Question about Lavazza Espresso Point Capsule Machine
Hot water LEAK in bottom drawer - PINHOLE in the heating element!
I started getting half-full cups of expresso and American coffee from the machine together with a large hot water leak coming from the left side of the machine and a lower drawer with the missing water that did not go into the coffees!
Well, as I am an engineer, I thought it would be wise to disassemble to machine to find out what the problem was!
I unscrewed and removed the top plate right on top of the heating element. The plastic hoses are in perfect condition - no leaks coming out either from the hoses nor from the fittings to the water tank or heating element.
SO, I decided to plug the machine to the electric outlet and ran the machine to get a coffee out of it to see what happened, and
HELLO! did I get a surprise when I ran the machine without the top metalic plate. There is a minuscule PINHOLE in the body of the heating element, which is jetting steaming water out of the heating element STRAIGHT into an electrical connection that has 2 wires coming out of it! So, even though I knew it was not a good idea to get close to the machine while it was jetting steaming water out of the unit and spraying it into the electical fitting, I saw that half or more of the water supposed to go into the expressso coffee, was just leaking out of the body of the casted heating element. I can tell that there is not gasket or anything to be replaced in the heating element because it is a PINHOLE in the body itself. Therefore, I think, I need a new heating element.
Does anybody know if I can get/and where a new heating element to replace my leaking one?
If you experience this same problem, WATCH OUT! You could have the same problem I have and this situation could represent a MAJOR hazard because you could get an electric shock if you are touching the machine and water coming out of it while the machine is running!
JUST TAKE CARE, please.....
SOURCE: Leakage when filling espresso cup
I had the same problem, there is a O-ring seal between the heater and water feed...U have to remove apprx 8 allen screws on the top of the heater plate, remove the wiring connectors from the heating element and overload sensors and the heater plate romoves from the attached bottom plate. The seal is located on the center nipple and is apprx 1/8" round. Replacing it with a seal from the hardware store corrected my problem...GOOD LUCK!
Posted on May 31, 2008
SOURCE: replaced gasket now I can't find what was plugged in...
Do you still have this problem? If you want I can send you a picture of this part.
Posted on Jan 13, 2009
wentlanv
  • 710 Answers
SOURCE: I have the Lavazza point.
I owe this solution to one of our experts, Seldemseen: "there is a O-ring seal between the heater and water feed...U have to remove apprx 8 allen screws on the top of the heater plate, remove the wiring connectors from the heating element and overload sensors and the heater plate romoves from the attached bottom plate. The seal is located on the center nipple and is apprx 1/8" round."
He replaced his seal with one from his local hardware store.
Good luck to you,
I hope this helps. If it did, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 25, 2011
walesarumi
  • 6993 Answers
SOURCE: Everytime I brew espresso in
How are you sure the gasket is exactly the fix to this problem? I would suggest you perform some diagnosis first in order to know precisely the cause of the problem so that a solution can be proffered.
I would like you to read through the below first to get the root of the problem.
Tools and Materials needed to fix this problem are as:
* White Vinegar
* Fresh Water
* Volt-ohm Meter
* Screwdriver
Step 1 - Clean
If your coffee maker seems to be clogged, try cleaning it with a mixture of white vinegar and water. Assuming that your coffee maker has a 12 cup capacity you will want to use 11 cups of vinegar and 1 cup of water. Fill the coffee pot to the 11 cup mark with vinegar and then fill it to the 12 cup mark with water.
Pour this mixture into the reservoir and turn on the coffee maker, allowing it to run through a brewing cycle as if you were making a pot of coffee. By doing this you will dissolve any build up in your coffee maker. If the coffee maker is leaking because the pump is clogged, then this might clear the clog and stop the leaking. If it has been a while since you last cleaned your coffee maker, you may need to run the vinegar through more than one cleaning cycle to dissolve all of the buildup.
Step 2 - Pump Valve
Unplug the coffee maker and examine the pump valve. If the pump valve is broken or has a clog, then the water will not be able to rise up and flow through the fill tube. When the coffee maker is turned on, the water needs to go someplace. If it cannot flow through the fill tube, then it may leak onto the countertop. If the pump in your coffee maker is sealed, you will need to replace the whole pump. If the pump is not sealed you should check it to ensure it is not clogged with coffee grounds or mineral deposits.
Step 3 - Brew Switch
Examine the brewing switch to ensure that is working. To get to the brewing switch, remove the base plate. Next, you will need to test the switch with your volt-ohm meter. Touch the tester to the RX1 scale. If it reads 0 ohms then you will know that the switch works fine. If it gives you a number other than 0 then it is time to replace the switch.
Step 4 - Tube Connectors
If the coffee maker is leaking or sputtering then you should take a look at the tube connectors. Many times, a leaky coffee maker is caused by faulty tube connectors. If you find the leak is in an elbow, clean the surfaces before you replace it. If the tube connector leaks, replace both the tube and the elbow so that you can be sure the pieces will both fit together properly.
I hope the above helps....
Good luck.
Posted on Jul 18, 2011
espressonist
  • 1711 Answers
SOURCE: I have a lavazza pod
The bottle water it may be purify and full of all the minerals which are essential for humans, however for machines are the a desaster since the minerals will build up scale in the water system. So now you will need to perform and descale and if you did not perform it frequently try to do it two or more with interval of 2 days each. Also try to leave the solution in the machine for about 45 minutes to 1 hour so it can desolve as much as possible of scale. A tip is to flush out some solution every 3-4 minutes so to move smaller parts and avoid the posibility a large scale parts unstuck and have a complete blockage in a nuroow point like a valve.
After that you should perform a descale every month.
The good thing is that you still have the machine pipping open so you can perform the descale. In other case if the machine was completly blocked then the only solution would be the complete desasemeble of the machine and manual descale all piping.
Posted on Aug 06, 2011
What makes a perculator heat?
Hi, If you have a Farberware, Just look into the bottom of the pot. There you will see what looks like a hole in the pot. That is the high heating element, under the pot, when you go to make coffee the pump ( rod) sits into the hole. When you turn it on to make coffee the high heating element that the pump is in gets very hot and starts pushing the water that is in the hole to the top (that is called perking) the hot water goes over the the top and the drops into the coffee, This keeps going on until the thermostat feels it has reached 190 degrees or close to it and turns the high element off. While this is running it's cycle the keep warn is on helping the water to get hot, when the main element is off the keep warm element that runs around the bottom of the pot stays on all the time the pot is plugged in. Should the coffee get to cold the thermostat will turn the main heating element back on until it is back to 190. This system was developed by Farberware and a lot of makers copied it, But Farberware sold the pots and was known for a FAST and HOT cup of coffee. Farberware started making them in China and the pots are having a hard time keeping it up to American standers, and parts are very scarce.Farberware USA pots have been around a long,long time and are still going strong . I hope this helped you to understand how the pot works.
Dec 09, 2010 | Faberware 12-55 Cup Coffee Urn
Water does not pass through the Mr. Coffee. Just started out of the blue a few days ago. Heating element definitely works as steam just pours out the back of it but after running for 15 mins or so only...
Most of the time the coffee maker just needs cleaning with some Vingar sulution run though it.Do this about every 6 mouths.what happens specially with hard water it cluggs line up.So go to store buy small or big bottle of Vingar put about 1 cup in and half cup water aloud it to go though cycle's.Then or you may put two cups of vingar and two cups of water depend on how clugg it is.Then after done fill water despenser up to run Full pot like 12 cups,but donot over fill.that cleans it from the Vingar taste.You may want to do this twice.Hope this help,thanks for your question it was a good one.
Aug 08, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
The coffee maker just quit midway through brewing this morning with half a resoviour of water left in it. I cleaned the screen at the bottom and determined there is no clog. Perhaps the heating element...
That has happened to me, and I ran a full 10 or 12 cups of vinegar and then 3 more times of water thru the coffee water resoviour and it took care of the problem. It is probably overdue for a cleaning.
Jan 11, 2010 | Cuisinart DGB-600BC 10-Cup Coffee Maker
I've owned this saeco vienne de lux for about 3
Hi
When was the last time you descaled the machine? Scale will build up inside the boiler and insulate the water from the heating elements. The thermostat is on the outside by the heating elements so it gets hot but your water is warm. There are other things but check this first.
Nov 22, 2009 | Saeco Vienna De Luxe Espresso Machine
Hello. I have had my Incanto Sirius S-Series for
check your brew valve,maybe is plugged or leaking in tray.
Sep 03, 2009 | Saeco Incanto Sirius Fully Automatic...
Expresso comes out warm not hot what is problem
The magic delux has only one boiler so if you are getting hot water and steam, then it could be that the cup used to brew into is taking the heat from your espresso, trly warming up the cup before brewing into.
Jun 03, 2009 | Saeco Magic De Luxe Espresso Machine
COFFEE MAKER LEAKS CLEAR WATER FROM THE BOTTOM EVERY TIME I USE T
Have the same issue, looking for my receipt for warranty. All of us having this problem can't be wrong and it must be defective
Dec 30, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Can't get a full cup of coffee
First, you should not be using your espresso machine as an american coffee maker. It puts way too much pressure on the components of the machine. The standard cartridges are made to do 1.5 - 3.0 ounces of espresso. should you want to make a longer cup of coffee you need to get the aroma point gran caffe cartridges, lavazza code 427. this will enable you too get the longer cup of coffee without putting the added stress on your machine. Also it sounds like your machine mighy have a problem with the volumetric device. are you getting water in the capsule ejection drawer? should you want service you should call 781-393-2929. we are an authorized lavazza distributor and repair center.
Oct 09, 2008 | Lavazza Espresso Point Capsule Machine
Gevalia CM-500 12 cup problem.
Underneath the hot pad that the carafe sits on, there are two thermal fuses that are inside tubes that are clamped to the heating element with spring clamps.
Remove the bottom of the unit (5 screws), unclamp the thermal fuse tubes, slide the tubes to one side and check the each fuse with an ohmmeter. If one of them is open, that's your problem.
Aug 30, 2008 | Gevalia CM-500 12 Cup Coffee Maker
Lavazza Espresso Point Capsule Machine Logo
78 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
