Question about DeLonghi EN680.M
My machine is scaled up and does not pump water through to froth the milk. The descaling does no seem to work... HELP?
mirran
  • 515 Answers
SOURCE: Steam not frothing milk
Have you decalcify the machine, the boiler does not heat up if there is calcium in it.
Posted on Jul 11, 2008
mirran
  • 515 Answers
SOURCE: milk not frothing
Make sure the edge on the steam pipe are in place.
Posted on Aug 30, 2008
SOURCE: EAM3500S will not froth milk ?
I had this problem once... It turns out the electrical connection for the solenoid valve that feeds the hot water out into the milk jug/hot water tap had come loose. They are clipped on rather than being soldered into place. Trace the wires back to the main board from the solenoid (brass bit with grommets) and check that the clips are in place.
Posted on Feb 17, 2009
Testimonial: "Thanks ;) "
First, check to see if it will pump out steam without a ton of water. If it doesn't, don't use it.
Now, skim milk is terrible for it, the bubbles are too dry and flavorless. Use 2% milk or half-and-half. It should be cold (very cold). I put mine in the freezer in a steel frothing container for 5-10 minutes before use. Just barely submerge the wand (about .25") and turn on the pressure. It should sound like tearing paper (not like blowing bubbles through a straw). Do this until volume increases to around double (if you have a frothing thermometer, it should be around 100 degrees F). Now submerge the wand farther and tilt the cup to create swirling (this is called stretching & sweetens the milk). This should be done until the temperature is around 140-160 degrees F. Done.
If your machine is no good for steam, there's another way: Put milk into a steel cooking pot (I use a saucier for large groups) and put it in the freezer. When very cold (ice forming) put on stove. Whisk briskly while heating up on medium-high. It will create fine foam & stretch the milk at the same time. The bubbles will start big, but become finer as time goes by. I test by stocking my finger in & going until it feels nearly scalding & remove from heat. Just use a ladle for he milk & a spoon for the foam.
Posted on May 03, 2009
MNfisherman
  • 11896 Answers
SOURCE: not frothing milk
that means that the steamer is not generating enough pressure steam.
This happens either because there is not enough heat, or if you release the steam when pressure is not enough.
Very common problem with the american maid makers.
bear also in mind that Krups are not the best at frothing milk, and this is also a basic model.
If you want the best capuccino Coffee machine, buy the italian ones, Gaggia, Delonghi, Ariete etc. that are all great at this, or get a bigger Krups as a replacement like the Krups XP405040 that is also good at capuccino
Posted on May 09, 2009
Delonghi magnifica esam 4200 lost bar pressure for frothing milk
The most possible problem is that the machine have build up scale both in boiler and in pipe system. Your are still in good chance to solve it easily since it operates normal by performing a good descaling of the machine. You can buy a very good product posibly from ebay like the Urnex DEZCAL which is an excelent descaler and if you perform a couple of descling procedures in a period of one week your machine will perfom better and better.
Oct 30, 2012 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi Perfecta won't froth milk or allow hot water to come out from waterspout
Aug 20, 2012 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Delonghi Lattissima EN 660CW milk frother not frothing
I don't know why my answer posted in the comments section, so here it is in the proper area.
I had the same problem and was ready to send it in for repairs, but I talked to a great guy at Nespresso who helped me fix it myself. The problem was when I pushed the latte button, it would only froth milk for a second or two and then the espresso would start pouring. It basically refused to make a latte. Here's the things he had me do:
1) Descale immediately. I have an older machine, and descaling once a year does NOT cut it. He told me descaling every 5 months at the bare minimum, if your machine is not having any problems at all. Descaling is usually the main problem for lack of froth. I descaled and it seemed like the machine was working better almost immediately. I also ran 4 - 5 tanks of water through the hot water spout and the main espresso part (but mostly this is because it seems to take this much flushing to get the smell of the descaling solution out).
2) Reset your machine to factory settings. I have a classic Lattissima, so this is how you do it on that machine. Turn the machine on and wait until the drink buttons are steady (espresso and hot water buttons are no longer blinking to warm up). Then press and HOLD the power button until the espresso and hot water buttons BLINK THREE TIMES. Then they'll go back to steady again. You're now back to factory settings.
I did notice that I started having the trouble after moving the machine, so I'm not sure which of the above solved the problem. The main thing is it worked and I'm back to yummy lattes!
Jan 09, 2012 | DeLonghi Nespresso EN660 Espresso Machine
Delonghi Magnifica Coffee Maker the milk is not frothing properly - there's lots of steam & very little milk being issued from the spout We clean the milk jug each day, have adjusted the plastic tube...
You did not state anything about descaling, but every now and then, I also add water and descaler to the milk container and use the "Frothing" program to run through the water and descaling-solution (double-click the Cappuchino button).
I have also noticed that the first cup (and sometimes even the second) will produce less milk, and not as well frothed milk as later cups. My theory is that the machine is warmer when producing later cups.
If possible, you could try to run two-three frothings of plain water through before switching to milk. I realize this is inconvenient, but it could be worth testing this to see if it helps. We luckily have two milk containers and keep one filled with water just for the purpose of heating up (or whatever we do :) the frothing system before serving the first cappuchino.
Sep 04, 2009 | DeLonghi Coffee Makers & Espresso Machines
Seaco Incanto not frothing milk properly
Hi
When was the last time you descaled the machine, and not with vinegar? Scale can accumulate inside the boilers and insulate the water from the heating elements, produce less steam. Descale on a regular basis.
May 12, 2009 | Saeco Magic De Luxe Espresso Machine
Aeroccino does not heat
Try descaling, if the element is covered with scale it wont produce enough heat and pressure.
The machine is Krups, and therefore should be covered with one year warranty. Call the number listed on the user manual, or find contact from websites below:
Coffee & Espresso Machines - Small Domestic Appliances - Krups
Home - Krups UK
Oct 06, 2008 | Nespresso Aeroccino Automatic Milk Frother
The frothing stick doesn't seem to work
descaling time not with vinegar with descaler vinegar remove calcium in little piece descaler melt it use 1 part descaler 1 part water put in the water container start it up open valve after a few second turn it off leave it for15 minute repeat untill empty after do 2or3 rince descaler is corosif thank you for using fixya pierre
Feb 10, 2008 | Dualit Espresso 889 Espresso & Coffee...
DeLonghi EN680.M Logo
35 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
