Question about Garden
Need to rewind craftsman chainsaw pull rope.
Pull rope cgot stuck. re-coiled back into unit. took off housing can not figure out how to rewind. nothing broken...new saw. just trying to figure out how to rewind..any ideas???
  • 137 Answers
I have tried to do this many times and have yet to suceed, believe me it's not worth the fustration and the extra days in hell you will spend from cussing.
Take to a repair shop, they can do it quickly and cheaply when you consider how difficult this is for the ordinary person. (me)
Posted on Mar 02, 2009
Starter rope won't pull on my Craftsman rotary mower model 917.4787A.
the cable may be stuck or you may have to take the top off and rewind the rope.
Nov 05, 2016 | Garden
Pull starter stuck
If the pull start is stuck, it is normally because it is kinked and knotted inside the coil housing. Take the top off, pull out the spool, rewind the rope, put back together, and pull start away!
Sep 15, 2013 | Aprilia Motorcycles
The pull cord on my Craftsman gas blower model 358.794765 was jammed with about 6" sticking out. I took it apart and found nothing broken but now i cannot figure out how to put the spring in. There does...
Most likely the reason for the jamming of pull rope would be the rewind coil was over stressed due to use and age (they become brittle after a while) and where the coil catches on inside of housing snapped causing a slight unwinding and then the restricted movement of pull rope assembly. If you have it apart you should be able to see where the coil connects at both ends and attaches to its mating location. If you do not see the typical bent coil hook then your coil is broken. No worries, if this is the case, heat the broken end with a lighter or torch and use a pair of needle nose pliers and reshape to match the hooking location. Once completed, rewind coil and place masking tape around coil temporarily holding coil in place and leave yourself about three inch lead of coil to attach where it needs to go. Insert and fasten coil assembly then remove all pieces of tape. At this time your pull rope should be recoiling and rewinding pull rope. Always wear eye protection.
Sep 03, 2013 | Craftsman Garden
Broken starter cord to re thread
I'm going to assume you have a new rope. If you look at the rewind pulley (plastic disc) there should be a hole where the original rope went through. Run the rope through this hole and then through the hole in the starter housing itself. At the other end of the rope near the pulley, tie a knot at the end of the rope and pull it through the housing until your new knot is up against the hole in pulley. Next put the rope through the starter handle and tie another knot. Now you should have a rope with a knot on both ends with the handle near one, and the pulley on the other end. Now if you look at the pulley on the outer edges, you will see a notch in it. Hold the rope into that notch and spin the pulley in a clockwise rotation for about four turns. Don't let go of pulley because there will be tension on the spring. Hold pulley with your thumb while pulling rope out of housing on the handle side until taught. Hold rope outside of housing and release pulley. Now slowly release rope on handle side of housing an let it slide back around pulley. When tension is released and if there is still rope hanging out of starter housing, repeat the above steps but instead of going four turns around with rope in notch, only go one at a time until the handle is all the way back to housing. It's important not to go too many times with your wrap around because it will cause spring to be too tight which may cause breakage in the future....Just go far enough to let handle touch the housing and you should be good to go.
This would be much easier to show in a video than in type. I hope this helps.
Sep 21, 2012 | Stihl Chainsaw Rewind Starter Spring 024...
Rewind sticks
Was the saw dropped on it's left side? Remove the entire starter housing and look for bent metal parts. Does the cord operate normally when off of the saw? Unless the housing was crushed, usually you can bend some of the internal metal parts to get the spool to turn freely. Hope this helps!
Jun 08, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Starter rope won't retract
You have to wind the spring as tight as you can before you put the rope on. Then allow the spring to unwind, pulling the rope onto the spool. Be very careful when you take it apart. Good luck...Lee
May 29, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Homelite model No. 10609. 1H2100076 My pull rope won't recoil.
Not that i know of, take the cover off and rewind by hand, use greese on the coil and pull the rope in and out, if the rope doesnt recoil you are going to need a new pull start assembly
Apr 28, 2010 | Homelite ZR10926 16 Chain Saw
Starter rope pulley will not pull the rope back into the leaf blower.
Most commonly, the recoil rope rewind spring is broken. However, inspect the recoil housing assembly first to make sure no debris or rope fragments have prevented the rope rotor from rewinding. Always remove the spring 'AS A LAST RESORT'. Many rewind problems can be solved by inspection of the rotor and not have to remove the spring. In case you do, I will include instructions on how to re-install.
1) remove the recoil housing
**NOTE: normally you DO NOT need to remove the rotor pulley or spring to replace the rope. This is the area that causes so many guys a lot of extra trouble
2) locate the string that is left and the hole it is threaded thru
3) determine how much string has broken off of the rope that came out
Note: if more than 1 inch is left, then the rope needs to be replaced
4) after rope is obtained, make sure both ends are melted to a point for easier threading thru handle and rope rotor
5) install the rope (with the handle installed on one end) thru the recoil housing and towards the rope rotor.
6) with the rotor free of tension, route the rope from the groove toward center and up thru the hole. Tie a knot in the end of the rope, leaving a 3/8" tail free.
7) wind the rotor in the direction of what the rope would pull (this will tighten the spring) until the spring is completely wound. remove 1/2 to 1 revolution, and then allow rope to wind onto the rotor until all rope is wound.
8) Pull the rope several times to position rope properly into rotor.
*note : there should be NO droop in the handle after released
If droop is evident, wind the rotor and rope 1 revolution tighter so there is no droop of handle when released
9) when unit is functioning proplerly, re-install housing onto unit
Nov 21, 2009 | Craftsman Garden
Craftsman gas chainsaw 18'' model 358 pull start repair
Recoil Spring Rewind
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool. HTH
Lou
Sep 20, 2009 | Garden
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
484 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
