Question about ASUS M51Sn-C1 Notebook
I have connected my network cable to ethernet port but it is showing the cable is unplugged. my board is asus P5KPL-CM CONTACT 9868115300
  • 523 Answers
Make sure the cable is good, or the ports that the cable comes from is good too, look at the computer network card from the back, if you see linking light this means is computer problem. try to see if your network card is not disabled,or if there is static or dynamic ip address you should use, check this and let me know what happened.
Regards
Posted on Mar 01, 2009
I want to download audio drive for asus mother board p5kpl-cm please
Goto official website. And download the particular software. And please rate with 5 stars for my answer.
Jul 18, 2011 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
What arethe compatible components of this kind motherboard
CPU P5KPL-AM empty.jpg Valuable Intel G31 uATX solution with FSB overclocking 1600MHz!
- Intel® Core™2 Quad Ready
- Intel® 45nm CPU Ready
- FSB 1600(O.C.)/1333/1066/800 MHz
- Intel® G31/ICH7
- Dual channel DDR2 1066(O.C.)/800/667
- EZ Flash2 & CrashFree BIOS3
- 8 Channel High Definition Audio
Intel® Socket 775 Core™2 Quad/Core™2 Extreme/Core™2 Duo/Pentium® D/Pentium® 4/Celeron® E1000 Series and Celeron 400 Series Intel® Hyper-Threading Technology ready
*Refer to www.asus.com for Intel CPU support list
Chipset Intel® G31 Intel ICH7
Front Side Bus 1600*/1333/1066/800 MHz (*1600 is overclock speed) Memory 2 x DIMM, Max. 4 GB, DDR2 1066(O.C.)/800/667 Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*Overclock speed
**Refer to www.asus.com or user manual for Memory QVL (Qualify Vendor List)
***When installing total memory of 4GB capacity or more, WindowsR 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended. Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
VGA Integrated Intel Graphics Media Accelerator (Intel® GMA 3100)
Max. resolution:2048x1536X32bpp, Horizontal:127.5KHz Vertical:85Hz Storage Southbridge
1 xUltraDMA 100/66/33
4 xSATA 3 Gb/s ports
LAN Realtek RTL8102EL 100/10 LAN
Audio VIA VT1708B 8 -Channel High-Definition Audio CODEC
Anti-Pop Function
Jack-detect & Multi-Streaming
Support S/PDIF Out connector USB 8 USB 2.0 ports (4 ports at mid-board, 4 ports at back panel) Overclocking Features SFS (Stepless Frequency Selection)
- FSB tuning from 200MHz up to 600MHz at 1MHz increment
Overclocking Protection
- ASUS C.P.R.(CPU Parameter Recall)
Special Features ASUS MyLogo 2
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Fan
Back Panel I/O Ports 1 x Parallel
1 x VGA
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x LAN(RJ45) port
4 x USB 2.0/1.1
1 x COM port
8 -Channel Audio I/O
Internal I/O Connectors 2 x USB connectors support additional 4 USB ports
1 x Floppy disk drive connector
1 x IDE connector
4 x SATA connectors
1 x internal speaker connector
1 x S/PDIF Out connector
1 x CPU/ Chassis/ Power Fan connector
1 x Front panel High Definition audio connector
1 x Chassis Intrusion connector
1 x CD audio in connector
24-pin EPS 12V Power connector
4-pin ATX 12V Power connector
1 x System Panel connector
BIOS 8 Mb Flash ROM
DMI 2.0
AMI BIOS
PnP
WfM 2.0
SM BIOS 2.5
ACPI 2.0
Manageability WOL,PXE,RPL,WOR ,PME Wake Up Accessories User's manual
1 x UltraDMA 133/100/66 cable
1 x Floppy disk drive cable
1 x SATA cable
1 x SATA power cable
I/O Shield
Support Disc Drivers
ASUS PC Probe II
Anti-virus software (OEM version)
ASUS Update
Form Factor uATX Form Factor
9.6 inch x8 inch ( 24.4 cm x 20.3 cm )
hope this helps
Jul 18, 2011 | ASUS P5KPL-AM - Motherboard - micro ATX -...
My motherboard P5KPL-CM sometimes does not detect my seagate Barracuda SATA HDD (500 GB) at all. plz advise.
Check your sata cable and try to use another sata slot and cable. Also check the power connection.
Cheers!
Sep 28, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
I want asus motherboard driver how can i dowanload..tell me...? asusmother board p5kpl-cm i want all driver...
  1. Go here: http://www.asus.com/
  2. Select your country
  3. Click on Services, Support
  4. Browse to the Download section
  5. Input your motherboard model to display available drivers.
Sep 11, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Sutaible mother board of a size 9.61 x 9.61 inches. I am having a MB of Intel D865G & i want to replace it with Asus P5KPL, so please suggest me is it match all dimensions of D865? Thanks Rupesh
The Asus P5PKL motherboard has the dimensions of 12 X 7.6 inches.
The boards which exactly match your size requirements i.e; 9.6 x 9.6 inches are:
Asus P5P800-VM and Asus P5P800-MX
You can also have a look at Asus P5KPL-CM , P5KPL-VM, P5KPL-AM motherboards which have the dimensions of 9.6 x 8 inches.
Hope this solves your problem Thanks.
Jul 16, 2009 | Intel D865PERL Motherboard
Drivers Pack For Windows Vista 7 is required
I will give you a alternate and easy way for your problem.Just download this software named driver magician and install it.It will search for the drivers for all your hardwares and components that doesnt have proper drivers and will download it.It will make your problem easy
http://www.ziddu.com/download/4569239/Driver_Magician_3.42.zip.html
May 17, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Ethernet port not "active"
Hi there.
Restart the PC and go into the bios to make sure the on-board LAN is enabled, if it is try as jery says and try another ethernet cable.
Post back please and good luck
Apr 21, 2009 | Dell Latitude C400 Notebook
ASUS M51Sn-C1 Notebook Logo
87 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
