SOURCE: Oil leak in head gasket
U have the engine steam cleaned of all oil and grease and then u just keep an eye on the suspected leak area.
SOURCE: Oil leaking into coolant -- not head gasket
check the transmission condenser or oil cooler built in the radiator..
SOURCE: 1984 F150 302 Had oil pan gasket and both valve cover gaskets
If you have oil coming down between the transmission and the engine where they meet your problem is with the rear main seal. It seals the back of the crankshaft so no oil comes out. Over time it tends to leak especially if the oil changes haven't been done on time or you live on dirt roads. Where the transmission and engine meet there should be a metal shield but it may be already removed. Just pry that back and see if there is oil. Depending on the color tells your rear main seal for the engine or the front seal on the transmission. Hope that helps.
SOURCE: On my 2006 Monte Carlo
bad
gaskt probabley but grab the front shsft and wiggle it any play and its shot careful hot replace anyway too much labor to do twice
SOURCE: We change the oil pan
If it is the 3.0 you may have heard the lifters. but sometime when you leave an oil pan off for very long you will lose your prime from your oil pump and it will take an few sec to get primed. how long did you let it run for. did the the knocking go away
dennis
If you need further help, reach me via phone at https://www.6ya.com/expert/dennis_f849d3d6a68c6430
Testimonial: "It was very helpful, however we need to know how can we illiminate the noise,what can we do to fix this"
http://schematicsdiagram.blogspot.com/2011/12/location-of-head-gasket-on-1994-grand.html
HOW TO REPLACE A HEAD GASKET
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-head-gasket.html
How
to replace Exhaust Manifold?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-exhaust-manifold-on.html
How
to replace Intake Manifold?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-intake-manifold-on-acura.html
How
to replace Cylinder Head ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-cylinder-head-on-acura.html
Is it Easy to replace head
gasket?
http://schematicsdiagram.blogspot.com/2011/12/is-it-easy-to-replace-head-gasket-on.html
Should I only replace head
gaskets or complete head gasket assembly?
http://schematicsdiagram.blogspot.com/2011/12/should-i-only-replace-head-gaskets-or.html
-----------FOR oil leak issue check the following help links:---Common Causes of Car Oil
Leaks?
http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html
--------Troubleshoot Car Oil leak?
http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html
---------Car oil leak?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leak.html
Car oil leaks from valve
cover gasket?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
---------This will help.Thanks.
For leaking head gasket it has to be replaced.For head gasket leaking and other troubleshooting,there are help links provided.Its suggested to click the link below and go through the troubleshooting procedure to confirm the issue :-----Leaking head gaskets? http://schematicsdiagram.blogspot.com/2011/12/leaking-head-gaskets.html
-----------Water in engine oil? http://schematicsdiagram.blogspot.com/2011/12/water-in-engine-oil.html
-----------How to replace head gasket on car?http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-head-gasket-on-1994.html-------------How to know what is faulty Cylinder head or Head gasket?http://schematicsdiagram.blogspot.com/2011/12/how-to-know-what-is-faulty-cylinder.html
-------------- Can I just replace Head Gasket on 1991 Buick Century?http://schematicsdiagram.blogspot.com/2011/12/can-i-just-replace-head-gasket-on-1991.html Location of Head Gasket ?
How to replace Exhaust Manifold?
How to replace Intake Manifold?
How to replace Cylinder Head ?
Is it Easy to replace head gasket?
Should I only replace head gaskets or complete head gasket assembly?http://schematicsdiagram.blogspot.com/2011/12/should-i-only-replace-head-gaskets-or.html
-----------FOR oil leak issue check the following help links:---Common Causes of Car Oil Leaks? http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html --------Troubleshoot Car Oil leak?http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html
Car oil leaks from valve cover gasket?http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
