Question about Dell E173FPb 17" TFT LCD Monitor
Dell Monitor 1907FPt comes on for a short time and goes to a black screen. Power light is still on. How do I fix this?
  • omiesteve Mar 12, 2009
    I found a website lcdrepairs.com They sell the inverter board for the dell 1907 FPt monitor. It cost me $49.95 + Shipping. If they don't have your inverter board they will rebuild yours.
    omiesteve
  • Mark Hughes
    Mark Hughes May 20, 2009
    Comes on for a short while then goes blank, unplug the power and try again - same happens.
    I have the same fault on 2 monitors.
HI
YOUR PROBLEM IS NOT INVERTER BOARD IT IS MOST LIKELY THE LAMPS, ANY 19" LCD LAMP THAT FITS WILL FIX IT FOR YOU.
THANKS
AHMAD
Posted on Jul 06, 2009
LCD monitor turns off
I have had the same problem as others seem to have had with the dell flat panel. After leaving the screen on for some time, the monitor brightens for a moment, then goes black, while the green light stays on. When I reboot, it works again for some time, or if I remove the cable for a few minutes and plug it back in (with monitor turned off) it will come back on...only to repeat the black screen. I have changed the power features, screen resolution, downloaded updated drivers from dell, and viewed dells troubleshooting advice on the monitor cd that came with the computer. Nothing directly advises on this problem, but I have read here and in other online message boards the exact same problem. Anyone able to fix this?
Nov 02, 2012 | Computers & Internet
My monitor keeps shuttinhg off how do I fix it
Common problem for E172/173 are shorted out inverter transformers driver transistors (4) C5706/5707 in the inverter circuits.
Jan 28, 2010 | Dell E173FP 17" LCD Monitor
Problems with Dell E153FP 15" LCD Monitor goes out to black green light flickers.....If i hit it a few times or more the screen on the pedestral come times that works too. No loss wire connection
Check 4 transistors (c5706/5707) for shorts in the inverter transformer driving circuits, this is a common failure. A lot of solder joints will also need to be resoldered. Check for bad capacitors also.
Dec 18, 2009 | Dell E153FP 15" LCD Monitor
Dell E171FP Monitor goes black after 2 secs
Hi, I don't think the problem is with your monitor. Your monitor sounds like it's doing exactly what it's supposed to do. The monitor is supposed to turn off if there's no cable attached, which means there's no signal input. When the screen goes black, does the power light stay on and turn orange? or does it go off as well? I would recommend that you lower your screen resolution to 1280x1024 or lower in the Display Properties window, then remove your primary monitor, and connect the monitor to your desktop computer. You should see it light up when connected. The monitor auto-senses when there's a computer attached to the cable and when there's a signal. If it doesn't see a signal, it goes black to save power.
Jun 17, 2009 | Dell E171FP 17" Flat Panel LCD Monitor
Dell 1907FPt picture appears for three seconds, then off, LED power remains
I have the same problem. I talked to a few people and it is believed that the condition has been caused by a power surge.
My monitor is out of warranty, so I intend to open it up to check the fuse(s).
I will post result of that soon.
Aug 21, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Monitor shuts off but green light stays on
I perhaps can. I would think inverter or ccfl's.
Jun 12, 2008 | Dell UltraSharp 2407WFP 24" LCD Monitor
Problem with dell lcd monitor
Frt. Power button control board shorted. Part# 715L1153-1A
Apr 29, 2008 | Dell E173FP 17" LCD Monitor
Dell 1907FPT lcd monitor
Could be the power supply. Get one at www.partstore.com. I've had very good luck with them fixing various LCD monitors.
Jan 08, 2008 | Dell E173FP 17" LCD Monitor
Dell E173FPb 17" TFT LCD Monitor Logo
976 people viewed this question
Alun Cox
