Question about Sony DAV-FC8 System
Plugging in my iPod
How can i plug my iPod into the system? I can't find a basic "AUX" function on the unit. I have bought a couple iPod adapters and can't get them to work, but I am starting to think it is user error. Where would I the input be?
    Problem Solver:
  • 7 Answers
All you have to do is get a cable that on one end can connect to the headphone jack on your ipod and the other end will have the audio left and right jacks(red and white). The wire doesn't cost that much, maybe $10. Plug the two audio jacks into your Video1 connection on the back of the system and turn your receiver to Video1. That's how i play my ipod on the surround sound.
Posted on Jun 15, 2009
Does the Kenwood KDC MP5032 have an aux input? If so, where is it?
Kenwood utilize the CD Changer plug in the back (which acts as a secondary Aux input), to operate external iPod devices.
This is done with the aid of an Adapter Lead - it has the 13-pin DIN plug on one end (plugs into the rear of your unit), and an iPod plug on the other end (plugs into your iPod).
Depending on the "Generation" of your external iPod device, you will need to buy the appropriate Kenwood adapter cable. These are: KCA-IP102, KCA-IP202 or KCA-IP302.
There may be some aftermarket (3rd party) cables that may do the same job.
Just ensure you read your Kenwood manual, as the Kenwood unit may be limited to the types of files (i.e. formats) it can read & play.
Hope this explains....
Dec 31, 2012 | Kenwood KDC-MP5032 CD Player
How to set it to play with and Ipod
After researching your model DEH-P470MP, it appears that to use an iPod, you need an adapter that plugs into the rear port of the unit intended for a multi-cd changer connection.
If you have one installed and it's not working, I would check the connection on the unit. Make sure the cable is firmly seated in the port and then check the cable and also check for any fuse in the line to make sure it's not blown out.
Also some of the earlier models of ipod adapters aren't compatible with the newer generations of ipods. There are aftermarket adapter plugs that will allow your ipod to charge/play off these earlier decks/adapters.
May 29, 2010 | Pioneer DEH-P470MP Premier In-Dash...
Panasonic SA-AK630 can i plug a ipod into it some how ?
for these stereo you have a AUX IN on the back (L and R RCA sockets)
from your manual follow these steps.
1. Press [AUX].
The unit comes on.
2. For listening: Proceed to step 3.
For recording: Press [a, REC] (recording starts).
3. Start playback from the external source. (For details, refer to the
external unit’s instruction manual.)
External unit connections
An analog player with a built-in phono equalizer can be connected.
For details, refer to the instruction manual of the units which are to
be connected.
When units other than those described above are to be connected,
please consult your audio dealer.
Rear panel of
this unit
(R) (L)
then you need a ipod audio cable, available on mac store, but these cabble has 3,5 mm jack connector, need a adapter 3,5mm stereo jack to rca Connectors, and these is available on electronics stores, or professional audio store
try these and post
Jan 29, 2010 | Panasonic SC-AK630 CD Shelf System
How can I hook up my Ipod to the radio system inexpensively
If you don't have a cassette player, you can purchase an ipod/RCA adapter cable for about $10 and plug it into your aux inputs in the rear. The cable has one end that fits into your ipod headphone plug and the other end is a white and red pair of plugs (called RCA plugs)that will plug into the rear inputs.
Jan 27, 2010 | 2006 Honda Odyssey
I dropped my On Stage micro and now when my iPod is docked and the on stage is powered on their is a LOUD buzzing sound from the speakers. The auz-in mini plug still transmits sound and music fine, only...
I have had then same exact problem, except I had an ihome. I've done research on it for a way to fix it. basically what I have come to find is that the plug for the ipod is just cheaply made, and that there is basically no easy and cheap fix for it. However as long as you have an aux-in you can just simply avoid the problem by buying an eighth inch to eighth inch cord so that you can just simply plug you ipod into the aux-in. As long as you have the ipod plugged into the the aux-in, and aux mode is selected, it should play your music while charging.
Sep 21, 2009 | JBL On Stage Micro Speaker Dock for Apple...
How do I turn on the "external aux" for my pioneer DEH-p7000r
You'll need an adapter cable such as this one:
The adapter cable will convert the changer port on your head unit into an AUX input with dual RCA jacks. Once connected, the head unit will detect the cable and allow it to be another source (i.e. radio, cd, aux).
To connect your iPod to the adapter cable, use any iPod cable or dock that outputs to male RCA plugs.
Apr 01, 2008 | Pioneer DEH-P7000r
AUX slots
hello..i think that.aux in this case is an can try this through connecting your amplifier to any of the aux outputs... and play a cd ,sorry..good luck ..Ron.
Mar 07, 2008 | Kenwood KDC-MP235 CD Player
Phase linear uv8
Assuming that your unit have a rear video/audio input, you need an adapter cable. 35mm to video/audio rca. You may find one on Ebay or RadioShack. Goodluck.
Jan 28, 2008 | Lanzar SVD26MUT Car DVD Player
Sony DAV-FC8 System Logo
103 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
