Question about Broan-NuTone CV350 Performance Bagged Central System Vacuum
Motor won't shut off on central vacuum
Motor won't shut off after pulling hose out of the outlet, unless I unplug it in the garage.
    Scholar:
  • 95 Answers
Your relay is bad. This is very easy to change out yourself. There are several websites that sell this part online. Some websites offer free tech support.
Posted on Mar 02, 2009
My central vac unit does not turn off even when hose is disconnected. I have to unplug the motor unit in the garage to shut it off. What do you think the problem is? It is a 7 year old Electrolux
Possibly the power module. Or a short in the wiring. Take it to the local Aerus Electrolux store and have it checked by a service tech to be sure. The pm is a lot less expensive to replace than a whole cv.
Nov 21, 2010 | Electrolux Central Vacuum
I have to go into the garage to turn on the motor on the tank and to shut it off. When I plug the hoses into the outlets in the house, it doesn't turn on the tank motor. I don't know what part to get and...
Is this Electrolux that's now known as Aerus? If so, take it in to the Aerus Electrolux store for a tech to look at. You can find the nearest Aerus Electrolux store by following the instructions on the site at bottom of page.
It sounds like a problem with the power module in the vacuum. Without checking for myself, that's my best guess.
http://www.aerushome.com/storelocator/
Poor suction in system - I have used shop vac to suction all three receptacles. Have checked bag and cleaned everything. Still poor suction. I have one receptacle in garage that works perfectly. Must...
Have you checked the hose for clogs or leaks. Clogged and leaky hoses are an area of concern with any central vac. Unless you hose has a hose sock, then wear and tear from constant rubbing on floors and other surfaces will result in holes and cracks. Pulling the hose can also result in leaks where the hose attaches to the handle and intake connector.
Mix some dish soap with water.
Use shop vac to blow air through hose, with other end capped or "clogged".
Apply soap solution to each end of hose.
If bubbles form, this indicates leakage. Hose will need to be replaced.
Oct 25, 2010 | Broan-NuTone CV450 Central Bagged Central...
No suction once hose is plugged in. If I go to another recepticle it has plenty of suction until I plug the hose in. I just bought this house and the owner was unable to help with operating manuals due to...
If it's just the one outlet, then there's probably a clog in the pipe between that outlet and the main pipe. You may be able to clear it by plugging the hose into a working outlet, placing other end to non-working outlet, and turning vacuum on. This may provide enough suction to **** out the clog.
If not, you'll probably need to use a mini plumber's snake to try to remove it.
Sep 11, 2010 | Broan-NuTone CV353 Central Vacuum
A Nutone CV-450 System with inlet nozzle switch issues
You are suffering a connection problem of the hose end fitting to the wall outlet. Either the hose is not aligned with the two pins in the wall outlet, or the pins in the outlet are dirty and not making good connection to the hose end fittting.
Jan 01, 2010 | Broan-NuTone CV450 Central Bagged Central...
Central vacuum with new motor shuts off and throws switch
Your mini breaker is probably bad if its a new motor. Its found on the relay board and they can weaken over time, especially if you had a bad motor before that tripped it a lot.
Oct 31, 2009 | Vacuums
AirVac ZX6000 won't turn off!
There is a relay board inside your unit which is most likely bad. If you have the make and model, you can contact me and I can order the board for you(pending your mechanical abilities). If not, contact your local central vacuum installation company. www.thevacdudes.com
Apr 21, 2009 | M&S Systems AirVac AVP1200 Platinum Series...
I have a central vacuum system. When I disconnect the hose from a wall outlet the central canister does not shut down dispite my turning off the vacuum at the handle of the hose. The only way I can get...
What I'm hearing is the canister(Not the Powerhead) portion of the unit is running all the time unless you unplug it. this problem could be caused by a short in one of your low voltage lines running through the house. To determine that just unplug one/both low voltage lines from the canister, and plug it back into the recepticle. If it doesn't start up then you figured out that it is in the house somewhere and not the unit. If it is in the house I would check for water in the valves, or you're just gonna have to chase down the short. If the unit is still running with the low voltage wires disconnected then it is probably the relay on the board, which means you will need a new board unless you're expereinced at soldering and want give it a try replacing just the relay. Which you'll probably need a new board by the time you're done anyhow. LOL
Good Luck
Nov 21, 2008 | Vacuums
I have a 3 year old NuTone CV 353W central vac system and recently the switch on the hose handle does not turn the system on from any outlet in the house. I have to plug the hose into the outlet and then...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=567634
Generic problem for all Vacuums
I have a 3 year
posted by patfitz on May 03, 2008
I have a 3 year old NuTone CV 353W central vac system and recently the switch on the hose handle does not turn the system on from any outlet in the house. I have to plug the hose into the outlet and then turn the unit on from the switch on the canister. Any help would be greatly appreciated. Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are a couple of things that come to mind, 1st. you may have a bad switch in the hose and in most cases that can be repaired – if not you would have to purchase a new vacuum hose. 2nd. You may have a bad inlet valve in your hose and most of them are low volt of which would only cost less than $10.00 and can be replaced yourself unless you have what they call a SuperValve of which has 2 low volt wires and then it is wired to your home electricity and that should be replaced by an licensed electrician. It is a low volt and high volt inlet.
#3. the last thing you may check id that you may have a bad relay in the canister itself. Because you should be able to turn on the Central Vac with the switch on the hose and everything should work just fine . feel free to contact your local vacuum cleaner dealer in your area of call the Nutone Factory cust serv line for further assistance. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://nutone.com/ Customer Service
Nutone Inc.
9825 Kenwood Road
Suite #301
Cincinnati, OH 45242
Customer Service 1-888-336-3948
Technical Support 1-888-336-6151
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 03, 2008 | Broan-NuTone CV450 Central Bagged Central...
Broan-NuTone CV350 Performance Bagged Central System Vacuum Logo
226 people viewed this question
Top Broan-NuTone Vacuums Experts
Steve
Gerry Harvey
Gerry Harvey
JoeVacs
Are you a Broan-NuTone Vacuum Expert? Answer questions, earn points and help others
