Cars & Trucks Logo
George Posted on Mar 01, 2009
1987 Jeep YJ [Wrangler] so owner ship says''
When 4 wheel drive in gear, front wheels still not in drive plus 4wheel drive light on dash does't come on. It is a 5 speed standard trans.Would the problem b in the transfer box.
  • 2 more comments
  • Anonymous Mar 01, 2009
    I parked it for this winter.I'm either going to sell it this year or fix it up for weekend drivin. Haven't checked anything yet, too cold an no time. No mod. to front axile,no locking hubs an no controller on it. I not use it for awile ,an when i did 4 wheel did not work'''
  • Anonymous May 11, 2010
    Have you checked to see if transfer case linkage is actually engaging the unit? Has anyone modified front axle and put manual locking hubs on there? Does the axle have a controller on it?
  • Anonymous Mar 25, 2014
    Stuck in 4wheel drive and will not come out why
    Will not come out of 4 wheel drive
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Mar 08, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
Helped
5727
Points
19
Our Jeep Wrangler YJ's are equipped with a vacuum module on the front axle. It is used to engage the front axle when the transfercase is shifted into 4WD. Check the vacuum lines on the front axle to make sure they are connected. The passenger side axle shaft has a disconnect sleeve that is moved left and right by the vacuum.
Will not shift into 4wheel drive
On these issue,there are few solved help links for troubleshooting the issue easily.-------
Click the link below:---
No 4x4 light on dash?
http://repairhelpcenter.blogspot.com/2011/12/no-4x4-light-on-dash.html
4X4 Truck makes roaring noise in the front end?
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
Car will not go into 4WD high or 4WD low?
http://schematicsdiagram.blogspot.com/2011/12/car-will-not-go-into-4wd-high-or-4wd.html
4 wheel drive system will not disengage?
http://technoanswers.blogspot.com/2012/01/4-wheel-drive-system-will-not-disengage.html
4WD light is flashing and beeping? NO 4WD high?
http://schematicsdiagram.blogspot.in/2012/02/4wd-light-is-flashing-and-beeping-no.html
2002 Jeep Wrangler: 4WD Idiot Light is ON?
http://technoanswers.blogspot.in/2012/06/2002-jeep-wrangler-4wd-idiot-light-is.html
Traction control switch will not engage on 4WD High or Low
http://whoisbyme.blogspot.com/2012/10/traction-control-switch-will-not-engage.html
4WD light flashing and 4WD will engage after few minutes
http://repairhelpcenter.blogspot.com/2012/10/4wd-light-flashing-and-4wd-will-engage.html
2008 Toyota Tundra: 4x4 Wheel Drive Light is Flashing?
http://technoanswers.blogspot.in/2012/05/2008-toyota-tundra-4x4-wheel-drive.html
4x4 front differential will not engage the axle on ford?
http://technoanswers.blogspot.in/2012/02/4x4-front-differential-will-not-engage.html
4x4 will not engage on Ford F150? http://technoanswers.blogspot.in/2012/02/4x4-will-not-engage-on-ford-f150.html
Dodge Ram 4x4 light keeps flashing 4X4 LOW LIGHT IS FLASHING ON DASH
http://technoanswers.blogspot.in/2012/09/dodge-ram-4x4-light-keeps-flashing.html
Ford 4x4 front wheels will not engage?
http://technoanswers.blogspot.in/2012/02/ford-4x4-front-wheels-will-not-engage.html
These details will help.
Thanks.
I have an 89 jeep wrangler yj, when i try to engage 4 wheel drive front shaft is turnin but front tires are not pulling. any ideas of might be the case? just bought it and prior owner i dont think used the...
If you have a square box mounted to the right front axle tube, make sure the vacuum lines are attached to it and that it's working. If it's OK, then you have likely either have a broken differential gear set, broken outer axle joint or axle itself. I'd bet on the vacuum hose though. They did away with that unit in later jeeps because it was always getting disconnected.
1helpful
1987 jeep yj 6 cyl manual trans. New fly wheel, clutch, presure plate, and batt. Starter is one month old on old worn flywheel with bad ring gear. Inspected starter gear before reinstalled on the new fly...
check to make sure the starter is seated correctly to the bell housing also check for a cracked! nose cone on the starter as well and make sure the front nose casting bushing isn;t worn out and make sure they sold you the correct tooth count flywheel
1helpful
92 wrangler wont go into four wheel
If you have an actuator box on the passenger front axle that may be disconnected or broken. If not remove the cover from the front differential and check the gears...they may be broken.
2helpful
I have a 1987 jeep wrangler and it will not shift into 4 wheel dr
The front axle connects 4wd by vacuum. check the vacuum hoses that run to the actuator. Pay close attention to the vacuum hoses running underneath the battery as battery acid can eat thru those hose easily. Good Luck.
2helpful
1990 jeep yj 4 wheel drive issues
what are you trying to say is that the front wheels wont engage?? if this is your problem? check the actuater on the passenger side axle there are 3 lines that go to it and that is what pulls it in and pushes it out of gear by air.
2answers
4 wheel drive doesnt work.
Has this Jeep been modified at all?
It sounds like the shifter cable was reinstalled backwards.
Specifically the 4-Low "Not Climbing Well". 4-Low should give you the best torque and hill climbing ability.
Do you feel any "Binding" in the steering wheel (difficult to turn)?
Remember a Jeep uses real driveshafts and differentials to give you 4WD - you cannot engage 4WD or 4-Low on dry hard surfaces. It needs a little bit of slip between the wheels for turns.
Check you're fluids too.
13helpful
3answers
4 wheel drive problem on Jeep YJ
you can also check the 4 wheel drive vacuum switch on top of the transfer case...got mine for 10 bucks from parts store...fixed the problem
4wd problem jeep wrangler yj 1995
i just bought a used 97 CHEROKEE but i had the same problem, when i got to looking at it i found out the front driveshaft was shot, look at that, if its not it i would say its probably the transfer case especially with an older vehicle like that which is a very expenxive repair
1helpful
Jeep YJ 1991 4 wheel drive
if u got automatic front hubs stop put in park pull 4x4 shifter into 4 wheel
manual hubs at front wheels turn the hub locks to the lock position and then pull the 4 wheel shifter inti 4 wheel
also look over drivers sun visor if the tag aint worn off the direction are there... have fun 4 wheeling and keep the rubber side down
rank, rate & vote for my solution
Top Jeep Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Jeep Expert? Answer questions, earn points and help others
