Computers & Internet Logo
satyanarayan de Posted on Mar 24, 2013
1313 error code - ASUS Computers & Internet
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Mar 24, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
408
Points
19
Error Code 1313
System error code 1313 means "A specified privilege does not exist." This error code may also display as "ERROR_NO_SUCH_PRIVILEGE" or as the value 0x521.
I found this page for solve your problem "http://wefixerrors.com/error-code/error-1313.html"
My paper is jammed in my canon pixma printer. Support code 1313
i don't know but if you think all the paper is removed, consider a' cancel of print' if computer requested printing.
push stop button to see if fault cancels. if fault remains,
try shutting off printer and restating it [ push ON for 20 sec.]
if fault remains, pull power cord from back for 30 seconds,
plug back in and push ON. PLEASE refer to this link. if fault remains. <https://ugp01.c-ij.com/ij/webmanual/ErrorCode/TS8000%20series/EN/ERR/1313.html>
i have called cannon for no charge help - maybe try them.
Asus p5kpl error code 1313
http://repairerrors.net/error-1313.html
2helpful
How to fix code P 1313 - 1314
CODE P1313 MISFIRE CATALYST DAMAGE BANK 1 CODE P1314 MISFIRE CATALYST DAMAGE BANK 2 COULD BE MANY THINGS THAT CAUSE THAT PROBLEM.FAULTY EGR VALVE FAULTY MASS AIR FLOW SENSOR OR BAD COOLANT SENSOR BAD O2 SENSORS.LEAKING INTAKE MANIFOLD LEAKING EXHAUST PIPE OR EXHAUST MANIFOLD.
2answers
What code do i need to pair my phone to my 2008 jag x type
try 1234 or 0000 these are the most common codes
Programming instructions
HERE ARE THE CODES FOR Philips TV. 1005, 1008, 1014, 1039, 1064, 1079, 1082, 1086, 1099,1104, 1106, 1115, 1116, 1123, 1149, 1150, 1153,1154, 1157, 1185, 1186, 1203, 1246, 1295, 1312, 1313, 13511157, 1185, 1186, 1203, 1246, 1295, 1312, 1313, 1351
I have a ls2208 symbol scanner that need to scan code 39.... The example below is return when I scan the following information. It seems to be do stange thing with the first 2 charecters. Can you help?...
Your scanner is set up for full Ascii mode.
$B = CTRL B
%I = >
Re-program to enable "Code 39" and disable "Code 39 Full Ascii"
In Code 39:
$B = Control key on
%I = Tab
Hope this helps.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
