I bought this radio and have no idea what model it came out of. model no. 39100-SCA-A200-01 ref. no. CQ-EH8261LC s/n 17086570 i need the code would like to put it in my truck yes the hole is big enough dry fit it already... thanx
SOURCE: I need a radio lock
The code normally comes on a separate document as does key codes or numbers. You could check the owner's manual to see if it was noted in there. (A bad idea.) Also check for a sticker inside your glove box. If that doesn't work then you need to remove the radio/CD player from the dash to get it's serial number from the back of it. Take that number with your VIN to a Honda dealer and they should be able to get your security code for you. They will likely ask for your driver's license & registration to prove you own the vehicle.
SOURCE: honda cd player code need?? model
hi if its the orignal make a note of your vin number take it to any honda dealer they can get it for u
SOURCE: nesecito el codigo del radio de mi honda accord 1996
Los codigos de radio, generalmente son unicos para cada modelo y serie; recuerde que es un mecanismo de seguridad en caso que el vehiculo o equipo de audio sea robado. Le sugiero visitar a su distribuidor Honda y solicitar esta informacion directamente, podrian pedirle documentacion que demuestre que Usted es el propietario del vehiculo.
Good luck.
