be working fine except won't heat food. timer, touch pad, inside light, carousel all work fine. tried different times and power levels but still no heat.
This sounds like a bad magnetron that would have to be replaced. There is up to 2000 volts stored in a microwave, even when unplugged. For saftey reasons I would strongly suggest you have a qualified technician check it out.
Hope this helps.
Aug 24, 2009 | Emerson Microwave Ovens
The microwave stopped heating the food. Power
The light inside the micro wave needs to be replaced most have a door on the back side that yo can remove the screw and unscrew the bulb and take to a applince shop and purchance a new one to replace.
Jul 16, 2009 | Whirlpool GH4155XP Microwave Oven
Kenmore Microwave Won't Heat Food
The service manual is here.
Unless there's a bad connection at a magnetron terminal, I would say you have a failing magnetron.
It is part number 2B71165R and you can get it from the Pros here for $68.59 (subject to change).
For more free DIY and other help & advice, feel free to contact me via my site.
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 15, 2017 | Microwave Ovens
MICROWAVE NOT HEATING
I have the same problem. Everything seems to work except it doesn't heat up food.
I remember last time when it was working. I pressed the start botton before I closed the door. So it didn't start automatically, and I pushed start and it worked(it still heat up the food), but it doesn't work now. Help Please!!!
I have a Whirlpool Gold GH5184XPQ.
Thanks in advance
Aug 27, 2008 | Microwave Ovens
GE JVM1870SF02 - not heating up anything!!
I had the same problem with mine, and discovered, somehow, that when I manually turned on the "vent fan", the microwave worked fine. A bit of a pain, but it heated up the food when it hadn't been prior to the vent fan being on. Can't understand why it solved it, but it's been working like that for about a year now. When I forget to turn on the vent fan though, the food is just as cold as when I put it in.
Jul 28, 2008 | GE XL1800 1100 Watts Microwave Oven
Convection oven problem
Most of the time the magnetron is defective if the food is not heating up.
In some cases there is a defective low power transformer or other componenents associated with the magnetron.
I would suggest to check the owners manual under the warranty section. Sometimes the magnetron has 5 years warranty.
Good Luck.
Feb 15, 2008 | GE JVM1490 Convection/Microwave Oven
Microwave not heating food
check magnetron and related circuit, and control unit and highvoltage section..
Nov 19, 2007 | Microwave Ovens
GE JVM1653 Microwave Oven Logo
108 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
