Question about UPM Programmable Wall Switch Timer
UPM Timer: only works with pressing manually
Our indoor UPM timer no longer works. It hs worked fine for two years. But now, even switching on the lights requires multiply pressings of the on-off button. Even then, not always. Lately, it has required more and more manual pressings till the lights come on. We've replaced both fluorescents in the fixture controlled by the timer, but results are same.
Do you suspect a faulty timer that needs to be replaced?
Thanks
  • 169 Answers
Yes this does sound like a faulty timer, to be more specific it sounds like the triac device inside the timer is failing.
Regards,
Carl
Posted on Mar 02, 2009
Display very dim
Posted under UPM wall timer.
Timer model and brand and approx age are unknown.
Is this new installation?
Was display brighter before?
Most timers have 1 year limited warranty.
Buy another timer.
Add a comment.
http://waterheatertimer.org/UPM-timers-and-manuals.html
Sep 22, 2012 | UPM Programmable Wall Switch Timer
How to programme UPM Model ETl30
More information is needed to find manual.
ET130 timer appears to have 6 buttons with 3 buttons on each row.
http://hkm888.com/upm-marketing-et130-indoor-programmable-timer-reviews.html
Review options below:
1) Add a comment and describe timer buttons in detail so I can match buttons with known timers.
2) Open following links and check if manuals for ET525, ET420C, ET420 might have same button and programming relationship.
http://waterheatertimer.org/UPM-timers-and-manuals.html#ET420C
http://waterheatertimer.org/UPM-timers-and-manuals.html#ET130
Add a comment please
Oct 02, 2011 | UPM Indoor Electronic Programmable Plug-In...
Programing
Manuals for programming UPM timers are each longer than space allowed for free answer:
Open following link to identify your timer, open manual, write out instructions if they seem confusing, re-post question about any specific part of any UPM timer manual, and add exactly which timer you are working with, and add link to that manual so expert can read manual alongside you.
If your timer does not appear on UPM page, add a comment with photo of your product for possible identification by expert.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 09, 2011 | UPM Programmable Outdoor Timer
How do you set upm model dt 420 electronic timer
Open UPM DT420 manual on following link:
http://waterheatertimer.org/UPM-timers-and-manuals.html#DT420
The manual is longer than allowed for free answer and has important illustrations and options.
Please read the manual in addition to instructions given below.
Copied directly from the manual:
1) Select AUTO using the slide switch
2) Select the desired On-period (2, 4, 6, 8, 10 hours) using the dial switch
3) For continuous Dusk to Dawn operation, Select CONTINUOUS using the dial switch.
Timer turns ON automatically at dusk and turns off according to how you set 1 2 and 3.
If timer does not operate, or if it turns on at odd times, then it is broken.
Note: UPM manuals normally leave out important information, but this particular instruction matches closely with similar products and is probably accurate.
Add a comment for more free help.
Feb 28, 2011 | UPM Programmable Outdoor Timer
After 7 years working properly, the event button has stopped working. There is no way to start the load in manual, or to change the program... What can I do?
You posted under EH40 Intermatic programmable timer.
EH40 Manual:
http://waterheatertimer.org/pdf/eh40-manual.pdf
1) EH40 uses size A battery. Replace battery.
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html#Battery
2) Reset the timer: Press and hold reset button for several seconds
3) Contact Intermatic because they are aware of specific problems with specific timers
http://www.intermatic.com/customer%20service.aspx
4) Other folk have reported EH40 and EH10 last about 3 years.
EH40 has 1 year limited warranty.
I test timers: 7 years is reasonable run for inexpensive electronic time switch.
5) For longer lasting timer, consider Next Generation: battery is replaced every 8 years
http://www.intermatic.com/products/timers/electronic%20time%20switches/next%20generation%20time%20switches.aspx
Feb 28, 2011 | Intermatic EH40 - Electronic Water Heater...
I have a n older mandolyn (upm.??) AX-801S timer. I have it all programmed. However whereas many timers have ON/AUTO/OFF settings this one only has ON/OFF. Does anyone know which way to set this timer to...
I do not know that timer.
Many older timers never had online manuals.
Check following 2 links to see if your timer and manual show:
http://waterheatertimer.org/Woods-timers-and-manuals.html#seven
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Dec 22, 2010 | UPM Indoor Electronic Programmable Plug-In...
I am having a problem setting the UPM ETW350 timer, can't seem to have it go off at a certain time. What do I do about the countdown? IS that what I press to go to the time to shut it off?
You posted under UPM 350 programmable timer
Manuals for all UPM timers are missing key explanations, despite the lengthy manual.
I think there are 3 things to look for:
1) Program1 is ON and program2 is OFF and program3 is ON etc.
2) When setting days, be sure that ON and OFF are set for same days so there are no conflicting programs.
3) Timer gives three modes: Countdown and Random and Programming. Countdown is for a bath fan when you want to turn on fan with push of button and have timer turn off fan automatically after the countdown expires. Do not use countdown or random functions when you want timer to perform ordinary on-off functions.
For a price, expert works with you via e-mail or phone while you work on timer or any do-it-yourself project.
Dec 14, 2010 | UPM Programmable Wall Switch Timer
I need the instructions for a UPM Model 100 indoor programmable timer...
UPM100?
Do you mean UPM RTC100 remote control timer set?
Smarthome usually posts manuals with their products:
See if this is your product:
http://www.smarthome.com/2046/Programmable-Receptacle-Timer/p.aspx
pdf manual
http://www.smarthome.com/manuals/2046.pdf
add a comment if this is not your timer
Nov 20, 2010 | UPM Indoor Electronic Programmable Plug-In...
I have lost the instruction sheet for operation. Can't remember how to set it. Model ET160
ET160 is a UPM plug-in type digital timer
http://waterheatertimer.org/pdf/UPM-ET160-wall-timer.pdf
If you have problems with specific part of manual, add a comment and I will answer
Oct 30, 2010 | UPM Indoor Electronic Programmable Plug-In...
UPM Programmable Wall Switch Timer Logo
199 people viewed this question
Top UPM Hardware & Accessories Experts
Steve
Gene Haynes
Are you an UPM Hardware and Accessory Expert? Answer questions, earn points and help others
