Question about Lexmark X4270 All-In-One InkJet Printer
Poor printing My Lexmark x4270 used to print great with new cartridges but I just put new ones in and the text has become weak and sporadic. Whole lines will be missing or very faint. I have cleaned cartridges with the automatic system. repeatedly I have tried auto alignment setting and it tells me the tape is still on the cartridges which is wrong. Any suggestions?
  • 101 Answers
Gain new cartridges, possible that application time ended in yours.
Try to clean nozzles of cartridges by humid (wet) fabrics
Posted on Mar 07, 2009
The lexmark x4270 does not print black. I just put in a new cartridge.
Hi
check expire date on cartridge
your cartridge is clogged or it has not installed as it should
you can try cleaning printhead from printers maintenence menu
In case I had help you pls vote me
Nov 06, 2010 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x4270 all-in-one problem with Windows 7
I really appreciate your patience. Thank you for choosing Lexmark glhall53!!!
Apr 29, 2010 | Lexmark X4270 All-In-One InkJet Printer
Each line of text is printing multiple times, lines overlap, and printing
Hello. That's an alignment problem in the printer. Remove the cartridges from the printer. Close the cover. Clean the nozzles using a damp paper towel. But, if it's possible, try to use new cartridges. Unplug the printer from the power source. Plug it back in after 10-15 seconds. When the printer's ready, re-insert the cartridges. Let it print an alignment page all the way through.
Mar 25, 2010 | Lexmark X4270 All-In-One InkJet Printer
Poor and inconsistent quality from the black ink.
the problem seems to be un-even distribution of ink. try a different and new ink cartridge. Since you are refilling the cartridge, the ink inside of the cartridge is getting magnetized, there by, the ink stick to the drum of the cartridge and don't distribute the ink evenly. shake would clear it. you need to demagnetized the drum.
Feb 21, 2009 | Lexmark X4270 All-In-One InkJet Printer
Where the heck is the ink cartridge
If you will notice where the paper comes out of the printer, that whole top portion including the keyboard area tilts up and back, it is hinged. Once it is up you will be able to see the ribbon cable attached to the print head and the print head has the ink cartridges on it. With the printer off the printhead should be on the far left. Put your fingers on the cartridges and slide the printhead to the middle so that it is right in front of you and you can get to it. The ink cartridges just lift up and back off the print head. Replace the new one close the lid and power it on and you will be up and running again. God bless.
Jan 09, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark all in one 4270 won't print in black
I know your problem. I just put in new cartridges and it will print the test page, but nothing else. Did you get an answer
Sep 12, 2008 | Lexmark X4270 All-In-One InkJet Printer
Blurry Picture
Check that your print quality is not set to "Draft" in Windows.
Check for ink residue on your color cartridge.
Try replacing the color cartridge
If all else fails...
Update the printer driver using software from the vendor website.
Jul 11, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x4270 Alignment Problem
When you say you checked to see if anything is obstructing the cartridge, please also make sure the clear tape/tab on the cartridge head was completely removed before use.
If you put another head in, does it work? Sometimes the cartridges are bad, if they have been exposed to extreme temperatures.
A fragment of the protection tab would explain the error as well as the printout, as you don't seem to have any yellow at all.
Hope this helps.
Jun 09, 2008 | Lexmark X4270 All-In-One InkJet Printer
Color printing
GO TO MAINTANANCE SECTION IN THE MENU TRY TO TAKE SELF TEST PRINT.
IF IT COMES THEN GO TO NEXT STEP AND TRY TO CHECK THE INK LEVEL OF THE CATRIDGES IF THE INK LEVEL IS LOW DO REPLACE WITH THE GENUINE CATRIDGE ITSELF.
Feb 29, 2008 | Lexmark X4270 All-In-One InkJet Printer
No color printing with lexmark x4270
How may times did you use the printer to print befor this happened? If you used it a lot then you may need to buy more ink. My printer showed full ink and it turned out that they were empty.
Feb 26, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
