Question about Ovens
Oven Type FCSM6 gives STOP non the display; the
Oven Type FCSM6 gives STOP on the display; the knobs give no reaction; what to do? greetings: Ton van Beek
2 Suggested Answers
  • 160 Answers
SOURCE: stainless steel single oven type FCSM6
If the fan is still operating then its the Element that needs replacing..
Posted on Dec 21, 2009
Beko built in double oven alarm after power outage
Switch oven on using the function knob (first knob on left hand side)then press and hold(for 3 to 5 seconds) the left top button right next to the display screen this should give you a chance to set the current time on the oven after setting the current time switch oven off at function knob and on agian problem should be solved
Jul 05, 2015 | Ovens
Hi, My oven has been beeping a F10 error code for some time now, and I would like to know how I can fix this problem?
This is from Frigidaire website
These codes mean that the oven's electronic control has detected a condition it needs to check. When you see a code, follow these steps:
  • Press STOP/CLEAR to clear the display and stop the beeping.
  • Reprogram the oven.
  • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes to turn it back on.
If the code is still displayed after you've followed these steps, contact your local authorized service provider.
That is the best answer I can give. I hope it helps. I don't know what the code is, but it only gives this answer.
Joe
Aug 30, 2011 | Frigidaire FGB24L2A Gas Single Oven
I have a Fridgidaire Galaxy Oven,can you tell me how do I set the self cleaning oven?
Greetings,
I can't locate your model number, but, if you have the one with an electronic control..just put it to clean and maybe set the clean time and it should start the cycle and lock the door by itself and start cleaning.
if it has knobs for selector, and a knob for oven thremostat and a clock with two or three knobs.
put the selector on clean, put the thermostat on clean and then go to clock and set the stop time three hours past the time thats showing on your clock(providing its keeping time) and lock your oven door and it should start.....Bruce Denton
Dec 13, 2010 | Frigidaire FFEW2725LB Oven
My oven display dosent work nor the oven itself it justs beeps and then nothing
greetings,
The membrane or main board has failed most likely. the display itself is built in the board...the beep usually follows some sort of fault code...its possible your having a voltage problem, like a burnt wire on L1 or L2 at the junction box or inside the oven itself. This is not easy to trouble shoot with limited info, but hope this gives you a general idea of what to look for...Bruce Denton
Dec 13, 2010 | Whirlpool RBD275PD Electric Double Oven
Stainless steel single oven type FCSM6 no.387(electric) not heating stopped in middle of cooking
Dec 21, 2009 | Whirlpool Ovens
I have just moved into our new home with a Westinghouse wall oven. The previous owners have scrubbed the model number paper tag off so I can't give you that details. The left knob is labelled Function the...
Go online and type in westinghouse ovens/stoves that looks similar to yours and look for one with dig readout. Then type in that model # then manual on a Google search and see what pops up. I'm sure that most if not all of them are then same for setting time..
Oct 06, 2009 | Ovens
My whirpool oven display reads stop, how do i turn it off?
Hi
This "STOP" message appears when either the cooker has been switched off at the mains or there has been a power cut. What you have to do is a s follows:
1. The knob on the left should be turned anti-clockwise ONE click only.
2. Press the button between the two knobs (under the display) ONCE only. You will now have got rid of the word "STOP" and it will be replaced by _ _ . _ _ symbols.
3. Press the same button twice more or until "12.00" is shown. This is the 24hr clock and can the be adjusted up or down by turning the right hand knob clockwise or anti-clockwise. Its always recomended that you set the clock before useing the oven although you dont have to.
4. Now you can operate the oven as normal.....Good luck with that!
Regards Ian W.
Jul 31, 2008 | Whirlpool AKZ159IX Oven
Whirlpool wall oven error code
f3 generally relates to faulty oven sensor. thin rod in upper left hand corner of oven cavity held in by 2 screwa, easy enough to replace,
Feb 20, 2008 | Ovens
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
Ovens Logo
304 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
