Question about Hotpoint First Edition WMA22 Front Load Washer
Hotpoint wma22 is leaking between seal and door
My hotpoint wma22 is leaking between the seal and door at the bottom of the door . There is nothing wrong with the seal. It also looks like it could be over filling could this cause it ?
    President:
  • 842 Answers
It could be an over filling issue, or there may be a tear in the seal where you can't see it very well Take a look at my articles:
http://www.fixya.com/support/t1667828-water_spewing_out_air_vent_back_washer
Which discusses pressure switches, or
http://www.fixya.com/support/t1543617-door_seal
if you discover you do need to replace the door seal
Posted on Mar 01, 2009
There is water leaking from the bottom of the door of our Hotpoint Aquarius WMA 56 washing machine. What could be the cause.
Have you been wiping the glass off in the door. A buildup of detergent crust on the bottom will cause the seal to weep.
Jul 20, 2012 | Hotpoint Aquarius WMA56 Front Load Washer
Washing machine wont lock
Sounds like you door switch is faulty. You can access this buy either taking the lid off and reaching down the side and removing and changing it or you can remove the wire clip around the door seal and folding it back out of the way and the switch is just there, 2 screws removes it. Should only be about 20 pounds for a new one. Hope this helps
Mar 03, 2011 | Hotpoint First Edition WMA22 Front Load...
Our Hotpoint Aquarius Dishwasher BF11, built into the kitchen units is leaking steam from the door ( and starting to cause the wooden floor to bend ). Can I get a door seal for this model ? It's probably...
you gotta send the full model number,open the door and look at the very front of dw where the door closes into the machine,usually the tag is on the left side at 9 oclock,first are you positive that's where it's leaking remove the bottom kick panel and see if the motor or anything isn't leaking there too.if it is the door gasket it's an easy fix
Oct 07, 2017 | Hotpoint Dishwashers
I have a Hotpoint Super Plus dishwasher 7820. It worked well for a long time. Towards the end of the cycle it leaks a lot of water from the underside of the door, so it seems. I have fitted a new door...
The door seal has to be in a proper position completely around the door (including the bottom area of the door). If not, it will leak. Also, there are two black corner baffles/seals (located in each front corner inside the tub area) that may also be the culprit. Additionally, there may be an issue with the float switch assembly that shuts off the water supply prior to the wash cycle. If the float switch assembly is allowing an extra amount of water in the tub, it will cause a leak.
Feb 26, 2010 | Hotpoint Dishwashers
I have a hotpoint wma22. problem with it does not spin.The belt is ok .
+I would remove the motor and check the brushes for wear.
If they are less than 3 or 4mm long, thet need replacing.
If brushes o/k, then it is probably a control module fault.
I am of course assuming that the washer has drained the water out, or it will not spin.
Jan 12, 2010 | Hotpoint First Edition WMA22 Front Load...
Our hotpoint WMA22 washer will fill with water and wash but will not drain.i have lowered the drain hose to almost ground level and it will empty the water, and then will spin. In your opinion is it the...
Sounds like a blocked filter to me.
Remove lower rear panel of washer, remove large black hose fastened to bottom of drum, remove and clean filter inside hose, check pump for blockage at same time. You probably will not need to replace any parts
Please rate my solution.
Thanks.
Nov 06, 2009 | Hotpoint First Edition WMA22 Front Load...
Hotpoint Dishwasher that leaks from bottom of door.
the spray arm not spining and shut water on the door all the time or the hole in the spray arm is clug
Feb 01, 2009 | Hotpoint 24 in. HDA3740G Built-in...
Door seal
it has a big ring clamp around it. both could be loosen by a philipps screw driver.
tnx 4 using fixya,
drcool
Oct 22, 2008 | Hotpoint First Edition WMA22 Front Load...
Cleaning
I am not familiar with this machine's model, but in most of the machines the filter is located under the panel in the bottom of the machine (the panel under the front door). You should pull the panel out and you will find the filter there. Before openning the filter prepare a bowl and a floor cloth to avoid water's flooding. Good luck!
May 06, 2006 | Hotpoint First Edition WMA22 Front Load...
Hotpoint First Edition WMA22 Front Load Washer Logo
127 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
