Question about Microsoft Xbox 360 Console
Our power light is solid green but no pic
Our xbox power light is solid green but we have no picture on the tv
  • Anonymous Mar 01, 2009
    i have no sound or picture
    Novelist:
  • 174 Answers
Its the same sort of problem as the 3rrod, the mainboard overheats and as a result the lead free solde rcracks and these type of faults occur. we can rectify this type of problem for you np. the xbox 360 needs a few things doing to it to get it working again:
1: clean the cpu and gpu
2: add some new heatsink paste to them pref arctic silver 5
3: replace the x-clamps
4: reflow the entire board
5: add heat conducting pads to the memory chips
we do all the above and also give the xbox 360 a free service worth £40 including return delivery to your door for only £40
www.fixmyconsole.co.uk
Posted on Mar 01, 2009
How do I replace control board?
RCA/Westinghouse HV320WXC1007061 T-Con Boards ...
? 4:35
https://www.youtube.com/watch?v=5jO_TZfplR0
Jan 21, 2013 - Uploaded by ShopJimmy.com
RCA TV Repair Westinghouse TV Repair T Con Board Tutorial & No Picture ... Top Common LCD TV problems for bad TimingControl T-Con Boards: .... VR-3215 with no picture no sound but the power LED is solid green, any ...
RCA 276046 Power Supply Unit (PSU) Boards ... - YouTube
Nov 24, 2015 | RCA P52927 52" Rear Projection TV
I have a 42 " Phillips with no pic and no sound. I've replaced the Power Board and CT Board tht corrected the error blinking lights but still have the problem My Light stays solid green and I
Dear Mate
Please share us the Model # and Is that is the Plasma LCD or LED. And tell us Is your`s TV is stay on stand by or its green LED is stable.With No video and sound.
Dec 11, 2014 | Televison & Video
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
Mitsubishi projection T.V
check the lamp first to see if intact or shattered.
Mar 31, 2012 | Mitsubishi Televison & Video
I've been having this problem for a while. when I'd turn the tv on I was able to watch it for about 15 minutes. suddenly the picture and voice would turn off, but the green power button was still solid...
Sounds like it may be a power supply issue. I don't know what "modules" the tech replaced, but I would have advised you to scrap the TV for a newer model as they can get pretty expensive to find and replace parts of the older rear projections. Sorry I can't be more help to you.
Feb 04, 2010 | Televison & Video
XBOX360 No Audio, No VIdeo, Solid Green Light
the G.P.U has more than likely detached from the main board.
the x clamp mod is more of a diagnostic procedures than an
actual repair function. The G.P.U will need to be re-flowed to
the main board then lightly but firmly clamp to the board
then stress tested (force it to run hot for 15 min shut off and
repeat 3 times)
that's it
Aug 23, 2009 | Microsoft Xbox 360 Console
Xbox 360 solid green light in the middle
hey gandylt, i had the exact same problem happen to me acouple days ago. i bought an additional working xbox 360, and i decided to up grade the cooling. anyway let get to the point.
There were three things that i did that solved the problem.
1.) I removed all heatsinks to find that i did an crappy job on applying the artic silver, it was everywhere. so one thing u want to do is make SURE THERE IS NO THERMAL compound on the motherboard PERIOD! the thermal compund can act like conductors, therefore if its all around the motherboard it can actually BRIDGE two different flow routes on the motherboard which isnt good at all. So Clean the mother board with 90%+ Alcohol.
2.) Second i reapplied the artic silver 5 in an very thin layer! its important not to have too much.
3.) Third. i didnt tight the heatsink bolts so tight like i did the First time. tight them but dont tight them too much.
Those were the exact 3 thing i did to get my 360 recovered from the following error. good luck guys!
Mar 26, 2009 | Microsoft Xbox 360 Console
Have sound no picture and 2 green rings around power button
They are green?!? usualy when people have problems with  the xbox 360 hardware, the lights turn red. This xbox 360 may have a birth defect... Best thing to do is call 1800-4my-xbox. Talk to a representative about sending your xbox in, ONLY if you have not voided the warranty. If so, you will most likely have to buy a new xbox or new motherboard for it.
Also try changing your video settings to tv instead of hd, or hd if it is plugged into a hd tv. You might have toggled the HD switch on the video/audio chords.
Dec 31, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
299 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
