Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Icemaker not making ice
Water
  • Anonymous Mar 31, 2009
    In my case when I stick my fingers in the ice making unit I can feel the cubes but they are not being pushed out into the dispense.
    Bob
    Williamsburgr
    Genius:
  • 1,122 Answers
STICK YOUR FINGERS IN THE ICE MAKER WELL TO SEE IF THERE IS ANY WATER,IF THERE IS THEN THE ICE MAKER IS BAD AND YOU NEED TO REPLACE IT(VERY EASY TO DO)MIKE
Posted on Mar 02, 2009
U-Line Icemaker is cold, but no water in resesrvoir for the ice.
Your water valve may hay a drip like a faucet. Causing the spout to freeze up.
Jul 08, 2012 | U-Line Icemaker
Ice maker not making ice, but water dispenser working, just changed filter
If you changed the filter than water may not have made it to the icemaker yet. If you have givin it 24hrs than check these.
There are only 3 things that will prevent an icemaker from not making ice.
1) Temperature in freezer. Most icemakers require that the temp in the freezer is at a minium of 6 degrees. If the thermostat in the icemaker is not reading this temp or below it will not let the icemaker call for water to make ice.
2) Icemaker. Is the arm on the icemaker in the correct position. Most models the arm should be down to operate and up to be off. Faulty icemaker. The internal components of the icemaker may have went out.
3) Water inlet valve. If the silinoid for the icemaker on the inlet valve is stuck it will not allow water to the icemaker. Over time inlet valves wear out.
Troubleshooting- Check the temp in freezer. If not 6 degrees or below you have another problem with your freezer. If at 6 degrees or below and you have ice and water through door unplug fridge, switch the two hoses from the inlet valve (NOT Possible on all inlets so check to make sure you can remove the hoses by pushing in on the cylinder that hose feeds into and pulling hose out) Switch the hoses than press the water through door feature. If you get water inlet valve is good. If you dont have ice and water though door than have your inlet valve tested. If inlet is good and temp is good replace icemaker. If you have any questions or need further assistance please respond. Thank you
Aug 01, 2011 | Whirlpool Refrigerators
Ice cube maker not making ice
feel with your finger on the inside of the icemaker to see if you have water or if there is the presence of ice if you have water or ice on the inside of the ice maker then replace the icemaker if you dont have water or ice then check the valve in the rear of the machine to see if your getting water to the icemaker
Apr 29, 2010 | Maytag MFI2568AE Side by Side French Door...
No Ice is being made
Ice maker solenoid ...side..water side ok replace
Aug 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker wont make ice
Put about 1/2 cup of water into icemaker . If it freezes and dumps , replace the water inlet valve . If the ice stays in the icemaker , replace the icemaker . Also , make sure the fill tube to icemaker is clear of ice and the coils under refrig are clean of dust , lint , etc..
Aug 12, 2009 | Roper Refrigerators
No water inside ice maker tray
Pour about 1/2 cup of water into icemaker . If it makes ice and dumps , replace the water valve . If ice stats in the tray , replace the icemaker . Also , check the hose going into the icemaker , to make sure it isn't frozen . If it is , replace the water valve . And , make sure the coils are clean of dust , lint , etc ...An icemaker has to be 5 degrees to dump and dirty coils will raise the temp above 5 degrees .
Aug 09, 2009 | Refrigerators
Ice maker does not work
Make sure fill tube is clear . Pour about 1/2 cup of water into icemaker . If ice dumps but no water into icemaker , replace water inlet valve . If water stays in icemaker , never dumps , replace icemaker . Make sure the coils are clean of dust , lint ,etc...
Aug 05, 2009 | GE Refrigerators
Icemaker doesn't work
chack water valve and make sure it is getting water if so and there is ice in ice maker then your heater is bad and not releaseing ice
Jul 08, 2009 | Whirlpool GS6NBEXR Side by Side...
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Ice machine not making ice
Hi, everak11,
Three possible solutions for you.
1: No water coming in from inlet valve. Check voltage on inlet if you have voltage and no water then replace valve.
2:Icemaker not cycleing. Lift the arm on the icemaker to shut it off and leave it for about an hour. Come back in and turn the icemake back on by lowering the arm. If the icemaker does not begin a new cycle and the arm start rising then the problem is most likely an icemaker. Replace Icemaker
3:Refrigerator not cold enough. If the freezer is not getting cold enough the icemaker will not cycle. Check the temperature in the freezer and make sure it is getting down to 0 degrees. If not then you may have another problem with your refrigerator. I hope this helps you, Let me know if you have any other questions or symptoms. Mike
May 08, 2008 | Refrigerators
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
74 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
