Question about HP Officejet 5610 All-In-One InkJet Printer
Spring sprang out of paper receiver tray holder
The spring that holds the left side of the paper receiver tray sprang out of the unit and now it doesn't work. Can't see where/how to make repair. Any ideas?
We are out of our warranty period, of course.
Suzanne
    Genius:
  • 2,120 Answers
The spring that sprang has sprung, you cannot get a replacement from HP Buy a new machine
Posted on Mar 02, 2009
Printer head going one side and given beep
IF the jammed paper tears and you cannot remove the paper either from the paper output slot or from the transport unit, or the jammed paper remains inside the machine, remove the paper following the procedure below. 1. Turn off the machine, and unplug the power cord of the machine from the power supply. 2. Open the paper output cover. Remove the paper on the front tray if any.
Important:
    Do not touch the clear film (A). If the paper or your hands touch these parts and blot or scratch them, the machine can be damaged.
3. Make sure that the FINE cartridge holder does not hang over the paper. If the FINE cartridge holder hangs over the paper, move the FINE cartridge holder to the right edge or the left edge whichever is easier to remove the paper. When you move the FINE cartridge holder, hold the FINE cartridge holder and slide it slowly to the right edge or the left edge.
4. Hold the jammed paper with your hands.
If the edge of paper is jammed near the paper output slot, pull the edge of paper to the position where you can hold it with your hands.
5. Pull the paper slowly not to tear it, then pull the paper out.
6. Make sure that all the jammed paper is removed. If the paper is torn, a piece of paper may remain inside the machine. Check the following and remove the piece of paper if it remains.
7. Close the paper output cover, then reload the paper.
All print jobs in the queue are canceled. Reprint if necessary.
Jul 21, 2014 | Epson LX-300+ II Matrix Printer
How do i clear paper jam after tearing half of the paper leaving other piece locked inside machine?
Important:
Jul 20, 2014 | Canon Pixma Mx432 Wireless Inkjet Office...
I do not know how to remove the drum to fix a paperjam
Brother strongly recommends that customers do not use generic drum unitsand/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the Verify the message displayed on the LCD.
Warning: If you just used the machine some parts inside the machine are extremely hot.
1. Pull the paper tray completely out of the machine.
2. Pull the jammed paper out of the paper tray opening. If you are unable to remove the jammed paper continue to STEP 3. If you are able toremove the jammed paper continue to STEP 9.
3. Open the front cover. If you cannot open the front cover, do not useextra force. See below for further assistance.
4. Pull out the drum unit and toner cartridge assembly. The jammed papermay be pulled out with the toner cartridge and drum unit assembly, or removing the drum and toner assembly may release the paper so you canpull it out of the paper tray opening.
a. If you are able to remove the drum assembly and jammed paper continueto STEP 5.
b. If you cannot remove the drum unit and toner cartridge assembly easily, do not use extra force. See below for further assistance.
5. Place the drum unit on a drop cloth or large piece of disposable paper to avoid spilling and scattering the toner. Hold down the blue lock lever on the left side of the drum assembly and lift the toner out of the drum unit. Examine the drum carefully for small pieces of paper that may be jammed inside.
6. Reinsert the toner cartridge in the drum unit until it clicks into place. If you put it in properly, the lock lever will lift automatically.
7. Place the drum unit and toner cartridge back into the machine. Use equal pressure on both sides of the drum unit when pushing it back into place. Make sure it clicks into place.
8. Close the front cover. Make sure it clicks into place.
9. Remove any remaining paper in the paper tray and then reload it. The tray can hold up to 250 sheets of 20lb paper. Do not over fill the tray.There is a maximum paper mark located on the top of the right and left paper guide. It looks like a V cut out in the plastic. Fan the stack of paper well to avoid paper jams or misfeeds.
NOTE: If you are using special paper and the machine has problems feeding it from the paper tray, try the paper again using the manual feed slot
10. Put the paper tray firmly back into the machine and unfold the output paper tray support flap before using the machine.
11. Turn the Brother machine around with the back of the machine facing you.
12. Open the back cover.
13. The black plastic inner chute should spring open automatically when the back cover is opened. Note: The inner chute has a diagram on it of a piece of paper being removed from the unit.
14. If there is paper inside the machine carefully remove it.
15. Close the back cover. NOTE: The inner chute will close automaticallywhen the back door is closed.
16. To test, print the Help List:
a. Press the REPORTS key located on the right side of the control panel.
b. Press the up or down arrow key until Help list appears on the display(#2).
c. Press Menu/Set. The report should begin printing.
Thanks an good luck
Nov 27, 2010 | Brother MFC-7220 All-In-One Laser Printer
Duplex paper jam . i thought i took out the paper that was jammed and i am still getting that message, PLUS now I cannot the top tray back.
The duplexer, which flips the paper to automatically print on the back side, slides into the back of your printer. Unplug the printer and slide the duplexer out to check it for jammed sheets. You might have pulled out a sheet or two in the main printer section and left one in the duplexer.
As for the top tray, the paper feed wheels ride on the end of a long lever that drops down to rest on the paper. It should be held up out of the way by a spring until the drawer is inserted, but sometimes the plastic nub that the spring pulls on breaks off. Lexmark sells a little kit of the spring and "bellcrank" to fix it. If your paper tray holds 500 sheets - a whole **** - you need part no. 56P1331 "Parts packet, bellcrank and spring, 500 sheet." For 250-sheet trays the part number is 56P1337. A web search for either part number will find you a seller.
Sep 20, 2010 | Lexmark T632 Laser Printer
Paper keeps getting jammed in left cover when i try to copy on both sides of the paper
first: did you set correct paper size and type for bypass insertion?
Second: Clean roller!!
Remove drum cover, its a cover left sideway, with grey handle in middle. You can remove it by pulling it into left side.
Remove bypass tray, it is holded by two plastic hinges. You must remove them from its holders.
Now you are able to see the bypass roller.Its in the midlle and has plastic axis from both sides.
Clean it with alcohol, and dry it.
Try now, run few copies from bypass.
If that doesnt helps you you need to check bypass clutch, wich is located left of the bypass tray, covered with plastic cover, wich covers section from bypass to up to the fixing unit.
To remove bypass clutch you also must remove back cover.
But if you must do these write me on emma.servis@gmail.com, or call service, because the clutch must be putten into specific position.
Hope that helped!
Jul 30, 2010 | Canon imageRUNNER 2000 Copier
Keeps saying no paper in tray although paper is in tray
I encounter that problem before, after I checked the sensors, feed unit and mechanism nothing is wrong or broken but still NO PAPER indicates on the display .I only noticed with the machine is the cassette tray or the paper tray, when you try to pullout the cassette tray and look at its left side, there is missing parts on it. There is a spring and actuator on it that will engage on the feed unit drive. Try to find the same machine and look at the cassette tray to see the missing parts on it. You can buy a new cassette because the parts that is missing maybe not available.
Feb 19, 2009 | Brother DCP-8065DN Black and White Copier
Brother mfc8460n message no tray. tray is in.
The sensor also has a spring to the left that enables it to go to its default location. If this spring is missing then the sensor will not detect the tray and display the "No Tray" message even though the tray is in place.
Jan 15, 2009 | Brother MFC-8460N All-In-One Printer
I have a Canon 330 Home copier, and the paper drive, sprang the spring on the left side, and the paper goes in crooked. Where may I find a repair service, In Shawnee, Kansas 66216
i am assuming you are talking about the spring on the sponge roller under the drum you can use a small spring like from a pen just cut it in half or so.. that is if you have the little bushing that goes over the roller shaft.. ( the same set up on bothsides) the put tape it to hold it in place
Dec 26, 2008 | Canon imageRUNNER 400S Copier
Paper will not feed, some large spring is loose and don't know where it goes
Okay, I figured it out - if you unhinge the paper tray holder and you look at the bottom of it there is a little circular indentation that is where one part of the spring goes. I surperglued it that. Then if you look inside the paper holder you will see another circular type indent that has a tiny little plastic latch at the top of it - it will match up with the one on the paper try holder. I put the superglued spring into the printer and shoved it down with the handle of a comb and a long kitchen knife.
Hope that helps!
Oct 01, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Lexmark Optra T612
The broken part is called the bell crank arm part number 56P1228 this is very common. If the printer isn't recognising your tray, remove it and check the little plastic fingers on the left side (half way down the tray) and the metal springs in the printer (left side) which the tray pushes on to.
Aug 04, 2008 | Lexmark Optra T612n Laser Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
88 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
