Question about Honeywell Programmable Thermostat Heater
Hot Water is not comming
My System is not working properly, when I switch it on no hot water come but heating started even I don't switch on the heating, I tried it hard to switch off the heating, move the thermostat to zero but still the same problem i-e Heating remain ON and Hot Water is not coming.
  • 27 Answers
REPLACE THE CIRCULATOR PUMP ON THE SYSTEM.IT IS NOT PUMPING THE WATER.
Posted on Mar 07, 2009
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Want to shut off my hotwater heater and still run my boilerhave base board heat
Turn off water but leave heat on - Possible? - Handyman WIRE ...
handymanwire.com > ... > Heating and Air Conditioning
Jan 14, 2003 - 10 posts
My hot water baseboard heating system is a closed system. ... Could I shut off the main water and leave the boiler and heat going for ... If one is not installed, install one and rely on that to save the boiler from the damage of running out of ... I do not wantto have city water push my antifreeze out of the system ...
What's the best temperature to set my hot water baseboard ...
greenhomeguide.com/.../whats-the-best-temperature-to-set-my-hot-water...
Nov 21, 2010 - With hot water baseboard heating, is it better to keep the heat at 60+ degrees ... a hot water heating system where water is heated in a hot water boiler and then ... by setting the thermostat to lower the heat when you don't need it on. ... Not only do I turn my heat down when I leave for work in the am but also ...
Jan 17, 2016 | Water Heaters
How do I fix central heating
The first thing you need to substantiate is the fact that there is enough water in the system. It will be a closed loop system requiring approximately 10 psi/ floor. (Only a rule of thumb). Usually when one protion of the system works and the other does not, it is an issue of water quantity available to circulate through the combination of loops. If you have to add water, you will probably have to purge air from the highest points in the system. Even if there is an "Airtrol" fitted in the bottom of the expansion tank, bleeding the high points will eliminate air quicker.
The hot water portion of the loop should only be going through a heat exchanger that transfers the loop temp to the domestic water circuit and the three way valve is probably a 'mixing valve' utilized to maintain a certain loop temperature on the primary loop.
Dec 01, 2014 | Honeywell Heating & Cooling
Heated air still comes out of my vents even when the air is off
You might have a faulty water valve. The hot air in the car is supplied by the engine cooling system. As the engine works, it heats up and water is circulated through the system and kept at a cooling level by the radiator. However, this water is still hot, and by turning on the heat in the car, a valve is opened that allows the hot water to circulate through the heater core inside the car.
This core is in fact just a mini radiator, and air from the blower fan inside the car blows air through this mini radiator, thus supplying hot air in the car.
If you don't want hot air in the car, the heater control operates a valve that shuts off the hot water from the engine. If this valve is faulty, it will allow hot water to circulate through the system. Another possibility is that the cable operating the water valve might be maladjusted or the cable or the lever operating the cable is broken or faulty. It often happens that the outer part of the cables slip and the controls operate so-so but never well.
If the cables to the dashboard controls are not adjusted properly or have started slipping, it could also cause the fresh air vent to not close properly, and this will cause a flow of air even when the controls and the fan are turned to the off position.
You can remove the control panel from the dash and check the cables and controls, but it is a finicky job. Maybe you want to take the car to a mechanic?
Mar 29, 2014 | 2001 Nissan Sentra
Elite 50 boiler
There should be a pressure drain to purge out all the air. Sound like there is an air bubble in the system somewhere.
Jun 03, 2013 | Water Heaters
Vaillant boiler no heating or hot water
refere to manual check for override switch loss of pressure no problem re-pressurise and check for leak top of rad valve good place to start
Oct 10, 2009 | Water Heaters
Asko dishwasher d3530. The water in the dishwasher is not hot.
Generally speaking, dishwashers don't heat cold water on their own. Be sure the dishwasher is connected to a hot water supply and that hot water is available to the dishwasher at the START of the cycle.
Often it takes hot water several seconds for house plumbing to deliver hot water to an outlet. If the dishwasher is connected to the kitchen hot water supply, run the water in the sink until the water runs hot before you start the dishwasher.
Dishwashers often have heaters to heat the water even hotter than most home water heaters, but they are not intended to heat cool or cold water. You MUST furnish hot water to the dishwasher from the time the cycle is started.
I've seen houses that take so long for hot water to reach a faucet, the dishwasher is already full (of cold water) before the first drop of hot water reaches it.
Good luck. Hope this helps.
Sep 11, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
When the engine is hot the check engine light came on and the fan (is ok ) don't start
Hi:
How hot is it getting? Is it running hot? Is there water in it or is there a water leak? You may even have a stuck thermostat. How many fans does it have? What makes you think that the fan is working properly I mean if the air conditioner is on when it's running the fan (s) will run automatically, make sure the air isn't on when trying to see if the fan is working properly while the engine is running. Those fans comes on by use of a mercury thermal switch that is mounted in the water jacket in some cars. If the fan is workinf properly and the engine is overheating then it could be something as simple as very low water in the cooling system, if it's full and the fan is working properly you may have a bad thermostat.
Hope helpful
Don
dwhitehead4062@verizon.net
May 02, 2009 | 1995 Ford Escort
GE Dishwasher SSD3900J00ww wash water cool heating element hot on
Crew that installed new cabinets and sink hooked dishwasher to cold water line I switch it works fine now. Thanks Don
Mar 20, 2009 | GE Dishwashers
No hot water when washing dishes
sounds like it was hooked up to a coldwater line instead of a hot and your heating element in the dishwasher went bad from overload or your pc board went bad but i would check to see if it is hooked up to hot water line first..
Jun 29, 2007 | Kenmore 16483 Built-in Dishwasher
Heating & Cooling Logo
133 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
