Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Where is the g board located at on my rear projection tv
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    what is the exact model number of Sony TV to help you out in locating G board in it.
    New Friend:
  • 168 Answers
If it is a kp53hs30 it is the main powerboard it is on it's side to the left as you are looking at it from the back
Posted on Mar 04, 2009
It wont trun on
the fuse is located on the ac filter board which is the small white board on the right side infront of the green board when looking in the rear of the TV. Its also the board that the powercord plugs into. I am attaching a picture of the board that has the fuse on it
Apr 02, 2013 | RCA D52W20 52" Rear Projection HDTV-Ready...
Where is the dm board for ws-55511 located
The dm power board is the small board shown in the illustration below it has the 7 capacitors on it and its located inside the metal box on the far left side of the TV when looking in the rear cover. The metal box stands up vertically2_12_2013_9_52_00_am.jpg
Feb 12, 2013 | Mitsubishi WS-55511 55" Rear Projection...
Hi, Where is the power supply board located within the WD-52825 rear projection tv?
Its in the very front of the metal encased chassis block underneath the sloped top shield. The Power cord plugs directly into the power board.
Jul 30, 2011 | Mitsubishi WD-52825 52" Rear Projection...
Hello, I have a problem with my sony rear projection tv. When I try to turn it on the standby lights blink but it odes not turn on. I turned it on using display 5 vol- power and it did turn on and know it...
You need to count the number of blinks between the pause. Most common is 9 blinks. Also- after you press POWER, do you hear a "click" or not? If no click and 9 blinks, you probably have a "zero cross failure" and have two options:
(1) Replace the "G" board (part # A1054157A) or have it repaired (they repair it on eBay for about $40. You ship them the bad board and they either repair and return or ship you a different repaired board) A new board costs about $80- without having to send them your board.
(2) Repair the board yourself- by replacing the two diodes on the "G" Board - (D6301 which is on top- by the small transformer) and (D116 which is an SMT component on the bottom of the board- it takes VERY steady hands and a good solder iron). The parts should cost less than $25 and are available on eBay by searching for "sony a1054157a".
Location of "G" Board on a Sony Rear Projection TV (KDP-51WS655)
problem-4ojfzua2t5qdonett1db0kz0-5-2.jpg Location of "G" Board on a Sony Rear Projection TV (KDP-51WS655)
problem-4ojfzua2t5qdonett1db0kz0-5-5.jpg Component D6301 location (Sony KDP-51WS55)
problem-4ojfzua2t5qdonett1db0kz0-5-9.jpg Component D6116 location (Sony KDP-51WS55)
Sep 11, 2010 | Sony Grand WEGA KDP-51WS655 51" Rear...
Where can I buy an STR-4525 transistor for my Toshiba Rear Projection tv?
That is a drawing number for the IC itself. I will need the model of the TV and the location number for that IC to be able to look up the Toshiba part number. The location number will be silk screened onto the pc board where it came from.
Dec 02, 2009 | Toshiba TP55G60 55" Rear Projection...
Sony kp 51hw40 real projection tv
Below is exploded view of your Sony KP-51HW40 TV rear side which shows board names and location.
You need to check D Board for convergence ICs and these are marked as IC8001 & IC8002 on circuit board.
Nov 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Convergence problem
Its located in the front behind the speaker panel there s a nother small access panel the convergence board is right there on the right hand side up front.
Jun 01, 2008 | JVC AV-48WP30 48" Rear Projection...
Toshiba 57h81 location of hyper board and remove procedure
Hyper board is located directly behind the input board, this is where all the tv conections are, then they are two tabs soldered from the bottom of the board then it simply unplugs, But replacing all those capacitors on that board can be a little tricky, replace all 10up @16volt caps and that usaly repairs the board
Feb 12, 2008 | Toshiba 57H81 57" Rear Projection...
Panasonic 53wx53g rear projection tv
The ONLY place I know might have one is PTS Electronics:
Good Luck!
Sep 12, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Mitsubishi WS-65869 65 in. Power Light
They are little green soldered in fuses located on the center board (the one with the STK's on it) toward the rear of the set near the large transformer.
Aug 24, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
