Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
My whirlpool washer adds water then stops.
You can slam the lid a few times and it will start agian.
  • Anonymous Mar 03, 2009
    My washer is having the same issue.
  • Whirlpool Master
  • 3,361 Answers
Check your water level switch for a blockage in the air hose.
Check the kid switch for good contact.
Posted on Mar 04, 2009
My washing machine fills up with water but does not continue the wash cycle. Sometimes when you slam the lid the washer will continue the wash cycle to the end. Other times the washer stays filled up...
Sounds like the lid safety switch is either out of adjustment, or needs replacement.
Most washers will fill with the lid open, but no continue a cycle where the drum or agitator spin, unless it senses the lid is closed.
Oct 01, 2013 | Whirlpool Washing Machines
My washer wnot agitate unless i slam lid
is the lid up during the filling process? the new washers will not agitate unless the lid is down. no need to slam the lid.. There is no pin to push the activator switch.. they are controlled with a magnet...
Jul 31, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Must repeatedly slam top loading door shut for machine to start
on the inside of the lid there is a lid switch hole that a plastic tab goes down through the switch could be bad or the screws holding the switch in could be lose or broken
Mar 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Have to slam lid down to get washer to start
Did not want to disect the entire machine to get at the lid switch. Couldn't figure out how to get the corner covers off so I figured we would continue to slam the lid until that no longer worked and then "call the guy". Thanks.
Jul 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Cycle stops...
replace the lid switch, or check the connections it might even be your pusing rod for activating the switch
Jun 17, 2008 | Kenmore 24032\24036 Top Load Washer
Washer
Sounds like the lid switch to me .... cheers and merry Xmas from 'downunder'
Dec 24, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Water fill stops
Your lid switch is probably damaged or loose. Examine the lid switch on the right-hand side of the washer tub opening. There are two screws that hold the switch in place. Check to see if they are loose. In addtion, the lid should have a small plunger that depresses the switch when the lid is closed. Make sure it is intact and not broken. If the switch is tight and the plunger is intact, the switch has probably been damaged and needs to be replaced. If you have the type of washer that has no visible plunger and/or switch, the lid switch is locate in the rear on the left hand side and has a small arm attached to the lid that activates a contact when closed. Often this arm can get bent and will not engage the lid switch contacts. A simple adjustment (sometimes) can correct this. I've seen a lot of these switches where the casing on the switch separates and the contacts will not close. Slamming a washer lid is highly NOT recommended just for this very reason. The switch is an easy replacement and costs roughly $35. If youy post back with your model number I can research to find a part number for you. I will also give you step-by-step instructions on how to replace it. I hope this helps.
Oct 12, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal De
