Question about Kenmore 23822 Top Load Washer
I have water on floor on the left of a top loading kenmore washer
Can you tell me what is wrong when I find water on the left side under my top loading wahing machine while filling?
  • 46 Answers
There are hjoses on the inside of your machine that connect to the tub. The fill is turned on by a electrically controlled valve. When it opens, the tub fills and if the hose is cracked or the connection is loose, the water will spill out of the hose. You have to open the back up (I think that is how you get in there) and check the hose and the control valve. Does it only leak on the cold? Or does it leak on both?
Posted on Mar 01, 2009
My kenmore oasis washer has started leaking out water and flooding my floor. have you had any other complaints about this problem and how to fix it.
first of, you need to find out where the water is originating from, pull washer away from wall and look for water dripping. usually water leakage starts from pump. on this washer there is a circulation pump and a drain pump on bottom left and right side. check all hoses and enure that there is no pin holes started
Aug 12, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Washer is leaking. If facing washer, water is on
probablly water pump or hose tilt machine to view where water is coming from
Jan 17, 2010 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore heavy duty washing machine model C110. When the machine has a full load and a high water level, it leaks, but when the level is lower ( small load ) it is ok. Also under the machine on the...
The water leak is from the white tub cover on top of the tub. The seal needs replaced.
The oil is from the transmission.
I honestly would replace the washer.
Jan 12, 2010 | Kenmore 24032\24036 Top Load Washer
Leaking water from underneath towards the right side.
The pad is an insulation pad to keep heat in the washer. It might be worth pulling the washer out and checking the water feed and drain connections - it's a good bet one of these is leaking.
Mar 14, 2009 | KitchenAid KAWS700L Top Load Washer
Kenmore 90 series washer overfills
your pressure switch may be bad or your hose that goes from your tub to your switch may be clogged with gunk
Mar 07, 2009 | Kenmore 22422 Top Load Washer
Leaks water
Probably a bad water pump. That is were the Kenmore usually leaks.
2 screws on the top panel right and left sides.
Remove these screws, tilt the control head backwards.
Remove the wiring harhess connector.
Remove 2 clips holding the cabinet to the back panel.
Remove the cabinet by pulling forward.
Pump is attached to front of motor.
Feb 21, 2009 | Kenmore 24642 Top Load Washer
Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Feb 14, 2009 | Kenmore 12502 Top Load Washer
Started a new load of wash and water never shut off flooding room
you can check for a broken/cracked/ dettached plastic hose leading from the back left side of tub to the pressure switch under the main console. usuall problem is it dry rots and cracks, or comes loose after shaking/vibrating,
Nov 15, 2008 | Kenmore 22422 Top Load Washer
Kenmore Washing machine
ck lid switch also ckd hinge screws that looks like newer moder with switch under left side of console try pressing left rear corner of lid or listen for clock when lid is shut slowly
Jun 03, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer top load heavy duty 80 fluid leaking
It's rusty Water probably the water pump housing is cracked might be replaceable need to take a look at it or call Kenmore for the part
Apr 13, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 23822 Top Load Washer Logo
76 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
