You can try QI wireless car charging doc,i am using one doc.It's really good and i just place my phone into the holder.It's charge automatically and i can receive any call while charging my phone.You can collect the charging doc from amazon store.CHOE wireless charger i am using. you can try it. Thanks. QI wireless car charger doc for mobile phones
Check
the USB cable for damage and dirt, especially at the ends. Then try
using the wall charger, as this will provide greater power input than
the computer/USB.
Broken charger or USB cord
Try using different chargers to see if you may have a problem with your charger or cord.
Obstructed/bad dock connector
Inspect
the 30-pin dock connector at the bottom of the iPhone for dirt, lint,
and damaged pins. Clean out the dock connector very carefully with a
tooth pick or soft toothbrush. If the dock connector is broken, you will
have to replace it.
I had the same issue. I tried opening the dock and could not find anything wrong. It seems the charger was delivering sufficient voltage. So I disconnected power to the charger and reconnected couple of times and it started working again. My charger has a LED light and based on the brightness of the light you can findout if the output voltage is close to 20 volts.
This happened to me earlier this year. I took it to At&t and they couldn't find anything wrong with my phone. So they gave me a brand new one. I've had it for about the same amount of time and it is doing it again. I'm not sure what to do. Considering i'm not with at&t anymore, they probably wont do anything.
The charging procedure varies from camera to camera. Some cameras charge the battery by plugging the camera into a wall outlet. Some do it by connecting the camera to a powered USB outlet. Some cameras come with a separate battery charger. Some cameras come with a charging dock. Some cameras don't charge at all, using standard batteries which can be charged using a standard charger.
If you need more specific information, please reply to this post and specify the make and model of your camera.
