Question about Garmin n?vi 260W GPS
Resetting garmin 260w. Did a hard reset and the screen is still frozen. Any suggestions to fix problem.
5 Suggested Answers
HarryHarley
  • 343 Answers
SOURCE: Need to do a factory reset
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To perform a Master Reset on the nuvi 200, 205, 465, 500, 600, 700, 705, 1200,1300,1400 or 1600 series device: Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Follow the on screen prompts then place your device in an area with a clear view of the sky until it acquires satellites.
Posted on Jan 17, 2010
SOURCE: reset 255 loader loading frozen
Press the reset button - you'll find it on the lower right of the Nüvi 255, but it doesn't look like a button. It's basically the sticker with all the information on it. It's just enough to push the sticker carefully with something small, not too sharp so it doesn' get destroyed. The Nüvi reboots, the loader loads and proceeds with the software load. Once this is over, shut down the Nüvi and reconnect to the PC. Then, everything works fine (it did at least for me).
Posted on Feb 27, 2009
  • 4090 Answers
SOURCE: how do I reset the password on my Garmin Nuvi
Take it back to the exact place where the password was set. Once the GPS is at the coordinates it will let you change the PW. This is an anti theft security and cannot be over ridden.
Please rate my help++++Thanks for using FIXYA
Posted on Jun 11, 2010
Testimonial: "thanks"
SOURCE: My Garmin Nuvi 660 touch screen is frozen. I've
Sounds like your firmware needs updated. Just go to Garmin’s website then downloads and update your firmware. As long as there is no screen damage but just touch screen not working that will fix it. An easy test is to take out the battery and if the unit works for second then freezes you just need to update firmware. Turn off unit plug into computer via usb cable and do firmware update, that easy!!!! Hope that helps?
Posted on Aug 22, 2010
Garmin nuvi 50lm only shows garmin screen and just a bit of green on the bottom. sometimes it shows the green register bar all the way accross
Garmin nuvi 50LM Boot problem ' POI Factory
www.poi-factory.com > Garmin talk
Aug 11, 2012 - Why won't my nuvi 30, 40, or 50 go past the Garmin logo screen when I turn it on? .... Just wanted to say thanks to Muell9K for the hard reset solution. ... get the Nuvi to start up with the screen that shows the picture of a Garmin ...
Crap... White Screen (nuvi 350)
May 11, 2008
garmin frozen?? (how do I reset?)
May 11, 2008
More results from www.poi-factory.com
How to Reset the Garmin nuvi 30, 40 and 50 with GPS City ...
? 0:51
https://www.youtube.com/watch?v=mujdSP-fM98
Jul 31, 2012 - Uploaded by GPSCity
In this video learn how to RESET the Garmin nuvi 30, 40, and 50GPS back to factory default settings. Back up all ... With the GPS unit off, press the bottom right hand corner of the screen. Turn the unit ... Show more. Show less.
Jan 05, 2016 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
My 260w has a screen lock and it has no reset button! what's the fix?
To reset the Garmin satnav you power on while holding the bottom right corner of the screen until it asks if you want to reset it.
Jun 12, 2011 | Garmin nuvi 260W GPS Receiver
Have Garmin Nvui 260w that has lost it maps. earlier purchased mapdates and hasn'b been the same. shows Garmin and computer on sceen.
GO INTO SETTINGS
THEN MAPS
THEN MAP INFO ,
MAKE SURE THE "TICK" IS IN THE BOX OF THE MAPS YOU WANT TO USE
IF THAT FAIL'S THE THE DOWNLOAD DID NOT TAKE, IF SHOWING COMPUTOR ON SCREEN STILL, THEN RESET, EITHER THE RESET BUTTON ON THE BASE, (PUSH) OR HOLD/PRESS BOTTOM RIGHT CORNER OF SCREEN WHEN POWERING ON AND WAIT, THEN RELEASE PRESSURE TO HARD RESET
Dec 29, 2009 | Garmin nuvi 260W GPS Receiver
Garmin Nuvi 350 screen iz frozen. reset did not help.
Look near the SN # and press the reset button.
or
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Aug 20, 2009 | Garmin Nuvi 350 Car GPS Receiver
My Garmin Nuvi will not turn off.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The reset button on your nuvi will switch the device off. The reset button can be used to switch your device off if the screen is frozen and you are unable to switch the device off by the power button.
To reset a nuvi 2xx:
  1. Look at the bottom of the device
  2. Locate the small circle with a dot inside
  3. Press the circle to reset the device.
To reset a nuvi 3xx or 6xx:
  1. Lift the antenna
  2. Locate a button with the word Reset inside
  3. Press the button to reset the device.
The device will now switch off.
Aug 03, 2009 | Garmin nuvi 260W GPS Receiver
Garmin 260W screen is blinking and beeping. Wont do anything else
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sure give it a try.
  1. Lift the antenna
Aug 02, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
Won't turn off, frozen screen
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Try "resetting" it.
  2. Locate the small circle with a dot inside (very small)
  1. Lift the antenna
Jul 25, 2009 | Garmin nuvi 260W GPS Receiver
I have a Nuvi 260. Where is the reset button? The manual that came with the unit is for a 200. Is the button under the sticker somewhere?
It hard to see, not hard to find....look CAREFULLY
Might need glasses to see it depending on your age!!
  1. Lift the antenna
Jun 06, 2009 | Garmin nuvi 260W GPS Receiver
My kids locked my garmin nuvi 260w all my screen says is enter pin in i dont know it
Unfortunately, even if you perform master reset on Garmin GPS unit, it does not reset Garmin Lock security feature, which password-protect most Garmin electronic devices to deter theft. If you forget the PIN or password unlock code to unlock the Garmin unit, the best solution is to bring it to Garmin to get unlocked. “Secure Location” does not unlock a locked Garmin unit either as it’s only a temporary fix as when it’s turn on outside the security location, the device is locked again."
So unfortunately, there is only one option: You have to send your nüvi into the Garmin, who can unlock it. Remember original receipt.
Mar 10, 2009 | Garmin nuvi 260W GPS Receiver
Garmin nuvi system software missing 265W i try to update my garmin nuvi 260. I see on the screen: sytem software missing. I cannot do anything else. Please, help!
I can help you reset and fix your Garmin Nuvi 265W.
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted.
There are three steps to take to get your Nuvi 265W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 265W Manuals here.
Feb 22, 2009 | Garmin nuvi 260W GPS Receiver
Garmin n?vi 260W GPS Logo
403 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
