Used it one day & OK next day nothing, changed fuse in plug still did'nt work & nothing on display works, belt turns easily, cant see anything obvious on control board. It is blowing fuse where power plug socket is.
any help appriciated
There are generally two control boards, I am assuming you looked at the lower one. I would first disconnect the power leads at the board and see if it still blows the circuit breaker (fuse?). If it does the check wiring for short. If OK then reconnect power leads and then disconnect all other wires (plug-ins) to the board and try again, each time plug a connection in and retry. (remember to disconnect power each time). I have a feeling the smoke got let out of this lower board and may need replacement. hope this helps
www.twincityrepair.com
The motor quit working. the panel lights up,the incline works. I replaced the fuse and as so as I plugged it in the fuse blew. Thhe way the fuse blew acted like a short.
