Question about HP Compaq Presario SR1350NX (PP196AA#ABA) PC Desktop
PC will not power up
I have a COMPAQ SR1350NX desktop. I shut it down to move the unit from a table to my desk. Will not power up. LED light on PSU blinks. Can hear clicking noise from PSU. Followed HP help and have disconnected everything from PSU and LED is on steady. When I plug in 24 pin to MB, LED blinks. Also noticed green blinking LED on network connector. Disconnected everything from MB and still blinks when 24 pin plugged in. Has MB somehow gone bad?
  • ag74rec Mar 01, 2009
    I even removed each RAM to eliminate them. Video part of MB. The blinking/clicking dies out after the power plug is disconnected.
  • 447 Answers
Check that the ram memory hasn't come unseated from the mobo. If you are using an above board video card also check that it is properly seated as well.
The clicking noise from the PSU is kinda perplexing though...
Posted on Mar 01, 2009
  • John Elliott
    John Elliott Mar 01, 2009
    If you want to rule out the power supply as the problem you can pick up a 300-400w power supply (with a 20+4 or 24 pin connector) and test it. Many of the Compaqs use proprietary PSUs so a generic power supply may not be mountable in your unit but a generic costs much less than an actual Compaq PSU. If you can find a vendor that will let you return the PSU that would be the ideal...
My computer wont start up. The power supply light flashes green when plugged in then red. But still nothing , can someone please help?
Try a Power Supply Unit (PSU) Reset: Unplug the electrical cable from the wall and the PSU (Back of Computer)
Move the red voltage selector to the opposite position it is in and then slide it back. If you live in the USA 120Vac to 220Vac back to 120Vac
After you have done this you can plug the power cable back into the PSU. Connect the power cable to the wall power. If the PSU is still serviceable it will no longer be blinking.
2c170cb8-7c41-4ef0-8a3f-ff232e57320e.jpg fd10abb2-6218-42f0-8857-b761fffbcecd.jpg
Jul 08, 2013 | HP Compaq Business d530 PC Desktop
Compaq 1930nx no power
May be the PSU. This PC has a few miles on it ,right? I had a HP/Compaq SR1120nx when the PSU when out it would try to start and immediately shut down. Over and over. A PSU is not that expensive. Be sure to get the same type ATX connectors. Verify it is a ATX. Mine was 400w for under $50.00. I uped the power from 250w to 400w, I had added Graphic card, sound card, wi-fi card.
Nov 18, 2012 | HP Compaq Presario SR1930NX PC Desktop
LED light is orange but computer is on.
it sounds like you may have overloaded the PSU, best thing to try would be to take out the dvd burner and and try booting again, if this doesn;t have any affect it may mean you need a new psu (power supply).
Mar 18, 2009 | HP Compaq Business d530 Ultra-Slim PC...
HP COMPAQ D530 RED BLINKING LIGHT WITH BEEPING SOUNDS.
4 beeps & 4 flashes mean problem with the power supply. For my experience, most of the time the PSU is good, it is just overloaded.
For more LED and Beep messages, check this link:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00067072/c00067072.pdf
Dec 26, 2008 | HP Compaq d530 PC Desktop
Green light flashing after shutting down computer to relocate office.
if its by the power button the led just indicates power after u have removed its source and reconnected it........this is normal nothing to worry about.
Sep 13, 2008 | Compaq Presario 5000 PC Desktop
Fans won't start on my compaq evo
I suggest replacing the fans with new fans. Fans do expire and they need to be replaced.
Aug 30, 2017 | Compaq Evo D300s PC Desktop
REINSTALL XP HOME EDITION ON Compaq Presario SR1350NX Desktop PC
Files copy errors during the XP installation process are often an indication of BAD RAM.
If you have dual RAM modules, try install with 1 memory module installed
May 19, 2008 | HP Compaq Presario SR1350NX (PP196AA#ABA)...
Wont post.
Try a few things for me OK? From what you typed, turned on the psu "the toggle switch on the psu", pc seemed to be starting up. I need you to keep the toggle switch on the power supply in the on position. Press and hold the start button on the PC case to shut it down. Give it a few seconds & power up by pressing the power switch on the case. Notice a differance? Next, unplug everything connected to the pc expect the monitor, mouse & keyboard. Try to boot. Still no? Remove the side of the case exposing the board. Turn the psu off by flipping the toggle switch on the psu, wait till the green light on the board goes out. Grab the Mb ( I know it's tight in there) and see if you can move the board in any direction. Not loose? Re-check all data & power connections for a solid connect. Re-check your case to Mb connections. Also check the PSU, there is a red slide switch it should be set to 115v. Post your findings..
map
Jan 28, 2008 | ASUS P5ND2-SLI Deluxe Motherboard
Help on a compaq desktop pc
you seem to have a doggy Power supply unit that 's tripping or the power swith is faulty... it seems more like the PSU
Jan 07, 2008 | Compaq Presario 5000 PC Desktop
HP Compaq Presario SR1350NX (PP196AA#ABA) PC Desktop Logo
227 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
