I was vacuuming the steps, and it just turned off like the cord pulled out of the wall./...but the cord was still in. Almost like a fuse flipped off. Now it will not turn on at all.
Comments:
Mar 01, 2009
- You were right! After about 45 min or so, I plugged it in and it worked!
Most likely your machine has a blockage, has overheated, and the thermal cutout has operated. This will reset itself when the machine cools, which can take an hour or more. Unfortunately Dysons tend to run hot anyway, so it doesn't take too much restriction of the airflow to cause this problem. Check for obstructions (including filter that may need washing) before anything else.
The motor which causes suction stopped working. The brush will still spin, so we know it's getting...
(More)
The motor which causes suction stopped working. The brush will still spin, so we know it's getting power. Product is about 4 years old. When we turn it on there is no sound, no odor, nothing. When we pull handle into vacuuming position, the brush starts, but no suction.
vacuum was working fine, then I turned off to empty container, won't turn on now, but when I turn on...
(More)
vacuum was working fine, then I turned off to empty container, won't turn on now, but when I turn on the roller bar....that works??? Is there a reset button or anything?
my beater bar will not spin when the handle is lowered? But there's suction thru the hose when the...
(More)
my beater bar will not spin when the handle is lowered? But there's suction thru the hose when the handles upright
I recently cleaned the filter in the ball, replaced it after letting it dry, but now there is a...
(More)
I recently cleaned the filter in the ball, replaced it after letting it dry, but now there is a "catch" in the ball when I use it, and I cannot figure out where it is catching. Also, plenty of suction, but it is not getting to the nose. I am assuming there is a blockage in the tube leading from the nose to the canister, but how do I get at it?
brush will not spin, when you push the button to turn brush on and off it doesn't do anything. The...
(More)
brush will not spin, when you push the button to turn brush on and off it doesn't do anything. The vaccum and think is sucking up a little but the brush does not spin
