Question about JVC TH-M505 System
JVC sp-pwm606 Subwoofer wont stay powered. When volume is 30 or above, sub powers down. Please help.
  • 91 Answers
Hello, it,s very possible that it,s circuit protector built in to the sub (if it,s a self powered sub) gets to the point of overload and shuts off as a protection so that the speaker won,t get damaged and also so the internal amp tha,t pushing the speaker sound is also protected since theese amps all have heat buildup, their are two types of subwoofers ,They are the powered ones and the ones that are powered bt the surround amp ,The ones powered by the stereo surround amp/tuner tend to throw out less power to the sub and the ones that have internal power are mostly higher powered , Another thing you might want to check is your polarity to the speakers and also the omage , Most home theater system speakers are 8 ohm,s but their are speakers and amps that can be changed to 6 ohm,s you might want to check the speaker rating also . Well hopefully you can use theese different methods to at least troubleshoot and discount the thing,s that are not the issues , Good luck and hope theese sugestions might help you , Sincerely Glenn
Posted on Mar 04, 2009
Have a JVC sub SP-PWM606 all speakers work except sub. found a blown cap on what I assume is the sub's amp replaced 2 caps- still no sub
Sub woofers are basically mono amps. It's likely that either a fuse has gone, on the sub, due to the blown caps. Or more likely the main power amp device of the device blew the caps. I suspect if you replace the IC or transistor(s) on the heatsink then the device will come back to life.
Feb 04, 2018 | JVC Audio Players & Recorders
What model sub woofer can replace JVC SP-PW100?
open corel, at top click on about- click on activate and enter code
Sep 09, 2014 | JVC SP-PW100 Subwoofer
Where do i find a connector cord for my powered subwoofer model no. sp-pwm606
There are a few on eBay. Search for "JVC THM505 cable" and check the 'include description box'.
If you need the manual...
Register and download the manual for free at
Mar 16, 2011 | JVC SP-PW100 Subwoofer
I have the sub woofer and two sp-thc5f front speakers. Can I hook this subwoofer directly to my JVC 56 high def big screen or do I need a dedicated amplifier that works this sub wooofer?
No, the powered subwoofer gets its signal AND power through the DIN connector so you'd have to second guess JVC engineers on which pins are power or signal; and what voltage level it supplies and then you'd have to come up with a source for the power. Managing the volume and relative levels would be a trick, too. Devastation lies down that path.
Get the prescribed JVC electronics or go with a whole new sound solution.
Jan 16, 2011 | JVC THC5 Home Theater System with 5-Disc...
Subwoofer not working.... JVC surround sound system 778V Subwoofer Part Number SP-PW37-SUB I hear a hum coming from unit so there's power going to it. I hear weak bass thumps with volume turned all the way...
A connectivity check could provide the solution, notice any wrong wire connections on device or any other devices requiring interconnection. The woofer would perform properly when the connections that provide current for woofing are approapiate
important notes
1. Trace the connection from Recorder or sound output to the woofer device
2. The wiring connections should be sound and video ouput into sound and video output into woofer.
3. The connections if any problems would be located at the stereo recorder or device producing the spund and video. Check the connections of wires on the recorder device ensuring rewiriing
4. finally, adjust the equalisers if any the buttoms could have been disbled by master switch hindering full blaster boost sound.
Dec 05, 2010 | JVC RX-778V
SP-PWM508 subwoofer input conections
sub hooper power was not come.
Feb 11, 2010 | JVC TH-M603 System
The subwoofer lites but no sound
Have you gone into the menu settings and adjusted the sub woofer volume, some factory settings are set @ zero.
Sep 09, 2008 | JVC TH-M55 System
SP-PWM505 subwoofer does not stay on
Well i had exactly the same problem, my sub turned off right away when i turned the whole thing on. Well i opened the subwoofer and was trying to find out something unusual, i took out, i believe, internal amp, well, whatever that thing is, under the lid. Which one is screwed with 6 copper screws, so you unscrew those screws, lift that lid and that whole board comes out. On that board i find something like burn around one of the parts.
you can see it in the pick, the part q2902, then i contacted JVC. At the beginning they said i need to take the whole thing to service center and so on. But later i made them to tell me what kind of part that is, so here :
bought soldering gun in home depot for $15, returned after i was done. And that is it, just have to replace it, but total cost only $12 ($5 part +$7 shipping)
May 15, 2008 | JVC TH-M505 System
JVC TH-M505 System Logo
526 people viewed this question
Top JVC Audio Players & Recorders Experts
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
