Question about Cuisinart EM-200 Espresso Machine
Problem Water Flow in the Cusinart EM-100 Model
Water is flowing through the hole close to the removable drip tray when the large function knob is in the off position and the power button is on. I have not been able to stop water flowing through that hole even with the large knob in the off position. How can I solver this problem?
  • 8,596 Answers
I might have answered this one already, but:
Confirm one more time that the knob is lined up with the "o" in the middle - if it is leaning even slightly toward the coffee cup icon or the water/steam icon, water may come forth.
If the knob is perfectly in the middle, then the calibration is probably off (although I can think of one other possibility). Rather than deal with an expensive and warranty-voiding repair, I would just call Cuisinart - that unit has a three-year warranty, and I believe every single one of the EM-100's was introduced less than three years ago. Just write down the serial number that is on the bottom of the espresso maker, and call up Cuisinart - no receipt will be required as the serial number will almost invariably be enough in this case. If you live outside of California, you will have to pay for shipping - probably about $25 all together. But you will be getting a brand-new unit in return.
-Tha Mp3 Doctor
Posted on Mar 03, 2009
My cva 4066 will not make coffee, I descalled it, that function worked fine,all it does is make the grounds a little wet and the rest of the water goes in the drip tray. Can you help me?
Have you Cleaned the Brew unit? The descale Tablets are to clean and descale the internal plumbing - the cleaning tablets are to remove the oils from the brew unit. If clogged the water will not flow through , instead it will dump into the drip tray.
May 11, 2014 | Miele Coffee Makers & Espresso Machines
Tip
Bosch tassimo T65 - water draining in to drip tray possible cause and resolution
I had a problem on my Tassimo T65 where water was entering the bottom drip tray through the small hole at the rear. It seems many people have this problem but after researching on line there is little help although I found on this sit how to take the coffee maker apart and from that thread the possible cause for my own issue.
So if your machine seems to be leaking from the small drain hole to the rear of the drip tray try this before you think it is either in need of specialist repair by Bosch at a cost almost the same as a new machine or before you start to take it apart and have a look yourself.
CAUSE - The water is coming from the drain hole because the pressure valve at the top of the machine is blocked with calcium deposits through prolonged use without descaling sufficiently.
SOLUTION - Purchase a good quality coffee machine descaler. Sit the whole coffee machine in a tray or large oven tray so you can collect the overflowing descaler throughout the process, it's not economical to waste this solution. Remember to clean down and dry the coffee maker each time.
Use at least half strength descaler do not water it down more than 1:1
Follow the descaling process by inserting the yellow disc and holding the start button down for 3 seconds.
Repeat this process several times, recovering the fluid leaking in to the tray and cup or container. If you start to see small lumps being dispelled in to the cup try to remove these for further descaling.
After several cycles you should notice that the leaking or flow of water from the bottom drain hole becomes less until it stops. To force the dissolving scale out of the pressure valve try running the normal clean cycle but with the descaling solution, the flow is longer and will help flush the restriction.
After a number of descaling and clean cycles the leak or flow from the drain hole will have stopped, if not continue till it does.
Note: I ran cycles for about 2 hours with periods of rest to allow the solution to do its work.
Now the leak or flow has stopped clean out the reservoir and replace with clean water and run at least 4 clean and rinse cycles.
i hope this works for you and now enjoy your coffee.
on Jul 02, 2014 | Bosch Coffee Makers & Espresso Machines
Dripping water
Mine had the same problem today. I found the drip tray under the screwed on panels in the freezer was full.
There is an evaporative tray above the compressor in back, and feeding that was a drain pipe that was blocked with crud. Removing and cleaning the cap made it flow freely again. Hopefully that fixes it.
Jan 23, 2014 | Sanyo SR-1030W Top Freezer Refrigerator
Water drips in refrigerator. I think it has to do with the defrost feature, which seems to drip only periodically.
You are correct. the defrost drain is most likely plugged up causing the water to drip into the refrigerator through the air returns in the ceiling of the fridge.
To access the defrost drain hole in your model you will have to remove the back wall from the freezer compartment and possibly the floor of the freezer as well if it has the floor air flow tray.
The repair is quite simple- remove as much of the ice as possible (i use a putty knife to pull it up in as large chunks as possible and then use a moistened dish towel to pick up the smaller pieces.
Use a turkey baster with some hot water to "plunge" the drain hole out. The drain hole is located in the bottom center of the evaporator opening.
Jun 15, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Water leaks from my detergent dispenser from my front loader washing machine?
This is usually indicative of soemthing blocking the flow of water out of the soap tray, down the connecting pipe and in to the drum chamber.
The soap tray doesnt have any seals as water should just flow into the tray, wash out the soap / fabric softner, and then flow out the back of the tray and down the connecting pipe. When working correctly, there is no pressure or water back-up to cause the water to reach the front of the soap tray.
Take out the tray - your machine user manual will show you how, and check both the tray itself and the "hole" it slots in to for either a build up of solidified soap powder, or some other foreign object. If still leaking, remove the tray again and try to get your hand (a woman's or teenager's hand being smaller is best) down the large oulet at the back of the "hole" the tray slots in to to feel for a blockage.
Do you have young children ? A washing machine soap tray is a great place to hide things !
Occasionally, if the smaller pipes that deliver hot and cold water to the tray come adrift, this can spray water at the front of the machine. This water then has only one real way out - via the soap tray "hole". Most often this will be the cold water pipe as this has higher water pressure to cope with. The only way to check this is to take the top of the machine off.
If after all of the above it still leaks, you'll either need to dismantle the machine enough to see the back of the soap tray "hole", connecting pipe and drum chamber for a better look for problems, or call an engineer.
Nov 04, 2009 | Maytag Washing Machines
Problem with Cuisinart EM-100 Express Machine
-Tha Mp3 Doctor
Mar 01, 2009 | Cuisinart Coffee Makers & Espresso...
DeLonghi PAC A120E Pinguino 12,000-BTU Portable Air Conditioner - Water Leakage Problem
I had the same problem and found a fairly simple solution. UNPLUG THE UNIT FIRST. All left and right reference below is as view from the BACK of the unit (NOT from the front). Open the right side panel (right as view from the back), by removing six screws (remove screw covers first) and pull down on the panel to remove. Towards the UPPER-back of the unit, there is a cold air evaporator(?)(bunch of tubes and fins) you can only see the edge of it after removing the right panel. Below it is a white plastic drip tray with a hole at the end allowing water to pass down to the lower warm air radiator(?) (another bunch of tubes and fins) to evaporate. If this hole is obstructed, water will over flow and leak. I cleaned out the hole with a vacuum attached to a drinking straw, you might have a better way. After cleaning, I poured a little water through to make sure it drains. There is a lower drip tray at the bottom of the unit which catches the water and you can drain it out the bottom drain hole by unplugging the rubber stopper at the back bottom of the unit. The lower drip tray has a float switch (you can only see it by removing the back panel, which you don't have to do for this procedure) which turns off the unit when the lower tray is full. So, theoretically, even if the evaporation is not working properly, as long as the upper drain hole is not obstructed, there should not be any leakage, because the water will drain into the lower drip tray and turn the unit off when it is full. The upper drain hole obstruction might be causing most of the leakage problem. Also make sure the unit is level left to right. If the left side (left as viewed from the back) is lower than the right side (as view from the back) the water in the upper drip tray might not flow to the drain hole properly and might overflow. You should also vacuum and clean the upper plastis filter screen (pull it out from the top back of the unit). Before closing the right side panel, you might want to vacuum and clean the lower warm air radiator, be careful not to damage the fins. Again before you start any of this, UNPLUG THE UNIT FIRST. This might be easier than packing and sending the over 90 pounds unit to an out of town service center. I understand some service centers might charge $100 for a simple cleaning. Consult a trained technician if you don't have the skill to do this. Do this procedure at your own risk because I am not sure if it might void you warranty. Again UNPLUG THE UNIT FIRST before you start.
Jul 21, 2008 | DeLonghi CF210 Portable Air Conditioner
Water flow through humidifier
I installed this humidifier (and had a lot of trouble installing it!) and was surprised by the flow of water. Mine leaks out of the bottom of the unit so I haven't actually used it yet. I'll try to figure out why it's leaking this weekend. I thought there would be less water flowing through the pad. I suspect that the weight of the unit is causing it to not be plumb so some water is dripping off of the pad and past the drain tray.
Nov 30, 2007 | Honeywell HE360A1027 Whole House...
Cuisinart EM-200 Espresso Machine Logo
1,502 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Greg Cann
Greg Cann
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
