Lwhen laptop is turned on it only gives a blank screen.
My laptop starts up with the initial Toshiba screen then goes to a blank screen with a white dash in the upper right corner. No funtion buttons work...NOTHING works. I've tried to start it and run the recovery disk but this does not work either.
  • sureshireddy Apr 11, 2009
    hi
              i have the same problem it started when i tried to install windows xp where as my laptop is preloaded with vista. then i had to restore using recovery dvd system did start but from then when ever there is an update or if i put cd and start or some when i start it it goes blank. the only way i can get back is to restore. i even removed my battery and checked by pluging in still the same problem can any one let me know to get rid of this .
I am having the same problem with my Compaq. I boot up and I can hear it whirrling and doing its business but the image is blank. It lights up but no image.
Posted on Mar 02, 2009
Im having problems with my Toshiba Satellite L455DS5976 it wont start up. it will go to the normal toshiba screen when you turn it on but after that the screen goes blank and theres a white line what...
I had the same problem. Let it run that way for about 5-10 minutes, it should show a menu, choose START WINDOWS NORMALLY.
It will take some more time to boot, be patient. Once you start it, do the clean up, virus check and delete everything you don't it. That worked for me.
If this helps, please rate. Thank you
Jan 15, 2011 | Toshiba Satellite L455DS5976 Notebook
Toshiba M300 screen turns white blank.
White screen means that your lamp (back light) is working absolutely fine, but you could have a loose connection for the data ribbon cable, which sends the images to the monitor.
Carefully open laptop to reach its lcd, there must be ribbon cable which looks like this: mrc-0069.gif
It is very sensitive so be very careful with that, very gently remove this from the chip and reconnect it.
Hope this helps, Please feel free to ask me any further.
Apr 10, 2010 | Toshiba Satellite Pro M300-S1002X Notebook
Laptop boots up but after nothing.
Hard drive is shot. replace and then re install operating system
Jul 05, 2009 | Toshiba Satellite M45-S265 Notebook
Blank white screen in my Acer Travelmate 5730 Laptop
Hello Karthik,
This must surely be a problem with your monitor, because you say that you see the white screen while boot up. If this is a graphic driver issue, you may have the problem after booting up in windows. Since its been only a month old laptop, the product must be in warranty for sure. Take away any CDs in the drive, any USB drives and see if this white screen appears. Let us know.
Thank you!
Sabharish
Jun 26, 2009 | Acer LXA3706003 Notebook
Cold boot the PC by holding the power button for at least 5 seconds.
Hit F8 before the windows logo appears , select Last Known Good Congiuration. Try booting.
If same issue , try again , this time select safe mode , this should allow you to get in and undo any changes you made.
Mar 01, 2009 | HP Computers & Internet
My toshiba m35x-s111 laptop screen goes blank
According to the description of the fault and the symptoms that your equipment presents, you must replace the FL inverter, that is the one that gives the turn on of the screen of your equipment, if your you replace this piece that one finds behind of the mask of the screen in the low part and that is similar to a pen I assure you that your equipment it was working in perfect conditions
Dec 23, 2008 | Toshiba Satellite M35X-S111 Notebook
Toshiba satellite screen blank
This could be that the hard drive has failed, and could also be the reason for the initial crash. Run a drive test in the bios or set up. If the test fails in any area then the hard drive is bad and will need replaced. If it passes, then reformat the drive and reinstall XP.
Jul 29, 2008 | Toshiba Satellite A100-S8111TD Notebook
My Toshiba laotp's screen goes half blank help!!
Well try to boot into the safe mode.hit F8 on the startup and see if you get the same acreen.If its working fine in safe mode than you need to reinstall the video driver and that should resolve the issue.If it is still not working try connecting a external moniter.If you get the same display on the external moniter than its an issue with the video card and if you get a normal display on that than its an issue with the Laptop screen and you would ahve to get either of thses replaced by contacting the manufacturer.
Hope this helps!
Sep 17, 2007 | Toshiba (225EXTR5)
Computers & Internet Logo
386 people viewed this question
David Payne
David Payne
