Question about Air Tools & Compressors
How to replace a starter motor on a renult laguna 1.9dti year 2000.
I can only answer this through my own experience and all i can say is this is pig. You can only get to remove it by removing the inlet manifold and turbo from the top, or the drive shaft from the bottom. I chose the top way as i didn't fancy removing the drive shaft and it's complexities. Once the turbo is out of the way you can just about get your hand and tools in but you also need to go underneath to get to the bottom bolts. as above this is just about doable.
When you remove the tubo oil feed pipe watch for the small o'rings each end and remember to make sure they are there when you refit. Again experience, i dropped one and didn't realise untill i had a pool of oil under the car.
Any proffesional mechanics may have an easier way but i can't see how.
Good Luck.
Posted on Mar 20, 2009
Car will not turn over at cold temperatures
central locking not working unless you slam the one particular door very hard drivers side laguna 2000
Jan 26, 2014 | GMC Acadia Cars & Trucks
Renault laguna not starting when engine is hot
Would suggest the starter motor requires removal, cleaning and oiling, and or replacing starter drive.
Dec 10, 2012 | Cars & Trucks
Where do i put power steering fluid in a laguna
Problem here ?? what type of laguna as up till about 99 it was a manual hydraulic engine driven pump later ones had a electric over hydraulic unit at the front right side just behind the bumper ,top up on top of the unit later models have a electric motor under the dash with no hydraulics but a direct drive to the steering column which needs special software to reset the straight ahead position but this is a renault the pain vehicle of my life ,best advice is to buy a old XJ6 sovereign jag if your mileage per year is low
Sep 24, 2012 | 2000 Renault Laguna Estate
Starter motor car won't start
I am guessing that you already suspect the starter motor. If the battery is fully charged and the car won't crank over that could be the problem. You could try jumping across the starter solenoid first, if you can get to it and see if maybe it is just the solenoid. You could take the starter to a place like AutoZone and they can test it for you.
Feb 05, 2012 | 2005 Renault Laguna 1.9
How to ajust idling speed on renult laguna
Hello and welcome to FixYa!
On the throttle body, where the air intake is connected. There is a round thing with a screw driver tip slot. From there, you can adjust the idle of the vehicle. Turn it clockwise or counter clockwise to find the ideal idle for you.
Hope this helps and thank you for using FixYa! Have a good one!
Apr 28, 2011 | 2007 Renault R18
Dear Sir, name : renult magene classic 2002/3
1=idle air control motor bad 2= temputer sensor bad3=replace parts fix
Jan 04, 2011 | 2003 Renault 181
How to remove the starter motor from a renault laguna
dissconnect battery first. the starter motor is connected to the gearbox facing into the flywheel you need to remove any connecthions that are on the back of it then remove the bolts that go through it that hold it on give it a little shake and it should come off.
Oct 18, 2009 | 2000 Renault 181
Air Tools & Compressors Logo
150 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
