Home | Sampo | PME-42S6 42 in. HDTV-Ready Plasma Television | Sampo PME-42S lost hea...
Sampo PME-42S6 42 in. HDTV-Ready Plasma Television
Problem for Sampo PME-42S6 42 in. HDTV-Ready Plasma Television
Sampo PME-42S lost heat coating
By jmartin12 on Mar 01, 2009
I bought my unit many years ago (early adopter) without the optional tuner. It has always worked very well. I like it because of all the different types of connectors and I use it as monitor with a multimedia computer. Recently, it has developed a problem: The cleaning ladies apparently used some cleaner on the screen that stripped a very thin coating from the glass that apparently was there to dissipate the heat coming from the screen. After a few minutes being on, the set starts to pixalate and it looks as if the the colors are misaligned vertically. First, you see a yellow fringe around objects, then a pinkish ghost to the right of the yellow. After a while, the picture is unwatchable. If I stick a fan to blow on the screen, the problem will not happen. Is there some sort of repair for this, possibly re-spraying a new coating? I don't know if this is related, but when I call the menu, it jumps around (flickers) so much I can barely read it. Has anyone experienced the same problem? Thanks. jmartin12
Popular Solutions for Sampo PME-42S6 42 in.
Questions and Unsolved Problems for Sampo PME-42S6 42 in.
Do you recommend Sampo PME-42S6 42 in. HDTV-Ready Plasma Television?
Answer
Answer
my sampo PME-42S6 ha trouble powering on. It will start (blue screen and hour glass appear the turns... (More)
Answer
we have had our tv 4 about 7 years and over the past few months it has been going red! basically if... (More)
Answer
The T.V has all sorts of pink lines and other distortions on the screen if you hit the side of it,... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sampo PME-42S6 42 in....:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 1454
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
