Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
I have a leak at the bottom of the cistern where the nut joins to the cistern. The leak is coming from the bottom of the cistern, dripping on to the nut and running down. I have rubber woshers on both sides, in an out the cistern. I have screwed as much as I can. Help. Pleace
    Problem Solver:
  • 5 Answers
It may be that the washers are worn out, or you might have the nut too tight.
Posted on May 02, 2009
I have a leak coming through my ceiling from the ensuite toilet above. It is an ideal standard wall hung with concealed cistern behind tiles. There is no obvious access panel. The tiled wall is flush.
The flush control panel normally comes off. You can then hopefully see inside. You won't be able to see much though as the cistern will be in the way...
Places to look for leaks are:
Soil pipe to pan
Cistern to flush pipe
Flush pipe to pan
Cistern overflow.
Apr 17, 2017 | Home
Tip
FIXING A TOILET THAT WILL NOT FLUSH!!! a simple but very effective money saving...
This simple how to, is based upon most lever operated toilets, with the cistern mounted above the toilet bowl. The make and model of toilet used for this feature is of the following:
Toilet and internal syphon
DUDLEY ELITEDudley S7 Cascade syphon
Problem:
My toilet will not flush, but the ball float valve is working and there is water in the cistern; no leaks present and the flushing lever is not broken or disconnected, what do I do?
Answer:
first isolate the water to the toilet or the main water supply to the house. Bail out the water from the cistern using a small jug or cup, (or you can syphon the water manually using a hosepipe or similar pipe, a towel to cover your mouth, and either a bucket or the toilet bowl) and remove water from the bottom of the cistern with a sponge.
Changing the syphon in a toilet that is not close coupled is far easier as you do not need to remove the cistern from the wall!
Undo the lower of the two large nuts beneath the cistern using a large pipe wrench or pair of water pump pliers, now disconnect the flush pipe and push it to one side.
Place a bucket or bowl beneath the cistern and undo the Nut which is immediately below the cistern (syphon replacing nut), some water may be released by the syphon, take note of any washers that are removed as new ones need fitting when replacing the siphon.
Unhook the lift rod from the flushing lever and remove the syphon.
Inside the toilet syphon, there will be a small plastic piece of sheet called a diaphragm; you can fabricate a replacement using the plastic title cover on a DVD case. Cut this to the exact same size and shape as the original part, and fit this to where the original diaphragm was. This is your new replacement.
Refitting is a complete reversal of removal, be sure to fit any washers (preferably new ones) that you have taken out. Ensure everything is tight but do not over tighten before refilling the cistern
on Aug 09, 2010 | Plumbing
Why is gas dripping/runnng out bottom overflow line of carb?
Could be one of the carb floats is stuck or the rollover caused it to come off its mounting position. As fuel enters the carb, the float rises with the fuel level until it reaches a position that shuts off any more fuel entering the float chamber and prevents an overflow. Fuel level drops, float drops and fuel flows again. Basically like the cistern in a toilet.
Feb 11, 2016 | ATVs
Caroma toilet 12years old, concealed cistern. Water leaking around base when toilet is flushed. water level maintained when not flushing, so the leak must be between the cistern and the bowl. Had a plumber...
Fixing a leaky toilet is actually rather simple, requiring few tools and just a little time and effort. In looking at Caroma toilets on Google, they appear to be just a standard type of unit, and should present few if any problems for yourself or any handyman of modest skill.
If it is leaking around the base of the toilet - where the toilet sits on the floor, the repair item is a simple wax seal. Here is a tutorial to effect this repair: Replace Toilet Wax Ring. The wax ring is very inexpensive, usually $5 to $10 USD.
If the water is leaking from between the tank (cistern) and the toilet bowl, the job is even easier, as it does not require lifting and moving the entire toilet. A good tutorial for that repair is here: How to Replace Tank to Bowl Gasket . The gaskets, new nuts, bolts and rubber seals come in a kit and also cost only $5 to $10 USD.
I am sorry to hear your Plumber insisted you buy an entire new toilet, but do remember he is in the business of making money!
Jan 28, 2014 | Home
Camry csi 2000 oil leak between engine and transmission
Lots of Camrys do this.
The oil will typically leak from the rear main bearing seal between engine and transmission, but that will appear at the bottom of the joint line, and will not reach the exhaust. This leak is expensive to fix and is usually left as is.
A leak from the cam cover gasket can drip into the exhaust.
The other typical leak is from the distributor shaft o-ring seal. This appears at the top of the join line between engine and trans, and can blow back onto the exhaust.
Jan 03, 2014 | Toyota Cars & Trucks
Trying to remove Porcher Posh BTW toilet. Screws in side of bottom unit do not "undo". They are loose but do not unscrew from base. I have loosened cistern but that is all - "loosen". Screws again undo but...
Removing toilet seat hardware can be a problem, especially as it is prone to corrosion - but it can be done. You can attach a pair of gripping pliers to the nut, apply thread lubricant, and unscrew the bolt from the top OR you can use one of those blade-and-handle hacksaws to cut off the nut OR you can use that little hacksaw to cut off enough excess bolt length to allow a socket to engage the nut and allow the bolt to be removed from the top.
Oct 31, 2013 | Porcher Home
Twyford dual flush cistern
replace the whole control unit
There may be 2 problems
the small washer that shuts off the water flow when the level is reached may be swollen and not sealing properly
the section at the bottom has cracked at a thread level
so by replacing the unit you will eliminate both problems
to remove the unit, turn off the water tap, flush the system, holding the button down until all of the water has gone
remove the inlet pipe at the bottom of the cistern
undo the retaining nut under the cistern and lift the control unit out
there will be water in the bottom of the cistern so use old towels on the floor to soak up the water that will run out
Mar 23, 2017 | Home
Cistern leak
The flapper valve(ball)seat is not sealing. Needs a new seat and flapperat bottom of tank. -Ned-
May 26, 2010 | Caroma CARAVELLE270ADAW-EL Caravelle...
Dripping overflow from toilet cistern.
there is an adjustment screw ontop of the fill valve assembly. Tighten this down and the water level should stop at a lower level unless the internal mechanism has crusted up.
May 15, 2010 | Plumbing
Low-level Cistern - leaking from syphon back nut.
Assuming the seal washer is inside the cistern and there are no cracks in the cistern itself you could apply a silicon sealant to the seal washer inside the cistern.
Apr 04, 2010 | Plumbing
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
1,332 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
