Question about Bosch Washing Machines
I keep getting error message F04 on my BOSCH exxcel 1400 express washing machine. What does this message mean and how can I fix it?
  1. Loose debris blockin pump - Clean drain pump on the bottom of the machine,
  2. Drainage pipe and or drainage hose blocked - I would like help on this as well.
Posted on Sep 20, 2010
Bosch exxcel 1200 express fault code f04 what is it
i had this problem,no drain or spin,opened the flap at bottom right hand corner and pulled out small hose to drain machine opened circular filter cover (some water may come out) and found a 5p and 1p blocking filter after removing ,machine worked fine.
hope this helps
Apr 02, 2010 | Bosch Exxcel WFX 2467 Front Load Washer
I have a bosch washing machine make is a exxcel 1200 express and it stops working in the middle of a cycle and the words f04 come up wot does that mean please
there may be a stuck in cycle of rotating knob kindly rotate the knob more than three times your problem will be sloved otherwise replce the mechanism
Dec 23, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Have a Bosch Exxcel - error code F04 comes up half way through cycle - cleaned filter...still not resolved. Any ideas?
washing machin pipes were frozen in garage, defrosted now. done one wash half way through, error f04 came up. water still in machine and it makes a noise when trying to spin. The fillter knob has broken and i can't undo it to clean it out.
Oct 15, 2009 | Bosch Exxcel WFO 2264 Front Load Washer
F04 error message on a bosch exxcel 1400 washing machine, then the water wont drain away
This error indicates an obstruction in the water pump. . Tip machine back so you can fit a bowl under the bottom right hand side. Flip back cover at bottom right to reveal pump filter access - unscrew (quite a bit of water comes out so have the bowl ready).
Sep 26, 2009 | Washing Machines
USER MANUAL FOR BOSCH EXXCEL 1400 EXPRESS WASHING MACHINE
just go a bosch washing machine exxcel 14 express cant get it to work can anyone help i dont have the user book my email is sironsheik@hotmail.com
Apr 01, 2009 | Bosch Exxcel WFX 145S Front Load Washer
need more info what point in the wash does it start to display the code
Sep 06, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Bosch 1400 exxcel
The machine thinks the drain is blocked.. check the pump and outlet pipe for buildup of dirt.
I noticed holding start down for several seconds whilst powering the machine on, then turning it off / then on again would clear the machine's idea of where it was during a program. Does this affect the error code you're seeing?
May 26, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Washing Machine Will Not Drain
you have got a blocked filter or pump the filter is located on the right hand side at the front of the machine down the bottom behind the plinth you can drain the water from there as well by pulling the small grey hose out pull the plug out of the end and place in a small bowl good luck when the water is out you can check the pump impeler as well clean the filter houseing and put it back all should b well unplug the machine b4 u start work
Sep 02, 2007 | Washing Machines
Bosch Exxcel WFX2467
try removing power from unit and re-applying about 15 minutes later
May 13, 2007 | Bosch Exxcel WFX 2467 Front Load Washer
Washing Machines Logo
832 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
