Wont sew sew heavy kint cuffs
SOURCE: sewing machine motor will not run after attempting
Overload Viking:
The machine has a built in overload protector, if your needle can’t penetrate, it may stop the machine from working for a few minutes. Just wait it will reset automatically. Then, try a Sharp needle (denim needle is ideal) and be sure to Never Never reverse sew on heavy fabric, your needle will bend and hit the needle plate, use the FIX button for knotting (it really does work).
SOURCE: sewing heavy fabric
First thing is pin the heck out of it. I would not use a needle bigger than a 16. Set the tension midway and then just tweak it one way then the other to get a smooth stitch. And for your thread, just use polywrapped cotton thread and you should be fine.
SOURCE: fabric wont glide threw while sewing
Check your feed dogs below....maybe they have been lowered.
Kim
SOURCE: I am sewing upholstry fabric together in a pillow
Hi. Unthread and rethread everything, clean out any lint, and oil the
machine. This, plus using the right size needle (size 16 or higher) and thread (heavy duty), should do
the trick.
Let me know if this solves the problem, ok?
Sorry could you please explain your sewing machine problem,so that I can help you.
thanks!
