Washing Machines Logo
Posted on Mar 24, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washing machine door leaver is broken
The door leaver is broken so we can't open and close washing machine
Bill Boyd
Level 3:
Top Expert:
  • Bosch Master 53,816 Answers
  • Posted on Mar 24, 2013
Bill Boyd
Bosch Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11926122
Points
172802
Get a new one from you bosch service agent You will need the model number for this. If you can't replace it your self you might have to pay for a service call
5 Related Answers
Anonymous
  • 447 Answers
  • Posted on Oct 03, 2007
SOURCE: help needed indesit washing machine
well it would help to know brand/model#
Anonymous
  • 32 Answers
  • Posted on Apr 13, 2008
SOURCE: WF860 Door stuck in closed position.
FIRST switch off and unplug.
Pull machine out and remove lid by undoing self tapping screws at the top back. May have to slide lid back a bit to lift off.
Internal catch mechanism will be reachable from top for manual release. You may need someone to push door inwards while you release catch.
Good luck
douglas smith
  • 1462 Answers
  • Posted on Jul 10, 2008
SOURCE: Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
gittos73
peter gittos
  • 247 Answers
  • Posted on Dec 16, 2008
SOURCE: Broken door handle for a Thor washing machine
there r 2 ways to get the door open 1)use a normal knife and place in front of the door handle push it in and it should open 2)pull the plug out take the lid off now place your hand down to where the catch goes into the washer using your fingers u should be able to pop it open with a bit off fiddling
Anonymous
  • 566 Answers
  • Posted on Feb 16, 2009
SOURCE: door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
2helpful
2answers
Miele W1714 The machine says "Close the door", but the door is closed! All I can do is switch it off. Nothing else works.
There is a switch in the door that will make the door is ajar light stay on, if you no what door it is your going to have to replace this switch.this happen to me on my ford expedition
1helpful
HI! I HAVE A MESSAGE ON MY HOTPOINT WMF760P WASHING MACHINE OF ' DOOR ' COMING UP & IT'S STOPPING SHORT OF THE WASH CYCLE & THEN YOU CAN HEAR THE LOCK MECHANISM
http://www.ebay.co.uk/itm/HOTPOINT-WMD9692-WMF520-WMF540-WMF560-WMF720-WMF740-DOOR-INTERLOCK-SWITCH-/390558604486?pt=UK_Irons_Presses&hash=item5aef1b5cc6
you need one of these
take the lid off and open the door
isolate the mains supply and water supply
remove the two screws that secure the interlock
this is what the doors catch sits in
reach down and tilt slide it out
remove the plug
plug in the new one
and remount
screw back in the two screws hand tight avoid stripping the plastic
and return the lid in position
now reconnect the water and mains and test
the door closes and the machine should now work aok
did one the other day
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
2helpful
Washing machine Siemens iq300 has error CL in display (status) & can't be used
This means that the door is not being closed. It might be a bad door switch.
Door leaver on washing machine broken
You can look for parts on Fixya; and as to how to change go to YouTube, with your model, brand.
1helpful
2answers
W6444 washing machine door won't close
Try some WD40 spray on the door and lock. Just a bit. Try closing and opening the door. The machine should be in the <off> position.
My washing machine says door opened even i closed the door it' always says opened
Sounds like a sticky or broken lid switch. Over time, detergent and dirt can settle in and around the switch, causing it to stick or disabling it altogether. Try pushing the switch in manually to see if the door open warning goes out.
5helpful
Why is my frigidaire washer not spinning?
  1. Stopped Mid-cycle
    • If your Frigidaire washing machine started spinning, but then stopped, verify that the power cord is still connected to the outlet. See if the outlet blew by plugging in a different appliance into the outlet. See if you blew a fuse. A blown fuse usually is either black or has broken wires. Replace the fuse. If you have a circuit breaker instead of a fuse box, reset the circuit breaker if it's been tripped. Check the lid switch, which is located inside the main housing of the washing machine, near the door frame. If the switch is burned out, order a new part from a Frigidaire parts dealer.
    Pump
    • The pump's sole responsibility is to remove water during the spin cycle. If the pump isn't working properly, see if it's clogged with debris or clothing. Use needle-nose pliers to remove these items. Check the pump pulley, which is connected to the pump. This component must move freely for the pump to work. If it won't turn, purchase a new pump pulley since you can't usually fix this component.
    Lid
    • Check the door latch assembly if the door isn't closing correctly. If any of these components are broken, order a new part from a Frigidaire parts dealer. If you do not, the washer won't start spinning since it believes the door isn't closed. Your Frigidaire washing machine won't start the spin cycle until the lid or door is closed. Always close the lid, and remove any items preventing the lid from fully closing. Always close the dispenser drawer.
    Additional Concerns
    • Never over- or under-load your washing machine. Your Frigidaire washer may not enter the spin cycle if the load is too large, since this can damage the washing machine. Remove a few pieces of clothing. If the load is too small, add a few similar items to the washing machine. Check the internal belt, drive motor and motor coupling. If any of these components are broken or very worn, they may not work properly, preventing the washer from entering the spin cycle. Order replacement parts from a parts dealer. Check the tub and basket bearings, and get new ones if the current ones have broken components or are defective.
2answers
My mother accidentally pulled the door open on the washing machine when it was still locked. Now it won't do anything. It would not even finish the cycle. We were able to get the clothes out and...
Due pulling of the door forcibly the door interlock switch has damaged. So the door cannot lock properly &r the door lock switch is not functioning. Replace the door interlock switch.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
