Question about Gateway Profile 4 All In One (MPN PROFILE4SE) PC Desktop
Profile 4 My monitor will not turn on.  I see the gateway screen but then it turns black.  What do you think i should do? Thanks, Frank
    President:
  • 2,692 Answers
Download some free hard drive testing software, like seagate tools,from:  Seagate.com  or another had drive manufactor. They run from a disk w/o windows . If the hard drive checks out try reinstalling the system. Another quick test , for conformation is to hook up you monitor to anther computer just to make sure it is not the monitor. It rarely is.
Posted on Mar 01, 2009
My monitor does not turn on and the power button light keeps blinking
elvisy71, If different monitor will display the Win-desktop screen with no problem, then Gateway 2275w will need you or qualified electronics technician to possibly repair a defective internal "switch-mode-power-supply" / CCFL inverter supply" !! Check the status of unit warranty first, and check to see if Gateway has a swap-out (exchange+cash) program. If that dosen't work you will be doing a lot of reading about DIY lcd monitor fixes. You will also need to view some DIY video clips at YOUTUBE on "lcd monitor disassembly" and "lcd monitor repair" that will help you decide what to do about your now BLACK or BLANK n BLACK screen unit. You can find tons of DIY stuff here on fixya in my and other CCFL back-lit lcd monitor tech's fixya profiles. Elvis, remember this! Your 2275w isn't any different than any other brand of ccfl back-lit lcd display in it's basic design and operation and some can be DIY repaired for under $6 in parts cost. Just do some reading of the higher numbered (>16) pages in my fixya profile and my old profile "louie12fix" and follow the web links you find there. If this was of some help to you please come back to fixya and rate this response and tell me and all the other black screen lcd owners what you are planning to do about your monitor. 12fixlouie 42610
Apr 26, 2010 | Gateway FPD2275W LCD Monitor
My monitor show me bright for 4 sec only
morinj_04, "Switch-mode-power-supply" going into partial shutdown mode. Read more of my BLACK screen and BLACK and BLANK screen responses in my profile. You will get the hint as to what to do!!!
12fixlouie
Jan 30, 2010 | ViewSonic VX715 17" LCD Monitor
Turn on computer and Acer Monitor ( AL1913) and nothing but black screen. Know the computer is good as I hooked another monitor to it and worked fine. Frank
fbwhite, Was your screen also BLANK, along with it being BLACK? The flashlight test would have told you! Yes, it could be both, or just BLACK. Read my FIXYA profile and that of other FIXYA tech's (budmrtn and buddymc) and it will become crystal clear to you the problem your monitor has and the options you have open to you. Good luck with the repair. 12fixlouie
Jan 30, 2010 | Acer AL1913 19" LCD Monitor
Washed out monitor when viewing most web pages
exchange your dell monitor to gateway monitor.If the monitor from dell showed the same problem when you connect it to gateway. you must install video card driver. and if the monitor from gateway showed the same problem when you connect it to dell adjust your contrast to full and the brightness to 50% and adjust the colors to 100%
May 13, 2009 | Gateway Profile 5 PC Desktop
Gateway screen not responding
Try Pushing together the body of monitor in middle top areaWhere the Word gateway is Imprinted ,Loose connection on ribbion probably,on mine ,but I think I got LUCKY here honestly,
Just try it before disassembly
Apr 11, 2009 | Gateway FPD2275W LCD Monitor
When turn on the gateway screen apear, but the monitor turn off or black and not apear nothing my computer is gateway profile 4 all in one
Your power settings may need to be changed, it appears to be going into sleep mode or power saving mode.
If you are using Vista, Click Start> Control Panel > Power Options > "choose when to turn off display" (in the left hand pane) and check that it says at least 10 minutes. Click apply and then ok.
Alternatively, right click on your desktop, select "personalise" and click on screen saver - then select "change power settings" to bring you to the same thing.
If you have xp, right click on your desktop and select "properties" then "screensaver| > "Power" and change it to turn off the monitor after 10 minutes. Click apply then ok.
If your monitor is going to sleep, either press a key or wiggle the mouse to wake it up.
Mar 13, 2009 | Gateway Profile 4 All In One (MPN...
Gateway profile 4 all in one computer
Before you buy anything else try it with another monitor. Obviously if the other monitor works then its not your motherboard its your monitor. Update video drivers to ensure you have the latest.
Rate 4 diamonds.
Mar 02, 2009 | Gateway Profile 4 All In One (MPN...
LG LM190E05 (SL)(01)
Gateway has multiple part numbers for the LCD inverter board. Part numbers V01216400103, V01216400104, and V01216400105 are for the Profile 5 and 5.5 series with a 15" monitor. Part number V01316500104 and maybe others are installed in Profile 5 and 5.5 with 17" and 19" monitors. Also the LG part number for the 19" monitor provided in Gateway literature is LM190E02-A4. There is no mention of the LM190E05 SL in the product specs I have seen. Gateway does make special purpose runs and does change components without much much notice though. The definitive source of exact information is Gateway Tech Support. It may cost you a couple of bucks to get answers, but the value added to your system with a 19" vs. 15" screen to say nothing of the viewing comfort should far outweigh the cost of accurate information. Good luck with your upgrade. Please keep me posted on whatever you try be it successful or not. I too have a Profile 5.5 with 15" and have been considering the larger screen upgrade. BillyB.
Oct 07, 2006 | Acer AL1916S (Silver, Black) (Black,...
Screen lit up, but nothing displayed (black)
Hello Frank, I have the same problem with my monitor. I don?t have the answer yet to resolve the problem. if you want the first of us who find the resolution will advise the other. I sent an email to Xerox to get the info to remove the cover without breaking it. regards Sylvain
Sep 01, 2006 | Xerox XG-91D 19" LCD Monitor
Gateway Profile 4 All In One (MPN PROFILE4SE) PC Desktop Logo
161 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
