Question about Minolta magicolor 2200 DeskLaser Printer
SERVICE CALL 14 XFER ROLLER
TRIED EVERYTHING AND CANNOT GET PRINTER GOING AGAIN
PLEASE HELP OR IM GOING TO BURN THE PRINTER
IT HAS WORKED FOR YEARS
ITS THE BEST PRINTER I EVER HAD
  • jsorgie Apr 06, 2009
    Does anyone have the part number for the Transfer Roller and know where I can buy one?
The problem is most likely due to the little optical sensor assembly on the Transfer Belt getting covered up with toner. When you pull the transfer belt unit out and flip it over to the right, it will be located on the top left of the unit. It looks like a little rectangle sticking out over the edge of the plastic transfer belt. Remove the sensor assembly by removing the screws around it, and it should come right off (will have some wires running to it). You can further disassemble the sensor by removing the circuit board holding the LED and receiver. You'll have to clean toner out of or off of both of these. Mine had more on the emitter (LED), but YMMV. Be careful removing the circuit boards, because if you break it, it's $330US for a new transfer belt. 8-o
Posted on Aug 19, 2009
    Genius:
  • 2,120 Answers
You need to replace the TRANSFER ROLLER
Posted on Mar 02, 2009
Thanks axemann1 - you were completely right - in true magicolour style yet another consumable is saved by simply cleaning with care.
Posted on Sep 15, 2009
  • alexsilverma Dec 19, 2010
    Thanks Axemann1 - right on the spot. I was ready to buy a new printer. It is not worth $330 for the part when a new printer is around $500.
Erroe message says SERVICE CALL 0094 xfer dETACH 2
check the sponge looking roller inside the machine
model number would help
Mar 04, 2014 | Konica Minolta magicolor 4650DN Laser...
C450 blank copies
Does it print out a meter report OK? Does it make a copy? NOT A Print? I check the Xfer roller The sponge looking roller is the xfer belt OK (Shiny ) inside across from the sponge roller when cover is close. any P_ codes little oil can looking thing on the operation panel bottom
Feb 21, 2014 | Minolta bizhub 200 All-In-One Printer
How to fix service call 14 xfer roller
Remove the Transfer roller sponge looking roller and replace
Feb 17, 2014 | Minolta magicolor 2350 Laser Printer
I have replaced the transfer roller in the lexmark c510 and get an error msg. 80 xfer roller missing. i've installed these a zillion times but don't know what the problem is
Please click on the link http://bit.ly/qXq2Cfto see instructions on how to go about the procedure.For further assistance, please contact LexmarkTechnical Support.
Mar 16, 2011 | Lexmark C510 Laser Printer
Paper feeder does not appeat to be able to 'grab' paper ?? what can i do
Please refer to the manual and then open the ADF clean the rollers and then try again some times due to dust in the rollers then paper is not feeded.
Apr 11, 2010 | HP LaserJet 2420 Printer
SERVICE CALL 14 XFER ROLLER Have installed new transfer belt. Still had error message. Came here and read tips. Cleaned the sensor both in the printer and on the transfer belt; reinstalled. Still...
the transfer roller is a foam roller that transfers the toner onto the paper. It will be visible with toner removed, a little wider than a piece of paper, and about the thickness of a roll of quarters. I don't know how to physically remove it on your model, but transfer roller issues in general can be remedied by removing the transfer roller and wrapping it in packing tape until the tape comes off clean.
While you're in there, vacuum everything out for good measure; but never, ever use canned air on a laser printer.
Jan 03, 2010 | Minolta magicolor 2200 DeskLaser Printer
I have a brand new canon mp480 printer. it keeps jamming
HEY THERE GUY'S THE EASIEST SOLUTION I CAN TELL YOU TO DO IS CALL CANON COMPLAIN THE'Y WELL MAKE YOU DO A COUPLE OF THINGS THATS SUPPOSED TO CORRECT THE ISSUE: LIKE ROLLER CLEANING A COUPLE OF TIMES, CLEAN THE ROLLER WITH ALCHOL, TURN EVERYTHING OFF AND SHAKE THE MACHINE A LITTLE AND TURN IT BACK ON TO SEE IF THAT WORKS AND FINALLY IF THAT DOESNT WORK THEY TELL YOU TO UNISTALL THE DRIVER AND REINSTALL IT!! WELL MAYBE FOR SOME OF YOU THESE STEPS MIGHT WORK!! BUT L'M TELLING YOU IVE PERSONALLY NOTICED CANON'S PRINTERS ARE ****!!! I'VE GONE THREW 2 PRINTERS SINCE DECEMBER LAST YEAR AND THEY SENT ME OUT A 3RD ONE FREE OF CHARGE!!! I TOLD THEM I HAD A CANON MP 150 FOR YEARS THAT I PRINTED EVERYTHING ON IT AND I STILL CAN EVEN AFTER MY DROPED IT AND BROKE A COUPLE OF THINGS ON IT!! SO FAR I HAVE USED THE MP470 WHICH IS GARBAGE!! AND THE MP480 IS THE SAME!!!! L MIGHT JUST SELL THE ONE THEY GAVE ME!!! IF ANYONE HAS QUESTION FEEL FREE TO CONTACT ME AT jdaguilera28@yahoo.ca SEE YA!!
Apr 12, 2009 | Canon Pixma MP480 All-In-One InkJet...
Hp p1006 wont load/feed paper
i know this is not perfect but...
paper runs out during printing... so
1)open the front cover
2)close the front cover
3)IT WORKs
If i helped you please rate me
Dec 10, 2008 | HP LASERJET P1006 Printer
Minolta QMS 2350 showing service call 15 xfer belt
Your error means -
Incorrect pressure by or separation from the transfer belt cleaner
Remedy
1 - Check the Belt cleaner positioning sensor pc9 (located at the rear on the left hand side towards the top when looking from the front of the printer)
2 - Replace the Second image transfer roller pressure/separation
mechanisms.
3 - Check the Image transfer roller pressure contact solenoid SL2 (this sits more in the middle behind the printhead)
4 - Replace PWB-A.
5 - Replace PWB-P.
Jul 05, 2008 | Minolta Office Equipment & Supplies
Fatal error 14H MY MAGICOLOR 2530 DL HAS FATAL ERROR 14H
Try first rebooting the printer, if that doesn't work, reinstall/update all drivers. If that doesn't work, you need a service tech.
Error 14h is:
Service Call 14 XFER ROLLER: Incorrect pressure by or seperation from the Second image transfer roller..
not too sure on how to fix that if reboot/driver update doesn't work.
Mar 28, 2008 | Computers & Internet
Minolta magicolor 2200 DeskLaser Printer Logo
1,663 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
